For my next trick!
I will be mostly converting one of these
to one of these
Probably somewhat predictably she will be finished as ZE887 of 11 sqdn in 2005 90th anniversary scheme. She will be the first of my 11 sqdn jet project which will consist of an F6 Lightning, this F3 Tornado and a current Typhoon all 1/32.
anyhow, I promise I will be a bit more regular with the updates.
Edited by Phartycr0c
Oooh, I was gonna try to see if I could blag your skyshadow pod, but it's an IDS! Awww... :)
I'll find me one yet so I can complete mine!
Looking forward to being thoroughly upstaged in quality and modelling skill in the meantime :worthy:...front row centre for me please... :popcorn:
Interesting wee project. I was planning on doing a similar line up of my Harrier, Tornado and my Eurofighter, in a "Modern tools of RAF" theme. Just need Trumpet to get a wiggle on with a 1:32 GR7 or something, so I don't have to look with distain at my AV8B :D
What? the RAF cancelled the Harrier part? Sorry, I can't hear you..<sticks fingers in ears>....la, la, la, la....
Edited by silverburn
Hi Pharty,
What's that resin you're using?
Dave.
Hi Dave,
I was fortunate enough to lay my hands on one of Meindert de Vreeze's resin conversion kits. It was a limited run and has been sat in my stash for a good couple of years.
A little bit of hacking and filing of the relatively soft plastic later and this emerges.
one gets the impression of what this bird will look like.
one decision I do have to make is wether to smack in the paragon Flaps and slats set. If I do Ill aim at doing a "touch down" dio where the aircraft has literally just landed.
If not just having the aircraft at rest, in which nothing hangs loose and the rbf tags will be in place with the cockpit open.
Decisions decisions.
You'll probably think I'm strange...but I actually prefer the look of the "stubby" nosed Tonka - this long nosed one looks...weird. To me at least - each to their own etc etc.
Still - kudos on hacking everything up - you're braver than me!
Interesting project but I would imagine a lot of work.
How are you planning to do intake tunnels?, its a shame the kit provides not trunking.
I've got a large GR4 project slowly progressing on the bench, so I maybe able to provide some hints on missing details on the IDS kit
Shaun.
Edited by Shaun
Hi,
Nice work, be aware that that funny resin stuff is an absolute pig to fill, sand and get a good surface. If you find away around that then let me know.
I took a different route and used plastic card to replace the parts from the conversion - but used them as a master. The nose came from the Revel F2 kit but modified to match the conversion nose.
http://www.britmodeller.com/forums/index.p...c=49015&hl=
The only reason I have stopped is that I am waiting for Aires to release their resin undercarriage bays as the kits ones are very basic. With all the scratch building needed on this one I did not fancy doing the U/C bays as well.
Not sure how much detail you want to go into but if you use the blackbox F3 cockpit the side console layout is not 100% accurate for an F3 (at least not for the final version based on a number of photographs on the web etc).
Will be following with interest.
Regards
Regards
I'm the same with my GR4, I've got the new cockpit and exhusts but I'm waiting for the U/C bays to be released than I can really get cracking.
Shaun.
I could be wrong, but the nose appears to be upside down to my eyes !
Gonna be watching this one.
It Is! I wanted to see what it looked like Hee hee.
I can assure you that I wont make that mistake when it comes to glue it! (I hope) measure twice, cut once, thats what my dad always told me!
Not really much of an update, just to say that after what seemed like an age of cutting, sawing filing and sanding, im left with this
What you are looking at is the replacement fuselage underside with the recesses for the skyflash missiles (adapted aim120's in this build btw). In addition the fuselage extension plug was made to fit.
This is all obviously before filler and is as close as i can make it given the state of the resin, which brings me on to the next point.
When I bought this kit off Meidert some two years or more ago, he was at pains to point out that the rubber moulds had reached the end of their life and as such he wasn't prepared to guarantee the quality of the resin parts. With that caviat, I knew possibly what iIwas getting in to until now.
Having completed the fuselage cutting it was time to start on the cockpit. The kit provided new panels bulkheads and ejection seat heads. On close inspection, my eyesight allowing, I noted the following.
rear cockpit bulkhead has a chunk missing out of the top curve of the panel.
there are a few pits where they shouldn't be on the centre bulkhead and crt panels. nothing major though,
the big problem in my opinion is the front panel I feel it is unuseable and but for the tiny difference between the GR and the F3 I think I will be using the Kit part.
It sounds like Im having a go at Meinderts work, Far from it! he was brave nough to put the work into this conversion and by heck I will do my utmost to get the best out of what I have got, as, lets face it , it is the only game in town.
I want to complete the build as a tribute to the F3 which is finished finally in March this year.
Oh and I stuck the huge fin together.!
Hi Blacktjet, Im not entirely sure what you mean in terms of the starting point for the extension.
I appreciate that the conversion may not be completely accurate, however if you were to trace a line right round the fuselage from the vertical cuts, it would pass roughly through the hinge points. The extension at the back of the canopy is to allow the resin a little "purchase".
Is that the issue you are referring to?
Hi, hope these pictures help. If you increase the spine at the point that the conversion prvides, the plan shape will be wrong. Also the extension should give the spine a slight 'kink' in side profile.
