MiG-15Bis R used during the Korean war?
Antoine
I'm considering buying the Ciro conversion for a MiG-15Bis R (For tamiya's kit).
The colour options seems to be quite limited with this aircraft, and I was wondering if it had been used during the Korean war?
Any idea?
I Got to get the lattest Yefim Gordon book, but I'm not sure it wil give answers.
Resolution of the Council of Ministers number 1706-663 of 25 April 1950 and the Order of MAP from April 28 , DB-155 has been received to develop and produce in July on the state tests MiG-15bis is equipped with a camera for a planned shooting AFA-BA/40.
MiG-15bis number 53210120 was transformed into an armed scout plane, one gun HP-23 was removed, under the cockpit was set the desired camera. In addition EDB has introduced a number of improvements in the design of the pressurized cabin, changed the system of charging and heating system, installed lamp and filter GF-1103, which prevents contamination of the air cab. Operating pressure hose was lowered to reduce wear and hose assemblies. The plane was designated as "SR" and with a slight delay in the middle of August he was transferred to the Civil Air Force Research .
State testing began on August 15 and ended Sept. 16 , with unsatisfactory results. Air Force did not suit virtually all changes made ​​to the aircraft, photographic equipment in their opinion it was inconvenient to use and not effective as a new pressurization system, as well as a filter. Sweating and freezing on a new lamp, and were not fully eliminated. However, it was noted that the plane "SR" has kept the speed and maneuverability of the MiG-15bis, as well as most of the weapons that allowed the aircraft to not only serve as a scout, but also to successfully conduct a dogfight. Thus, the combat radius "SR" in the conduct 10 minute air battle, and 10% fuel reserve of more than 500 miles with drop tanks .
In early August, the Council of Ministers noted the inadequate provision of Air Force reconnaissance aircraft, and under the pressure under the designation MiG-15Rbis airplane "SR" was accepted for service and put into serial production at the plant № 21 in Gorky .
http://www.flickr.com/photos/theadventurou...in/photostream/
My suggestion is that you go to google,than advance search/only sites on russian and write МиГ-15бис СЯ you should get a alot info and pictures.
Kind regards,Sven.
Edited by Killa
