keefr22 Posted May 12, 2011 Share Posted May 12, 2011 Question today 1622 via the "Contact Us" form on the website, e-mail response 1810. Maybe I just got lucky! Thanks for the reply, I'll try again tomorrow!! K Link to comment Share on other sites More sharing options...
tonyh Posted May 13, 2011 Share Posted May 13, 2011 Well, let's wait until we've seen a revised example before we judge how successfully the nose has been corrected. But, as you say, hats off to a small company for recognising that there's a problem with one of their products and doing something about it. I've asked Campbell what changes he's made so I can carry them across to my unrevised versions. I agree that it's a lot easier to file off a cannon bulge than to add one.There are also some other additions (not further identified) to the O&O range awaiting posting on the website. Hi Seahawk, could I ask you to share the changes that have been made with the rest of us so we can correct the unrevised versions in our stashes? Regards Tony Link to comment Share on other sites More sharing options...
Pat C Posted May 13, 2011 Share Posted May 13, 2011 Mine just arrived. I must say on mine the plastic under the rear of the tail pipe does seem reasonably thick and I reckon I could probably shave off 1mm to at least give the impression of the F4 tailcone. Top of the build pile! Pat Link to comment Share on other sites More sharing options...
SimonR Posted May 13, 2011 Share Posted May 13, 2011 Mine just arrived. I must say on mine the plastic under the rear of the tail pipe does seem reasonably thick and I reckon I could probably shave off 1mm to at least give the impression of the F4 tailcone. Top of the build pile!Pat Nice one Pat, look froward to seeing it. I managed to get the fuselage together and wings on last night - the port wing went on perfectly, but the starboard wing was a nightmare fit, I guess there is going to be some differences in the moulding of this! Link to comment Share on other sites More sharing options...
keefr22 Posted May 13, 2011 Share Posted May 13, 2011 Nice one Pat, look froward to seeing it. I managed to get the fuselage together and wings on last night - the port wing went on perfectly, but the starboard wing was a nightmare fit, I guess there is going to be some differences in the moulding of this! My starboard wing wasn't a nightmare as such, but was definitely 'different' to the port, which fitted much more snugly (even though the rear wing root on the lower wing was broken off & missing!) K Link to comment Share on other sites More sharing options...
Seahawk Posted May 16, 2011 Share Posted May 16, 2011 Hi Seahawk, could I ask you to share the changes that have been made with the rest of us so we can correct the unrevised versions in our stashes? As requested. Verbatim from Campbell, with his permission: "What I did to correct the nose shape, was to remove the extreme nose of the conversion. At the first panel line behind the gun ranging radar cover. I replaced this with the extreme nose from the Revell kit, this needs to be sanded back to a flat face removing the chamfer. Then it is simply a case of bringing the contours in to match the new nose. As I mentioned in my previous e-mail the website will be getting updated soon, keep an eye on it as there will be pictures of the new nose appearing soon." He's also asked me to point out that he now does his own casting, meaning he always has stock now. Link to comment Share on other sites More sharing options...
keefr22 Posted May 16, 2011 Share Posted May 16, 2011 He's also asked me to point out that he now does his own casting, meaning he always has stock now. Hmm, wonder why he hasn't answered my e-mails then? No worries I suppose, I probably won't build another one befor SMW, so I'll get one off him then. K Link to comment Share on other sites More sharing options...
tonyh Posted May 16, 2011 Share Posted May 16, 2011 As requested. Verbatim from Campbell, with his permission:"What I did to correct the nose shape, was to remove the extreme nose of the conversion. At the first panel line behind the gun ranging radar cover. I replaced this with the extreme nose from the Revell kit, this needs to be sanded back to a flat face removing the chamfer. Then it is simply a case of bringing the contours in to match the new nose. As I mentioned in my previous e-mail the website will be getting updated soon, keep an eye on it as there will be pictures of the new nose appearing soon." He's also asked me to point out that he now does his own casting, meaning he always has stock now. Thanks for passing this on Seahawk. Much appreciated. Tony Link to comment Share on other sites More sharing options...
Richard M Posted June 15, 2011 Share Posted June 15, 2011 Oh, and I forgot to mention the seats which are completely wrong - those in the photos are Mk.2H seats, the T-birds used Mk.4H seats which are totally different - no thigh guards on the seat pan, no parachute container, horseshoe parachute pack and combined harness etc., etc.. Just want to check on this, not casting doubt, just want to nail down a source. The Martin Baker website lists the Mk.4H variant being used on export T.7 Hunters, it doesn't list them as being used by the UK. The Mk.2H and Mk.3H it lists as being used in UK and other nations Hunters without specifying a mark. Is it possible the RAF T.7's used Mk.2H's in common with the rest of the RAF fleet and it was only export T.7's which had the Mk.4H fitted? http://www.martin-baker.com/products/Eject...k--9/Mk--2.aspx http://www.martin-baker.com/products/Eject...k--9/Mk--3.aspx http://www.martin-baker.com/products/Eject...k--9/Mk--4.aspx Thanks. Link to comment Share on other sites More sharing options...
AnonymousAA72 Posted June 15, 2011 Share Posted June 15, 2011 Is it possible the RAF T.7's used Mk.2H's in common with the rest of the RAF fleet and it was only export T.7's which had the Mk.4H fitted?Thanks. No.....The T7 & T8 most definitelly used a pair of Mk IV seats. Xtrakit have it wrong. Link to comment Share on other sites More sharing options...
Richard M Posted June 15, 2011 Share Posted June 15, 2011 (edited) Thanks, I haven't found the Mk.4H in 1/72 scale anywhere, does one exist (Aeroclub?), or is it a case of hoping an aftermarket company does some? Presumably the PJ Production and LF Models conversions and kits come with Mk.4H seats, maybe they will release them as stand alone - PJ already have the 2h and 3H seats available now in 1/72. Edit; Pavla doa Mk.4 for the Alpha Jet, Mirage I/III, is this close enough? http://www.pavlamodels.cz/katalogy/detail....;styl=styly.css Edited June 15, 2011 by Richard M Link to comment Share on other sites More sharing options...
AnonymousAA72 Posted June 15, 2011 Share Posted June 15, 2011 Thanks, I haven't found the Mk.4H in 1/72 scale anywhere, does one exist (Aeroclub?), or is it a case of hoping an aftermarket company does some? Presumably the PJ Production and LF Models conversions and kits come with Mk.4H seats, maybe they will release them as stand alone - PJ already have the 2h and 3H seats available now in 1/72.Edit; Pavla doa Mk.4 for the Alpha Jet, Mirage I/III, is this close enough? http://www.pavlamodels.cz/katalogy/detail....;styl=styly.css I'd use that if I had no other choice - I can't imagine any variations in the 4 Series of seats would be that noticeable in 1/72nd!! I do have a few Aeroclub seats in the stash - not sure if they're available still? Link to comment Share on other sites More sharing options...
