desmojen Posted October 29, 2007 Share Posted October 29, 2007 In a fit of my legendary impulsiveness I just purcased these decals http://www.lemdecal.com/72.056%20page.html Can anyone tell me which is the right type of F-18 to put them on??? Thanks, Jen. Link to comment Share on other sites More sharing options...
ColinR (aka ARC Scotsman) Posted October 29, 2007 Share Posted October 29, 2007 You'll need an F-18A of some description , Hasagawa I guess, but basically any A model hornet would do Link to comment Share on other sites More sharing options...
Stephen Posted October 29, 2007 Share Posted October 29, 2007 (edited) You'll need an F-18A of some description , Hasagawa I guess, but basically any A model hornet would do Ditto. Hasegawa is your best bet. Stephen Edited October 29, 2007 by Stephen Link to comment Share on other sites More sharing options...
Phil @ Flory Models Posted October 29, 2007 Share Posted October 29, 2007 As the others said, it's the 'A' model Hasegawa make a CF-188 Hornet or did, It's the same as the A apart from it has the interrogation light on the port side of the nose. HTH Link to comment Share on other sites More sharing options...
desmojen Posted October 29, 2007 Author Share Posted October 29, 2007 Thanks peeps, I'll start looking around for an A. I'm assuming Hasegawa is the best bet, right? Jen. Link to comment Share on other sites More sharing options...
Phil @ Flory Models Posted October 29, 2007 Share Posted October 29, 2007 Thanks peeps, I'll start looking around for an A. I'm assuming Hasegawa is the best bet, right?Jen. I would say so, Link to comment Share on other sites More sharing options...
Andy Mullen Posted October 29, 2007 Share Posted October 29, 2007 You can also buy the >> Hasegawa F/A-18C #D08 << as this has the same sprues as the A boxing (plus the G sprue for the C version), and seems to be more readily available than the A versions. Link to comment Share on other sites More sharing options...
atdb27 Posted October 29, 2007 Share Posted October 29, 2007 Or even the HB F-18A and it's a bit cheaper (UK that is) Plus you get lots of weapons to hang off of it. No buying extra Hasegawa Weapons sets!!!! Adrian Link to comment Share on other sites More sharing options...
desmojen Posted October 29, 2007 Author Share Posted October 29, 2007 Thanks guys, it's good to know I can use the C. Despite my best efforts I couldn't find a Hasegawa A anywhere. I'll look out for something at Telford though. Hannants had the Hobbyboss as coming soon, is it out yet? Jen. Link to comment Share on other sites More sharing options...
AnonymousER99 Posted October 29, 2007 Share Posted October 29, 2007 As the others said, it's the 'A' modelHasegawa make a CF-188 Hornet or did, It's the same as the A apart from it has the interrogation light on the port side of the nose. HTH Phil Luckily all of the "A" boxings have the searchlight included so getting a canadain boxing need not matter. Cheers Mike Link to comment Share on other sites More sharing options...
Mike V Posted November 29, 2007 Share Posted November 29, 2007 Or even the HB F-18A and it's a bit cheaper (UK that is)Plus you get lots of weapons to hang off of it. No buying extra Hasegawa Weapons sets!!!! Adrian The problem with the Hobby Boss kit is that it has some major shape issues in the canopy (too wide) and the intakes, which are too large and squared. The MLG has some major issues as well, mainly the NLG torque links being scale 3 feet too long! Another problem is that the vertical tails have the early stub bulge RWR fairings. These were only on the FSD and 1st lot production F-18As. The reality is that type tail configuration has not existed since the mid 80s. Most of the stores are inconsistent for an A model and are crude as far as detail/accuracy goes. Hobby Boss just did not do their homework. Over all, the Hasegawa F-18A kit is still much better and a lot more accurate, not to mention has the correct or current vertical tail configuration. The only problem is that they are not as readily available as the HB kits are now. Mike V Link to comment Share on other sites More sharing options...
desmojen Posted November 29, 2007 Author Share Posted November 29, 2007 I should have posted before, Edgar stepped in and supplied me with a Hasegawa F-18A. What a beautiful kit it is too , many many thanks Edgar Jen. Link to comment Share on other sites More sharing options...
