Honeybee Posted January 3, 2011 Posted January 3, 2011 Hi all Have decided to do a white/black one, RAF of course. Not sure on the scale though. Mmmm, decisions decisions. Regards Paul
Honeybee Posted January 14, 2011 Author Posted January 14, 2011 Hi I have just located 2 White Ensign detail sets I'd forgotton I'd purchased, 3 months ago. I'll be building TW900 EM F of 115 Squadron. Don't normally have a lot of luck with etch so fingers crossed. I also have a few left over parts from a Hasegawa Lanc I'll try to incorporate. I don't think the tail turret is right in the drawing, I think it should be a FN82 with twin .5inch. Regards Paul
Antony Robertson Posted January 15, 2011 Posted January 15, 2011 Ooh, another white one!! They've got to be the best looking Lancasters Antony
Honeybee Posted January 16, 2011 Author Posted January 16, 2011 Hi all Piccie of bits to prove I'm moving forward with the idea, Regards Paul
smyfe Posted January 16, 2011 Posted January 16, 2011 (edited) C'mon Paul, I'm too fat to sit on the edge of my chair for too long. Looking forward to this. Mick Edited January 16, 2011 by smyfe
Honeybee Posted January 16, 2011 Author Posted January 16, 2011 Hi Mick sorry mate, I build at a snails pace, so I'm told. Still to get a tail turret and some paddle bladed props so couldn't finish it if I tried harder, Regards Paul
Honeybee Posted January 18, 2011 Author Posted January 18, 2011 Hi all I have started. I have also remembered I have some resin treaded wheels supplied by a friend. I'd put them away and forgotton them. Having decided to use the etch brass I've now decided to only use the easy bits. I took the pilots seat of the sprue and bent it. First part first fold, ollox. Regards Paul
Honeybee Posted January 27, 2011 Author Posted January 27, 2011 Hi all a bit of spare time today so a little update. Acouple of bits I'll need, spare paddle props from Hurrinuts Revell Lanc Seeing as I naffed up the etch seat I took to head armour off it and ased on the kit seat. I painted the interior Teerschwartz by Revell. Wheel wells. Note, this was the second one I did and learned from the first to remove the two sections at the rear to aid fitting. This was the first and as you can see it doesn't fit right. It'll be fine once the kit is done as no one will see it but I expect a better job one the second well. Regards Paul
Honeybee Posted February 1, 2011 Author Posted February 1, 2011 Hi all just a small update. We can see I have added the nacelles to the wings. The top picture shows the wing to nacelle joint as glued, no filler at all. I think a good sand to even out the level is all I'll need. As usual the rear neath had to have Milliput added to bridge the large gap, seen best on the wing at the left of the bottom picture. There is always a large gap here. On the wing at the right you can see that I have also had to fill a gap along the whole length of the necelle. As with the other wing I used milliput for the rear section but tubed plastic putty for the forward section. The difference can be seen as Milliput is green and the putty is white. I have not sanded down either in this picture, they were both smoothed with a damp ear bud. Also note the difference in the finish of the two outer nacelles. The one on the left has only been sanded. The one on the right has also been sanded to the same level but then I coated it with liquid poly, my favourite way to buff up the finish. Takes two seconds to do and only a few minutes to dry and saves having to use progressivly finer pieces of wet and dry Regards Paul
Martian Posted February 1, 2011 Posted February 1, 2011 Coming along well. Faster than mine at any rate! Martin
Honeybee Posted February 14, 2011 Author Posted February 14, 2011 Hi all Got cracking on after deciding all that etch was solwing me down. Starboard lower wing not painted yet but gives some idea of finished item. Looks kinda plain but weathering will take care of that later in the build Regards Paul
canberraman Posted February 14, 2011 Posted February 14, 2011 Looks lovely Paul, that white scheme will be really striking. Keep up the good work! Mark Hi allGot cracking on after deciding all that etch was solwing me down. Starboard lower wing not painted yet but gives some idea of finished item. Looks kinda plain but weathering will take care of that later in the build Regards Paul
woody37 Posted February 14, 2011 Posted February 14, 2011 Really like the white schemes and your doing it alot of justice. Looking forward to seeing more pics ! Neil
smyfe Posted February 14, 2011 Posted February 14, 2011 Hi Paul, most impressive so far, really like the white scheme. You have done far better with PE than i ever managed. Mick
Antony Robertson Posted February 14, 2011 Posted February 14, 2011 Looking great, can't wait to see this one finished Antony
Honeybee Posted February 19, 2011 Author Posted February 19, 2011 Hi all slow it may be but moving along it is. Not sure about the walkway markings but am sure that this Lanc has 84" roundels on the wing instead of the WW2 100". Wings and tailplanes not glued in place yet. Will be buying some more bits for this build at T'uddersfield show tomorrow. I like the difference in the cowlings, makes it more interesting, Regards Paul
woody37 Posted February 20, 2011 Posted February 20, 2011 Another 'different' Lanc, Very inspiring, great progress Paul.
Roland Pulfrew Posted February 20, 2011 Posted February 20, 2011 Ooh! That's looking good, and different!!
Honeybee Posted February 24, 2011 Author Posted February 24, 2011 Hi all had a go at the weathering. Mmmm, not sure. I might need some touching up here and there. After I had purchased and placed the squadron codes I realized that the 'M' is the wrong style, no worries I can sort that. I've tried to find a piccie of EM F on the t'interweb to show the state of the real a/c but can't. There are some in June 2008 issue of Model Aircraft Monthly but not sure of copyright so I won't scan and post them. Fair to say it's not spot on but is good enough for me so far. Rear of fuselage to weather yet, Regards Paul
Honeybee Posted March 6, 2011 Author Posted March 6, 2011 Hi Just keeping things ticking over, here's part of todays effort All painted now along with the main legs so will attach later today, Regards Paul
rowmk9 Posted March 6, 2011 Posted March 6, 2011 I think it looks great. The staining is heavy but consistent with the staining seen in archive pics. Love the detail on the main legs
