Jazzy Jase Posted January 24, 2011 Share Posted January 24, 2011 Can anyone tell me the difference between Carbon Steel and Stainless Steel Swann Morton blades? Link to comment Share on other sites More sharing options...
Mike Posted January 24, 2011 Share Posted January 24, 2011 I'm guessing that the carbon steel ones are like the ones I have, and if you get them wet they go rusty Link to comment Share on other sites More sharing options...
Dave Fleming Posted January 24, 2011 Share Posted January 24, 2011 I've found the stainless ones tend to keep their edge longer. Link to comment Share on other sites More sharing options...
Jazzy Jase Posted January 24, 2011 Author Share Posted January 24, 2011 I don't plan on getting them wet. I was mainly wondering if one was sharper or stayed sharper for longer? Link to comment Share on other sites More sharing options...
sinnerboy Posted January 24, 2011 Share Posted January 24, 2011 In theory Carbon steel should keep it edge longer providing it has been heat treated & then ground ( heat treating increases hardness but makes more brittle which is reduced somewhat by tempering ) where as SS has Chrome added which while increase hardness a little is mainly to make it more resistsnt to oxidising & staining Link to comment Share on other sites More sharing options...
Jon Kunac-Tabinor Posted January 24, 2011 Share Posted January 24, 2011 I didnt even know they made stainless steel ones! is that for surgical use perhaps? Jonners Link to comment Share on other sites More sharing options...
andym Posted January 24, 2011 Share Posted January 24, 2011 You can only get Carbon Steel in unsterile packs and they are cheaper. HTH andy Link to comment Share on other sites More sharing options...
little-cars Posted January 24, 2011 Share Posted January 24, 2011 The standard packs of 5 blades that you usually buy are all carbon steel and non sterile - standard ones and the generally the cheapest The single peel pack blades that are non sterile and carbon steel -limited range of blades, these are about 15% more . Sterile blades are available in single metal foil packs, in either Carbon steel or stainless steel. Carbon sterile are about 20% more and stainless are 25% more than the standard packs. There are some blades only availalble in some of the sterile ranges, so you are less likely to see them in our market. Link to comment Share on other sites More sharing options...
Rosco Posted January 27, 2011 Share Posted January 27, 2011 Currently using a Swann - Norton number 3 handle with 11p blades but I find then prone to snapping where they clip onto the handle. Just wondering if what other folk are using and if there is a stronger blane / handle combo. Thanks Link to comment Share on other sites More sharing options...
little-cars Posted January 28, 2011 Share Posted January 28, 2011 The number 3 is the standard handle, and the sides where some of the blades can be fairly narrow, 11p is a very light duty blades so can snap if you are doing heavy duty cutting. For heavy work switch to either a craft knife or the no 4 handle that has the heavy duty blades with a 25a or 26 blade. Link to comment Share on other sites More sharing options...
Dave Fleming Posted January 28, 2011 Share Posted January 28, 2011 Currently using a Swann - Norton number 3 handle with 11p blades but I find then prone to snapping where they clip onto the handle. Just wondering if what other folk are using and if there is a stronger blane / handle combo. Thanks 11 seems particularly prone to that, although I have snapped no 10 blades as well. These days the ones I tend to use most are the 15 and 15a blades, with 10a as a back up (but usually have a no.6, 11 and 15T lurking around as well. For heavier duty, I tend to use a no 4 handle with a 23 blade, but to be honest for anything that involves a bit of pressue on the knife or doesn't need delicate touch, I tend to reach for a more general purpose knife. Link to comment Share on other sites More sharing options...
AdriaN (MLT) Posted March 23, 2011 Share Posted March 23, 2011 I use handle no3 and use non sterile staineless steel blades 10 & 10A. Bloody sharp but they blunt so easily! Link to comment Share on other sites More sharing options...
