dr_gn Posted April 21, 2010 Share Posted April 21, 2010 About to paint the cockpit of my Bf109-E4. I got some Vallejo RLM-02 equivalent (Grey Green it says on the bottle), which I think should be a dark grey colour, but it looks almost green. Is this correct? Link to comment Share on other sites More sharing options...
andym Posted April 21, 2010 Share Posted April 21, 2010 About to paint the cockpit of my Bf109-E4. I got some Vallejo RLM-02 equivalent (Grey Green it says on the bottle), which I think should be a dark grey colour, but it looks almost green. Is this correct? Yup, 02 is a grey-green colour and the one to go for. The dark grey is RLM-66 used for later cockpits (and perhaps some very late E4's) HTH Andy Link to comment Share on other sites More sharing options...
andym Posted April 21, 2010 Share Posted April 21, 2010 I should also add that the instrument panels should be RLM-66 in an E-4 with 02 cockpit. Andy Link to comment Share on other sites More sharing options...
dr_gn Posted April 21, 2010 Author Share Posted April 21, 2010 I should also add that the instrument panels should be RLM-66 in an E-4 with 02 cockpit.Andy Much appreciated Andy. Link to comment Share on other sites More sharing options...
Deanflyer Posted April 21, 2010 Share Posted April 21, 2010 I should also add that the instrument panels should be RLM-66 in an E-4 with 02 cockpit.Andy True enough, like this: The grey/green used here is the Vallejo RLM02, by the way, so it comes out ok. Cheers, Dean Link to comment Share on other sites More sharing options...
dr_gn Posted April 21, 2010 Author Share Posted April 21, 2010 Dan, Looks fantastic. It's the 1:32 Matchbox E3/4 just like the one I'm building. Care to tell me your painting/wash technique? Cheers, Dr_GN. Link to comment Share on other sites More sharing options...
Deanflyer Posted April 21, 2010 Share Posted April 21, 2010 No problem...even if you DID call me Dan! I used an Eduard PE set which was painted first with Halford's Grey Primer, airbrushed with Vallejo RLM02, and then a coat of Klear. I used a black pastel chalk ground down and mixed with water and washing up liquid to make a wash, which was brushed on and then wiped off when dry, leaving it around the rivets and crevices: I also used some generic cockpit placards to add a bit of interest. Then the whole thing got a coat of matt varnish to seal it all in. The panel was painted with Tamiya acrylic, and a white pastel wash used to bring out the various control markings: A fine brush was used for the switches and buttons, and Klear used on the instrument faces to simulate glass. In the end, the Matchbox kit builds up into a nice result with a lot of scratchbuilding and patience. I also did a full rivet job on mine: Hope that helps, Dean Link to comment Share on other sites More sharing options...
dr_gn Posted April 21, 2010 Author Share Posted April 21, 2010 Dean, Sorry, missed the e out in my rush. Your model looks great. I'm using the same Eduard kit as you, plus another Eduard one for engine and exterior details. Never tried etch kits before, and It's tricky! I was going to try MIG Dark Wash for the details - have you any experience of this? Cheers, Dr_GN. Link to comment Share on other sites More sharing options...
Deanflyer Posted April 21, 2010 Share Posted April 21, 2010 No need to apologise, I was only pulling your leg! I've never used Mig pigments before, so can't offer any advice, sorry. I always make my own or use Promodeller wash. Best of luck with the build, Dean Link to comment Share on other sites More sharing options...
dr_gn Posted April 22, 2010 Author Share Posted April 22, 2010 (edited) No need to apologise, I was only pulling your leg!I've never used Mig pigments before, so can't offer any advice, sorry. I always make my own or use Promodeller wash. Best of luck with the build, Dean OK, might try Promodeller then - seems safer! BTW, on yours, what are the thin "T" shaped bits sticking up from the instrument panel lights? Here's my progress so far: Cheers, Edited April 22, 2010 by dr_gn Link to comment Share on other sites More sharing options...
tango98 Posted April 22, 2010 Share Posted April 22, 2010 Hi Garth, Regarding the correct shade of 02: In reality, even the RLM could not guarantee uniformity of the colour of 02 between the batches produced by the many paint manufacturers supplying paint to both the aircraft companies and the Luftwaffe. Because this uniformity could not be guaranteed, between late 1940 and the autumn of 1944, the Technical Office of the RLM issued a number of advisory letters essentially stating that this lack of uniformity was of no importance to interior painting and was thus no reason for complaint. Oddly enough and although it was approved for use as an exterior camouflage colour (Bf 109E, early 109F etc), not one of these advisory letters mentions exterior use! As far as model paints go, 02 produced by Gunze, Xtracrylics, Vallejo Model Colour and Model Air are quite acceptable. However, those produced by Humbrol & Tamiya require considerable lightening to bring them into a range matching samples of the real 02. However, and just like ‘scale effect’ and ‘wear & tear/weathering’ it really comes down to the individual modeller’s preference so, if your completed subject looks right to your interpretation of how the original appeared then be happy with your decision. HTH Dave Link to comment Share on other sites More sharing options...
dr_gn Posted April 22, 2010 Author Share Posted April 22, 2010 Hi Garth,Regarding the correct shade of 02: In reality, even the RLM could not guarantee uniformity of the colour of 02 between the batches produced by the many paint manufacturers supplying paint to both the aircraft companies and the Luftwaffe. Because this uniformity could not be guaranteed, between late 1940 and the autumn of 1944, the Technical Office of the RLM issued a number of advisory letters essentially stating that this lack of uniformity was of no importance to interior painting and was thus no reason for complaint. Oddly enough and although it was approved for use as an exterior camouflage colour (Bf 109E, early 109F etc), not one of these advisory letters mentions exterior use! As far as model paints go, 02 produced by Gunze, Xtracrylics, Vallejo Model Colour and Model Air are quite acceptable. However, those produced by Humbrol & Tamiya require considerable lightening to bring them into a range matching samples of the real 02. However, and just like ‘scale effect’ and ‘wear & tear/weathering’ it really comes down to the individual modeller’s preference so, if your completed subject looks right to your interpretation of how the original appeared then be happy with your decision. HTH Dave Thank you Dave, One of the reasons I asked was that in Lynn Ritger's book, there appears to be a bit of a confusing caption to one of the 'walkaround' pics. No problem though. BTW you'll be pleased to see I took your advice and used the Matchbox seat! Cheers, Garth. Link to comment Share on other sites More sharing options...
dr_gn Posted April 23, 2010 Author Share Posted April 23, 2010 Dean, I just sprayed the cockpit, and to me it looks totally wrong. It looks brown, not green. The paint I'm using is Vallejo Air Lt. Grey Green RLM2 - this is obviously not the same as what you used. Could you give me the serial number of the paint? mines 71044. Cheers, Garth. Link to comment Share on other sites More sharing options...
Master Zen Posted April 24, 2010 Share Posted April 24, 2010 (edited) I just sprayed Vallejo RLM02 and I agree, it does look brownish. But it might just be the lighting... Or it could just be that it was too light a coat. If you put a drop of 71044 on paper, it certainly looks green. Edited April 24, 2010 by Master Zen Link to comment Share on other sites More sharing options...
dr_gn Posted April 24, 2010 Author Share Posted April 24, 2010 I just sprayed Vallejo RLM02 and I agree, it does look brownish. But it might just be the lighting...Or it could just be that it was too light a coat. If you put a drop of 71044 on paper, it certainly looks green. Now it's dry, it looks green again! Looks green in the bottle Looks brown when sprayed and wet Looks green when dry. I even took the nozzle off the bottle top to check it was mixed - same deal - brown! I'm confused, but at least the colour appears to be OK. Cheers. Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted October 3, 2010 Share Posted October 3, 2010 In need of some Acrylic RLM 02 I can get Vallejo paints but is this a specific lufty colour or does it have a code please? Also which colour for the prop please Thanks in advance Link to comment Share on other sites More sharing options...
thx6667 Posted October 3, 2010 Share Posted October 3, 2010 Model Air 71044 is matched to RLM 02. Link to comment Share on other sites More sharing options...
dahut Posted October 4, 2010 Share Posted October 4, 2010 Back in the day I painted more than a few Messie cockpits grey - thats it, just grey. I didnt differentiate and I was happy. Today I would follow the advice given in this thread. Whether I would be happy is a matter of conjecture. Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted October 4, 2010 Share Posted October 4, 2010 (edited) Thanks Jonathan Is Model Air for Airbrushes or is it any good with hairy brushes please? Hi Dahut as a kid we never had any paint for the kits. There is something to be said for it as it saves ones' sanity. Am getting some very confusing results on my searches Doesn't even need to be considered 100% as long as I can feel am in the right part of the spectrum (No Jonathan, I don't mean Skybase, though time spent with the Angels ...*sigh*) Edited October 4, 2010 by walrus Link to comment Share on other sites More sharing options...
Giorgio N Posted October 4, 2010 Share Posted October 4, 2010 If yu're brushing, then the model air are probably thinned too much, as they're meant for airbrushing. To replicate 02 I use vallejo 886 from the standard range. Looks good enough for me and compares decently with other manufacturers interpretation. Link to comment Share on other sites More sharing options...
thx6667 Posted October 4, 2010 Share Posted October 4, 2010 Ditto Giorgio's sugestion, 886. Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted October 4, 2010 Share Posted October 4, 2010 (edited) Thanks both That'll do fer... much appreciate your help chaps! Edited October 4, 2010 by walrus Link to comment Share on other sites More sharing options...
dahut Posted October 5, 2010 Share Posted October 5, 2010 Hi Dahutas a kid we never had any paint for the kits. There is something to be said for it as it saves ones' sanity. There is also something eminently satisfying about loading up an old model with firecrackers, lighting the fuse and tossing the ersatz bomb skyward. Like riding a bike, such things transport one back to the days of youth. Few pleasures will ever be enjoyed like the first ones relished as a lad. Link to comment Share on other sites More sharing options...
dr_gn Posted November 28, 2010 Author Share Posted November 28, 2010 Guys, Forgot to track this topic (still haven't got the hang of keeping track of threads on BM !) Now the model's finished, I can confirm that Vallejo Air "Lt. Grey Green RLM02" Serial No.71044 is the correct colour after all ! It's the wierdest colour; looks grey when viewed next to green, green next to gray and brown in the bottle. Wotever... 1 Link to comment Share on other sites More sharing options...
