Erwin Posted April 18, 2011 Posted April 18, 2011 (edited) Hi all, My second entry in this GB... Using spare decals from other kits and "one of a kind" printed code letters it will be in markings of the Light Aviation component of the Belgian army as used in the 1960's. Edited April 18, 2011 by Erwin
It'sAllGoneHorriblyWrong Posted April 18, 2011 Posted April 18, 2011 Blimey, have you finished the Willow already?!
Erwin Posted April 18, 2011 Author Posted April 18, 2011 Blimey, have you finished the Willow already?! Euugghhhh...NO !
gfurm Posted April 20, 2011 Posted April 20, 2011 I build that a while ago. Two things: the air intake will not fit in the gap under engine cowling. If you want to close cowlings: the bulkhead between cockpit and engine should be flush with fuselage. If it sticks out a bit then you'll have a gap between fuselage and cowlings. Also you may want to leave as much engine pieces out of it, it's a little on the big side. Greg
seadog Posted April 30, 2011 Posted April 30, 2011 I build that a while ago. Two things: the air intake will not fit in the gap under engine cowling. If you want to close cowlings: the bulkhead between cockpit and engine should be flush with fuselage. If it sticks out a bit then you'll have a gap between fuselage and cowlings. Also you may want to leave as much engine pieces out of it, it's a little on the big side. Greg Yes, the whole area is a little fiddly....I have slight gapson mine, but so does the original...a little. F
Erwin Posted May 5, 2011 Author Posted May 5, 2011 The green is done... I'm using satin Humbrol green 195 and Revell brown 381.
Jasonb13 Posted May 24, 2011 Posted May 24, 2011 Looking nice Erwin, very nice camo and the decals look sharp. Looking forward to her taking shape... J.
seadog Posted May 24, 2011 Posted May 24, 2011 Camouflage and decals done... The camo really suits the Cub.
