PaulR Posted December 30, 2010 Share Posted December 30, 2010 Hi all, now I know Sabre wings have been done to death, but I have become confused . . . In short, are the slatted wings in the 1/72 Heller sabre appropriate to make a slatted RAF Sabre F4? Illumination from those less confused than me greatly appreciated! Thanks, Paul Link to comment Share on other sites More sharing options...
Max Headroom Posted December 30, 2010 Share Posted December 30, 2010 I came across this a while ago. http://f-86.tripod.com/wings.html HTH MH Link to comment Share on other sites More sharing options...
James Craik Posted December 30, 2010 Share Posted December 30, 2010 I came across this a while ago.http://f-86.tripod.com/wings.html HTH MH Short answer == yes. Link to comment Share on other sites More sharing options...
Tony Edmundson Posted December 31, 2010 Share Posted December 31, 2010 Hi all,now I know Sabre wings have been done to death, but I have become confused . . . In short, are the slatted wings in the 1/72 Heller sabre appropriate to make a slatted RAF Sabre F4? Illumination from those less confused than me greatly appreciated! Thanks, Paul The Heller wing is a Sabre 6 wing only--a 6-3 wing with slats--unique to the Sabre Mk6 It also has way more sweep than the Fujimi/Academy/Hobbycraft Sabre-- see here at post #5 ; http://www.arcforums.com/forums/air/index....howtopic=184207 Cheers, Tony Link to comment Share on other sites More sharing options...
James Craik Posted December 31, 2010 Share Posted December 31, 2010 (edited) The Heller wing is a Sabre 6 wing only--a 6-3 wing with slats--unique to the Sabre Mk6It also has way more sweep than the Fujimi/Academy/Hobbycraft Sabre-- see here at post #5 ; http://www.arcforums.com/forums/air/index....howtopic=184207 Cheers, Tony Hate to disagree Tony,but if you compare the Heller wing to the Hobbycraft wing you will see that the Heller wing is narrower,and yes the sweep is off a little.What I have done in the past is mate the Heller wing to the Hobbycraft centre section. Edited December 31, 2010 by James Craik Link to comment Share on other sites More sharing options...
James Craik Posted December 31, 2010 Share Posted December 31, 2010 (edited) Hate to disagree Tony,but if you compare the Heller wing to the Hobbycraft wing you will see that the Heller wing is narrower,and yes the sweep is off a little.What I have done in the past is mate the Heller wing to the Hobbycraft centre section. Photo of a Mk4,Fujimi fuslage mated to the Heller wing. Edited December 31, 2010 by James Craik Link to comment Share on other sites More sharing options...
Julien Posted December 31, 2010 Share Posted December 31, 2010 Photo of a Mk4,Fujimi fuslage mated to the Heller wing. me lilkey that one! Julien Link to comment Share on other sites More sharing options...
Tony Edmundson Posted December 31, 2010 Share Posted December 31, 2010 Hate to disagree Tony,but if you compare the Heller wing to the Hobbycraft wing you will see that the Heller wing is narrower,and yes the sweep is off a little.What I have done in the past is mate the Heller wing to the Hobbycraft centre section. You may be on to something, there. I checked my Heller kits and they have molded the ammo door forward of the wing. (raised panel lines of course) Maybe its time I considered my Heller sabres as Mk4 planes with the bloody slats molded closed. Model on gents, Tony Link to comment Share on other sites More sharing options...
James Craik Posted December 31, 2010 Share Posted December 31, 2010 You may be on to something, there. I checked my Heller kits and they have molded the ammo door forward of the wing. (raised panel lines of course)Maybe its time I considered my Heller sabres as Mk4 planes with the bloody slats molded closed. Model on gents, Tony You will have to remove the raised panel just forward of the vertical stab.Heller is the only sabre model that has the two vents on the side of the fuslage. Jim Link to comment Share on other sites More sharing options...
PaulR Posted December 31, 2010 Author Share Posted December 31, 2010 Cheers for all the input gents! My Heller Sabre will therefore emerge in the fullness of time as a 93sqn slatted Mk4 courtesy of Modeldecal . . . Paul Link to comment Share on other sites More sharing options...
