SaintsPhil Posted March 14, 2011 Share Posted March 14, 2011 Morning! Has anyone had success spraying the windsor and Newton artist varnishes? If so I assume it needs thinning, any suggestions what to thin it with? Thanks Phil Link to comment Share on other sites More sharing options...
periklis_sale Posted March 14, 2011 Share Posted March 14, 2011 I use the mat acrylic varnish thinned with tab water! Link to comment Share on other sites More sharing options...
C6MSD Posted March 14, 2011 Share Posted March 14, 2011 I use the mat acrylic varnish thinned with tab water! Ditto Link to comment Share on other sites More sharing options...
speedy Posted March 14, 2011 Share Posted March 14, 2011 As above, and you can brush it and it comes out fine. Link to comment Share on other sites More sharing options...
SaintsPhil Posted March 14, 2011 Author Share Posted March 14, 2011 Thanks guys, I've been brushing up to now, but I find it a little awkward to get everywhere sometimes, especially using a big flat brush to avoid brush marks. I assume it cleans up ok with water as well? From the the airbrush that is! Link to comment Share on other sites More sharing options...
periklis_sale Posted March 14, 2011 Share Posted March 14, 2011 yes pure tab water! Link to comment Share on other sites More sharing options...
offender Posted March 15, 2011 Share Posted March 15, 2011 windsor and newton varnish is great stuff but its very susceptible to water if you wash the dust off your models under the tap like i do i have had the varnish come off and also go white and stay white i sent a email about this and this was the reply "The Galeria Matt Varnish is designed to be removable with an alkaline solution. And therefore it is possible if it is cleaned vigorously with water that some of it may be removed or if the water being used has a Ph of above 7. (it is alkaline) If you want to ensure that your finished work has optimum water resistance then we suggest you use the W&N Artist Matt varnish which is removable with white spirit not alkaline water." so if your using "galeria" version of the varnish you might have a problem if your using the "artist" version you should be ok thanks rob Link to comment Share on other sites More sharing options...
