eng Posted August 28, 2010 Share Posted August 28, 2010 Title says it all really. I've had an idea for a wee diorama and although I've got a new Airfix 1/48th Bf109 I want to build one in 1/72 for size reasons. Are the Revell and Airfix boxings one and the same kit? If not which is the better of the 2 (or is there another option!). I'm not looking to spend a fortune but would like something that will provide a relatively trouble free build and be fairly accurate. Thank's for any info any one can supply. Eng Link to comment Share on other sites More sharing options...
The wooksta V2.0 Posted August 28, 2010 Share Posted August 28, 2010 No. Airfix and Revell did their own toolings and, AFAIK, no Airfix kit has ever been issued by Revell. Some Heller ones, yes, but not Airfix. Of the two, the Airfix one was supposed to be quite accurate in outline. Alternates? Hasegawa, ICM (most recent kit released), Heller, Tamiya, Academy. All fairly recent (past 15 years or so) and all to a reasonable standard. Link to comment Share on other sites More sharing options...
rowmk9 Posted August 28, 2010 Share Posted August 28, 2010 I believe the Revell and Airfix offerings are fairly old tools, and have the traits of an old mould design, albeit with a price to match the slightly dated mould tech. I've seen them built into reasonable models however. I'd throw my weight behind the ICM kit. It is a bit fussy and the decals are basically unusable, but the actual model is a good representation of the Emil, or so I've come to understand. If you don't want to fork out for extra decals, then maybe the tamiya kit would be better, but then we're getting into £10 for a small kit range. I doubt you'd have as much trouble building the tamiya kit as the ICM though, and they certainly look good. My two cents worth Link to comment Share on other sites More sharing options...
thx6667 Posted August 28, 2010 Share Posted August 28, 2010 From memory, the Hasegawa 109E has a bit of a banana shaped fuselage, ditto Academy E, though they are both very nicely moulded (more so the H kit given its age). Link to comment Share on other sites More sharing options...
AWFK10 Posted August 28, 2010 Share Posted August 28, 2010 Title says it all really. I've had an idea for a wee diorama and although I've got a new Airfix 1/48th Bf109 I want to build one in 1/72 for size reasons. Are the Revell and Airfix boxings one and the same kit? If not which is the better of the 2 (or is there another option!). I'm not looking to spend a fortune but would like something that will provide a relatively trouble free build and be fairly accurate. Thank's for any info any one can supply. Eng I believe the Revell kit on current release is their own original 1963 tooling, which was never brilliant and has long since been surpassed. Strange they should resurrect it, really, as they own the moulds for the younger and considerably better Matchbox 109E, which hasn't seen the light of day for some time. The Airfix kit dates from 1976 - never built it myself but I believe it's reasonably accurate (certainly more so than the Revell one) but spattered with overscale rivets in the Airfix fashion of the time. I've built the Academy kit and the result looks OK to me, although I think there are supposed to be some issues with the nose - the gun troughs are wrongly located, I think. Link to comment Share on other sites More sharing options...
Test Graham Posted August 29, 2010 Share Posted August 29, 2010 The most accurate 109E is said to be the Tamiya one. Link to comment Share on other sites More sharing options...
Wez Posted August 29, 2010 Share Posted August 29, 2010 The most accurate 109E is said to be the Tamiya one. Are said to be the ICM ones - similar in construction shall we say to the Tamiya but correcting the short length of the Tamiya - much cheaper too. Decals are crap though. Wez Link to comment Share on other sites More sharing options...
Max Headroom Posted August 29, 2010 Share Posted August 29, 2010 I believe the Revell kit on current release is their own original 1963 tooling, which was never brilliant and has long since been surpassed. Strange they should resurrect it, really, as they own the moulds for the younger and considerably better Matchbox 109E, which hasn't seen the light of day for some time. The Airfix kit dates from 1976 - never built it myself but I believe it's reasonably accurate (certainly more so than the Revell one) but spattered with overscale rivets in the Airfix fashion of the time. I've built the Academy kit and the result looks OK to me, although I think there are supposed to be some issues with the nose - the gun troughs are wrongly located, I think. The original Academy rease did have issues with the upper nose area but I believe it was retooled. No idea if he catalogue number changed but since it was retoold early on I would assume hat buying a new model from a retailer would be a safe option. Trevor Link to comment Share on other sites More sharing options...
Chuck1945 Posted August 30, 2010 Share Posted August 30, 2010 The ICM 1/72 Bf 109E is the most accurate. Tamiya is a couple of mm (or a little less) short in the aft fuselage. ICM is a virtual duplicate (the parts are interchangable) of Tamiya except it corrects the fuselage length. Even side by side it is difficult to see the length differences, unless they are lined up on graph paper Choose whichever is less costly from your usual source. Here (USA) ICM is cheaper. Link to comment Share on other sites More sharing options...
