Tornado GR4
Where the wings join they swing by the joints on Tornado's, shall i spray the whole wings before assembly or just the hole ends where they fix into to the overlapping flaps on the top fuselage ? i could then spray the edges in afterwards ?
i've sprayed the top too dark ! wadda i do ? :(
Depends where you are Graham? If you've sprayed the camouflage Grey already (main body slightly lighter Grey) and it's all masked off presumably, just deal with the wrong colour- either directly over spray, or prime again, then over spray.
I'm finding this build quite difficult, i've stopped the 2nd GR4 and concentrating on one.
the side air intakes and corner pieces to the wings don't fit properly so i used plasto to fill the gaps, after painting over with a brush i have some pitted holes that aren't smooth after sanding :(
It would be better if Italeri could have made the fuselage in halves rather than 3 too
