maltadefender Posted October 18, 2010 Share Posted October 18, 2010 Hi all, There aren't many 1/32 vehicles to sit nicely with a WW2 aircraft, so I was wondering whether a blind man would like to see the difference if I went for 1/35 instead? Link to comment Share on other sites More sharing options...
Obi-Jiff Kenobi Posted October 18, 2010 Share Posted October 18, 2010 It probably wouldn't be that noticeable, except to the real rivet-counter. If you had a mix of 1/32 and 1/35 figures it might stick out a bit more, though. Obi-Jiff Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted October 18, 2010 Share Posted October 18, 2010 Although almost 10% linear difference between the scales I think you can usually get away with it - esp figures and vehicles with a/c Iain Link to comment Share on other sites More sharing options...
speedy Posted October 18, 2010 Share Posted October 18, 2010 I've done it with my Tamiya Spitfire. The bicycles are 1/35 items, I just moved them as far away from the model as possible. Link here Steve. Link to comment Share on other sites More sharing options...
Spence Posted October 18, 2010 Share Posted October 18, 2010 Hey fella! If it was me, I wouldn't use 1/35 vehicles alongside 1/32 aircraft unless it was absolutely necessary. Though it may seem as though the difference is minimal, in reality the disparity between 1/32 aircraft and 1/35 vehicles is very noticeable, making either the aircraft look unduly large or the vehicles unduly small... If you are going to mix them up, be very careful; make sure they are kept as far apart as possible because you will notice the difference - trust me. In fact, this is the major reason why I have yet to make a diorama based around an aircraft in 1/32 and why I am considering it, but using a superdetailed Monogram 1/32 vehicle to ensure a consistent appearance across all of the elements... Hope this helps! Spence Link to comment Share on other sites More sharing options...
maltadefender Posted October 18, 2010 Author Share Posted October 18, 2010 Wow! Love that Spit diorama! Thanks for the replies. chaps. I'm going to build my 1/32 Hurricane Trop before the end of the year and would really like either a Tilly or a Matilda tank in Malta 'stone wall' camo with it. I don't have a lot of room to play with on display... I'll think on a little bit! Link to comment Share on other sites More sharing options...
mrvr6 Posted October 18, 2010 Share Posted October 18, 2010 put the vehicles closer to the camera close down the aperture on your camera (higher f number) that will increase the depth of field and keep more in focus Link to comment Share on other sites More sharing options...
