Hi guys,
picked up the1/35 scale Jagdpanther (early) from Gunz Sangyo at a kit swap run by my club this week,& I can see why these were regarded as the dogs danglies when they appeared in the mid 90's + there was a jordi robio barrel & mantle thrown in ( bonus) wondering if this is the same kit as dragon released in their original boxing as I've heard Dragon reboxed a lot of Gunz kits in the early days so I Can use AM stuff such as zim for it...
Thanks Andy :cheers:
If you go to the Axis forum on Missing Lynx, the Panther nuts will tell you exactly whats what with your Jagdpanther!!
smuts those kits are lovley for thier age
and were a small fortune when released i'm sure
well they were to fledling teenager as i was then
you should be able to use zimm kits such as cavalier zimm or atak zimm ,
as they also do "generic " sheets of various patterns of zimm just trim and use
heres a tip though if a zimm sheet isnt quite long or wide enough
get some plastic weld or similar glue and paint itover theresin and it becomes
rubbery it can then stretch its the only time you can use plastic cement for resin and i even use it to atatch
the zimm plates to the model surface be gentle and it'll do what you tell it fill the edges and go !
hope this helps
