benskipper Posted April 25, 2011 Author Share Posted April 25, 2011 You Sir have a lot more patience than I do. very nice indeed.Pete Cheers Pete, For some reason when I get the bit between my teeth on a project it's head down and off I go, worry not the next couple of builds will defo be OOB... Link to comment Share on other sites More sharing options...
benskipper Posted April 26, 2011 Author Share Posted April 26, 2011 Very nice, my Tamiya original Chally 1 feels so inadequate now lol Chap thank you for looking, but it has to be said your chally is top dog, it captures the original BAOR issue spot on, the weathering is bang on! I was looking for an original Tamiya Mk1 to replicate the one I 'bent' (long story), but found this one and decided to do it as a KRH Op Agricola special, that's where it started to go a little pear shapped and I was off on one. Link to comment Share on other sites More sharing options...
bruce3371 Posted April 26, 2011 Share Posted April 26, 2011 Chap thank you for looking, but it has to be said your chally is top dog, it captures the original BAOR issue spot on, the weathering is bang on! I was looking for an original Tamiya Mk1 to replicate the one I 'bent' (long story), but found this one and decided to do it as a KRH Op Agricola special, that's where it started to go a little pear shapped and I was off on one. Thanks! But I like the detailing on yours better, I know its a different Mk of chally, so some of the details are probably different anyway, but you seem to have such a great eye for detail. Mine was built a loooong time ago, when the original Tamiya chally was still brand new, and I was still cutting my teeth on the bigger 1:35 scale (having previously only built the old Matchbox and Airfix 1:72 aircraft and 1:76 military ranges). To this day, I still refuse to buy aftermarket add-ons, preferring to use household items to detail my models with. Link to comment Share on other sites More sharing options...
benskipper Posted April 30, 2011 Author Share Posted April 30, 2011 (edited) Well that's it finished construction wise. The front has been 'skippered' with the addition of some homemade light shields, power leads etc as well a couple of Eduard PE parts, the resin extinguishers are from AA and their fantasic quality, as per the norm, they set this off a little... ...the idler wheel adjusting nut was removed and a 2mm self pressed version made up. This is simple to do, just find an allen bolt with the desired size hex, then heat some spruce and when soft push it in, leave for 10 seconds and hey presto a nut! The driver hatch has recieved the handles and opening latch... ...the main gun has recieved it's PE and a bit of masking tape... ..top tip if your adding strapping to PE do it, if possible whilst the PE is still on the fret, makes life easier in the long run. The gun is molded so that a NASTY seam line runs veritacally through the thermal sleeve reinforcer, but some time with 1000grit wet 'n' dry sorts that out nicley... ...next the turret recived it's fire extinguisher... ...and the reinforcing stirp near the TOG sight housing was trimmed up... ...next the chain for the rear tools on the turret was replaced with a finer version and the antenna added, the best antenna's are from the very handy sandwich bag ties... ...the wheel set are completed with some minor wear and tear, not all have been butchered, but it's worth while rubbing around the tyre to smooth them off... ...now the model sans front armour, which will like the gun, turret, tow bar and gimpy be painted separately... ...I'm going to have a bash at this pre shading lark and see what the fuss is all about. Stay tuned... Edited April 30, 2011 by benskipper Link to comment Share on other sites More sharing options...
bruce3371 Posted April 30, 2011 Share Posted April 30, 2011 Nice work, definately looking forward to seeing it painted Link to comment Share on other sites More sharing options...
Troffa Posted April 30, 2011 Share Posted April 30, 2011 Absolutely cracking build- and great build thread as well- plenty of great pictures and tips- ideal for those of us with a couple of Challengers in the stash.. Thanks for sharing! Link to comment Share on other sites More sharing options...
smuts Posted May 1, 2011 Share Posted May 1, 2011 very nice work Andy Link to comment Share on other sites More sharing options...
benskipper Posted May 1, 2011 Author Share Posted May 1, 2011 (edited) Well that's the priming completed. I use Halfords Grey Primer as it hides a multitude of sins . Next I had a bash at the pre-shade lark...an hour later and it was done. I used Citadel Chaos Black thinned to milk like consistancy to avoid cacking up the needle, something Citadel paint is very good at if its not thinned, and it did the job extremely well... ..next job was to paint the armour inserts on the hull front, these, for some reason remained desert yellow (Tamiya XF59 is the best colour match here), on earlier armour the desert yellow had a bit more yellow to it, though that said some Buff coloured vehicles were about on Op Granby, so I reckon it was luck of the POL stores draw when it came to respray. Anyhow I used very LITTLE air and very LITTLE paint on these, and took my time, as opposed to my usual go at it like a fiddlers elbow approach. You know what what it worked! These two pieces took 10 minutes, so gawd only knows how long the rest will take? To really make painting really interesting the remaining areas are green, so roll out the low tack masking stuff... Edited May 1, 2011 by benskipper Link to comment Share on other sites More sharing options...
Stormbringer Posted May 1, 2011 Share Posted May 1, 2011 You wouldn't be after modelling a particular Chally from Kosovo would you? Using Echelon decals? Pete Link to comment Share on other sites More sharing options...
benskipper Posted May 1, 2011 Author Share Posted May 1, 2011 Why yes, with a hint of 'skipper' thrown in for good measure... Link to comment Share on other sites More sharing options...
rookie Posted May 2, 2011 Share Posted May 2, 2011 Looking great. Link to comment Share on other sites More sharing options...
Ian Posted May 5, 2011 Share Posted May 5, 2011 Slow painting... another dark art it's taken me years to master (sort-of !!) Ian Link to comment Share on other sites More sharing options...
benskipper Posted May 8, 2011 Author Share Posted May 8, 2011 (edited) Well the 'basic' paints cheme and camo are now completed!! After preshading I applied a coast of Tamiya XF61 dark green as a base coat, as it was rather too dark I mixed it with some XF59 desert yellow to produce a nice light green. after 3 hours with a fine airbursh this is what she looked like... ...next was the camo streaks. these were XF69 Nato Black. Note the lack of camo on the applique armour, this was normally taken out of stores and either painted green or left sand... ...next off the whole body is to sealed in a semi gloss varnish to protect the paint work. Edited May 8, 2011 by benskipper Link to comment Share on other sites More sharing options...
bruce3371 Posted May 8, 2011 Share Posted May 8, 2011 Looking better and better, I think it should be made compulsory for all armour modellers to have at least 1 Chally in their collection! Link to comment Share on other sites More sharing options...
jimbuna Posted May 8, 2011 Share Posted May 8, 2011 This is looking really very good....love the Challenger. Link to comment Share on other sites More sharing options...
Ian Posted May 8, 2011 Share Posted May 8, 2011 I think it should be made compulsory for all armour modellers to have at least 1 Chally in their collection! Not got the money, not got the interest, not got the room, not got the money (mentioned twice for emphasis !) Ian Link to comment Share on other sites More sharing options...
Kallisti Posted May 15, 2011 Share Posted May 15, 2011 (edited) Been following your build as I'm currently also building the same kit, however I'm not going quite so detailed as you - then again I've never driven one I do have one question though, the squarish grille in this picture (is it the engine exhaust?): this is different from the part in my kit. Where did you come by this? Thanks and keep up the superb work! Edit: ahh, just found them on the A sprue, part 29 which the instructions say is not used. is there any reason you chose to use this instead of the normal part D2? Edited May 15, 2011 by Kallisti Link to comment Share on other sites More sharing options...
benskipper Posted May 15, 2011 Author Share Posted May 15, 2011 (edited) Been following your build as I'm currently also building the same kit, however I'm not going quite so detailed as you - then again I've never driven one I do have one question though, the squarish grille in this picture (is it the engine exhaust?): this is different from the part in my kit. Where did you come by this? Thanks and keep up the superb work! Edit: ahh, just found them on the A sprue, part 29 which the instructions say is not used. is there any reason you chose to use this instead of the normal part D2? Cherrs bloke. The Mk3 exhaust vent was placed facing upwards to make its presence more obvious, it also dispersed heat more efficiently lowering the IR signature significantly. Unfortunately the sidewards directed exhaust shrouds retained a huge amount of heat. There were also several unfortunate accidents with unfamilar troops/civilians touching the vents and roasting their hands. Another added bonus of the upwards facing vent was that when fuel was added to the exhaust to create a smoke shield it actually enveloped the vehicle creating it more efficiently as opposed to the one next to it (loads of comedy moments resulted from this distinct feature of the Mk1). Some Mk1's were retro fitted this pattern vent prior to full Mk 3 fit so you could use it on an IFOR/SFOR Mk1 and it would look 'right'. Hope this helps. Edited May 15, 2011 by benskipper Link to comment Share on other sites More sharing options...
benskipper Posted May 20, 2011 Author Share Posted May 20, 2011 (edited) Ok here's the final pics before I start weathering and adding stuff to her... ...the barrel jacket is a mix of a range of vallejo colours ,airbrushed on. I watered these down with deionised water by 15% and then selaed it with a satin finish followd by a 50/50 mix of humbrol matt thinner and white spirit... ...the scratched paintwork is merely Tamiya XF59 which has been applied by dipping the edge of plasticard in the paint and pressing it against the side, the other scrathes have been applied using that black packing foam you often get with delicate stuff.. ...the chains were painted black and then given a few washes of raw umber before having the outer areas rubbed with a HB pencil... ...all of the periscopes were rendered using a mirrored card from the local art shop. the red tinge is the anti flash/laser coating that is applied to prevent the crew being blinded by said light sources, the wipers are all from the Eduard PE Kit... ...finally the tracks. These are the kit issued sets. First off they were sprayed matt black then the inner surfaces were sprayed Rover Aluminium, these was over sprayed with JSDF Brown and a final rinse of matt black heavily thinned. The whole lot was then sealed with matt varnish. To attach these I removed the front idler and threaded the track through the drive sprocket and around the side armour supports. The ends were sealed with a low temp soldering iron and pressed flat with a finger. Then the front idler was replaced and the end road wheels pushed into place to give the track tension followed by the remaining 4 wheels. Completed build here Edited May 30, 2011 by benskipper 1 Link to comment Share on other sites More sharing options...
jimbuna Posted May 21, 2011 Share Posted May 21, 2011 Looking fantastic. Link to comment Share on other sites More sharing options...
bruce3371 Posted May 21, 2011 Share Posted May 21, 2011 Yes, definately puts my own feeble efforts to shame lol Seriously, beautifull job so far, can't wait to see the final results Link to comment Share on other sites More sharing options...
Harvey Pincis Posted January 30, 2012 Share Posted January 30, 2012 Ok here's the final pics before I start weathering and adding stuff to her... ...the barrel jacket is a mix of a range of vallejo colours ,air............................................................ ...finally the tracks. These are the kit issued sets. First off they were sprayed matt black then the inner surfaces were sprayed Rover Aluminium, these was over sprayed with JSDF Brown and a final rinse of matt black heavily thinned. The whole lot was then sealed with matt varnish. To attach these I removed the front idler and threaded the track through the drive sprocket and around the side armour supports. The ends were sealed with a low temp soldering iron and pressed flat with a finger. Then the front idler was replaced and the end road wheels pushed into place to give the track tension followed by the remaining 4 wheels. Completed build here Very nice build indeed. I am about to embark on a Kuwait 1991 version, so all knowledge/experience is useful. Looks like the pre-shading worked very well. Just trying to figure the correct amount of 'weathering' for Granby, i.e. the liberation/how many oil fires were messing things vs how much exhaust must have come out of the grilles. The warrior threw up some smoke - I saw them in Basra, but post Saddam. The Chally is much less known territory for me. Have to complete before 25 Feb! The race is on! Link to comment Share on other sites More sharing options...
Kallisti Posted January 30, 2012 Share Posted January 30, 2012 (edited) This thread was a fantastic inspiration to me as well when I built my Challenger 1 (link in sig). I look forward to seeing yours! I've got a Challenger 2 in the stash that I'm thinking would look great with the bar armour on it... Accurate Armour do a PE set for this but its £65 eek! When my share options get cashed in my might consider it Edited January 30, 2012 by Kallisti Link to comment Share on other sites More sharing options...
benskipper Posted January 31, 2012 Author Share Posted January 31, 2012 (edited) Cheers Kallisti - Here's the final weathered beastie: KFOR Chally Your right about those AA kits eyewateringly expensive!!! Edited January 31, 2012 by benskipper Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted January 31, 2012 Share Posted January 31, 2012 Wonderful work Link to comment Share on other sites More sharing options...
