Giorgio N Posted April 17, 2011 Author Share Posted April 17, 2011 (edited) 10.30 PM, GMT + 1, and the Crusader is finally finished !!!!!! I've had to take some shortcuts to finish it in time for the end of the GB, among these I did not add any load under the wing. This meant adding a coule of bits to simulate the hooks on the pylons... took less time than painting the rocket launchers I wanted to use.. The pylons on the side of the fuselage are butt-joined and it was clear that they could not stand the weight of the 4 zuni packs, so I glued a steel rod on both pylons, passing through the fuselage: Another shortcut was the use of the kit seat. This kind of represents an MB Mk.7 as used on the F-8J, however my plane should have had a Mk.5. As I could not find any, I used the kit one. This has the ejection handles very thick and should be replaced... next time ! I only added a few belts to make the area look busy. One last annoyance was the decal provided by academy for the windscreen sealant. This is too big, so I had to cut it in many parts and add them separately in order to locate the sealant strips in the right place. Very annoying ! And here it is in all its glory ! As I had no time left, I did not weather the model as I wanted. I'll do this whenever I have time to play with it. This means that the model is not really completed, as I want to add some dirt, the underwing rocket launchers and a new seat. However it's complete enough to deserve its place in the gallery of the Group Build ! Did I enjoy it ? Yes and no. Yes because its a great kit and a beautiful subject. No because I had several problems with the paint and decals. However the finished model looks good enough, at least from 4-5 feet. And again shows how beautiful the Crusader is, even if some features are quite weird, as the variable incidence wing and the arrangement of the 4 rocket launchers on the fuselage... Next one will be done from this box: A very old Heller box, bought last year for a fiver. To be used for a conversion in one of the earlier versions.... I can see more crusaders being built in the future !!!!! Edited April 17, 2011 by Giorgio N 1 Link to comment Share on other sites More sharing options...
Muller Posted April 18, 2011 Share Posted April 18, 2011 Lovely job on that! And you're right, COOL markings! Link to comment Share on other sites More sharing options...
jimbuna Posted April 18, 2011 Share Posted April 18, 2011 Very very nice indeed....well worth the effort I suspect. Link to comment Share on other sites More sharing options...
Giorgio N Posted April 18, 2011 Author Share Posted April 18, 2011 Thanks for your comments, glad you like it. Looking at it now from a couple of metres it looks good, a great example of the '60s colourful USN schemes. And talking about cool markings, this is the one I'd like to build next: http://www.aircraftprofiles.dk/?page_id=49...amp;gallery=238 Link to comment Share on other sites More sharing options...
smuts Posted April 18, 2011 Share Posted April 18, 2011 nice work & great to see the F8 in Death Angels colours Andy. Link to comment Share on other sites More sharing options...
Metallicus Posted April 18, 2011 Share Posted April 18, 2011 Great Build! Well Done!! Link to comment Share on other sites More sharing options...
