MakingModelsAgain Posted March 1, 2011 Share Posted March 1, 2011 Have just sprayed (for the first time) with Vallejo Gloss in prep for decals and weathering and the result is about as shiny as a brick wall. I first diluted with water - as per instructions - but nothing. Then neat, but still not even a satin finish, just a slightly rough feel. Spraying at app 20-25psi. Any hints...? I do have Klear, so was wondering if I should use that instead? Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted March 1, 2011 Share Posted March 1, 2011 good luck spraying Klear! its a *itch to spray Link to comment Share on other sites More sharing options...
SaintsPhil Posted March 1, 2011 Share Posted March 1, 2011 I've had problems with it too, I did get a gloss finish but it was very thick and was bumpy to the touch, I assume this is the orange peel effect. Sorry doesn't help you but at least you're not alone! Link to comment Share on other sites More sharing options...
mideast-mover Posted March 1, 2011 Share Posted March 1, 2011 I was literally about to start spraying with this for the first time....I think I'll mark time for a moment... Let's hope the wisened members of BM have some advice. Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted March 1, 2011 Share Posted March 1, 2011 Spraying at app 20-25psi. Any hints...? thers your problem. too high! its drying on contact and leaving behind dots. lower it to below 20. i usually spray at 15 or a bit higher. when thers a lot of paint i lower it to under 15 so the wet paint wont run! Link to comment Share on other sites More sharing options...
MakingModelsAgain Posted March 1, 2011 Author Share Posted March 1, 2011 Thanks Adrian! Well, I tried a coat at 15psi-ish and now have a textured finish, but that's no doubt due to what I was already working on! Hehehe.... So not only back to the drawing board, but also the cupboard where I keep the Fairy Power Spray! So it's off with this coast (second time!) and a fresh start tomorrow!(third time lucky!) Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted March 1, 2011 Share Posted March 1, 2011 If you want to remove the ''textured finish'' and restore the surface to a smooth finish just went sand it a little and re spray. i always wet sand when i have imperfections after gloss. Link to comment Share on other sites More sharing options...
MakingModelsAgain Posted March 1, 2011 Author Share Posted March 1, 2011 If you want to remove the ''textured finish'' and restore the surface to a smooth finish just went sand it a little and re spray. i always wet sand when i have imperfections after gloss. Thanks again Adrian, I thought about that, but it's only a wee 1/144 Eurofighter Typhoon and that makes for a fiddly proposition. God knows how many times I've broken off the front stabilisers and now that she's fully loaded, there's a lot to snap off! Link to comment Share on other sites More sharing options...
M4rk Posted March 6, 2011 Share Posted March 6, 2011 For future reference, Klear does not need to be sprayed on. It brushes on very well and self-levels, leaving a smooth glossy surface for decalling. I have had similar experience to yourself with Vallejo gloss and have not managed to find the right way of spraying it as yet. I would suggest lower pressure and closer spraying distance from the model. Link to comment Share on other sites More sharing options...
T-Tango Posted March 6, 2011 Share Posted March 6, 2011 I've not had any problems with Vallejo varnishes, I do use their own thinners, about 50/50 and spray at 15psi, however you will need a few coats to get a good gloss. HTH Link to comment Share on other sites More sharing options...
Julien Posted March 7, 2011 Share Posted March 7, 2011 Definatly too high a pressure. I spray at about 15psi using vellejo airbrush cleaner to thin and have had nothing but perfect results with vellejo varnish Julien Link to comment Share on other sites More sharing options...
Rebilda Posted May 3, 2011 Share Posted May 3, 2011 The downloadable manual states one drop of Vallejo Airbrush thinner for every three drops of paint. I always do that, even with the Gloss Varnish and spray it at 10 PSI. Spray it kind of 'wet', don't mist it, really! Works every time. 20 to 25 PSI is WAY too high, can't remember when I used that high a pressure other than cleaning. But that's me. Link to comment Share on other sites More sharing options...
antoniom187 Posted December 20, 2016 Share Posted December 20, 2016 reincarnating this old topic, but does anyone know what the shelf life of vallejo gloss varnish is? Mine has gone quite yellow in the bottle, and when I spray it (with the recommended 20% thinners at 15psi), I get a blotches that won't level. Link to comment Share on other sites More sharing options...
Steve Noble Posted December 25, 2016 Share Posted December 25, 2016 As per the shelf life I've got a bottle almost 5 years and it's not gone yellow yet. As for the gloss level, well it's not great. When you paint it just seems to soak into the base colour and never goes glossy. It ends up dry and gritty. Best clears for high gloss are auto clears as used on full size cars. But they can be problematic over model paint and lift or even melt it.. Link to comment Share on other sites More sharing options...
