Tiger331 Posted April 19, 2010 Share Posted April 19, 2010 I'm currently doing some research prior to emarking on at least one JASDF F-15DJ in an Aggressor colour scheme. Clearly Hasegawa market several F-15DJ kits with these markings though I have read elsewhere that you are actually better off with the original Hasegawa F-15D or the Revell F-15E.....!. I know the latter kit is a newer mould and is, apparently, an easier all round build, but can it really be used as the basis for an accurate F-15DJ ?. Obviously the conformal tanks go but there must be other differences ?....not too worried about jet nozzles, cockpits etc since these will be aftermarket items but not being a Eagle afficionado I would really appreciate advice on the base kit. Thanx Tiger331 Link to comment Share on other sites More sharing options...
AnonymousER99 Posted April 19, 2010 Share Posted April 19, 2010 Tiger The best way to get to a DJ is to either use a Hasegawa DJ kit. If not you can use a B/D kit from Hasegawa or even the E kit from Hasegawa boxing P8. The E boxing is nothing more than a D with "additions" to make it an earl E prototype. You get correct instrument panels for a B/D in the box. Also remember that you need bot vertical stabs to have the small bullet fairings on top of the stabs. The only Hasegawa boxings with both small are the J and DJ boxings if memory serves. You cannot get s DJ out of Revells E model as it is strictly an E with all of the changes to the airframe that the E has. HTH Mike PS Tiger, if you need anymore help I spent a good portion of my young adult life in and around Eagles so I am sure I can answer some questions for you. Link to comment Share on other sites More sharing options...
atdb27 Posted April 19, 2010 Share Posted April 19, 2010 I'm currently doing some research prior to emarking on at least one JASDF F-15DJ in an Aggressor colour scheme. Clearly Hasegawa market several F-15DJ kits with these markings though I have read elsewhere that you are actually better off with the original Hasegawa F-15D or the Revell F-15E.....!. I know the latter kit is a newer mould and is, apparently, an easier all round build, but can it really be used as the basis for an accurate F-15DJ ?. Obviously the conformal tanks go but there must be other differences ?....not too worried about jet nozzles, cockpits etc since these will be aftermarket items but not being a Eagle afficionado I would really appreciate advice on the base kit.Thanx Tiger331 Hi Tiger331, As you know our deal is going on and kit is on it's way. There are up to 7 options in the kit and it does have a diff set of nozzles to use with it. It is as you say a basic F-15D as per suppplied inst + the decs and nozzles to make it a DJ version. Adrian Link to comment Share on other sites More sharing options...
Tiger331 Posted April 19, 2010 Author Share Posted April 19, 2010 TigerThe best way to get to a DJ is to either use a Hasegawa DJ kit. If not you can use a B/D kit from Hasegawa or even the E kit from Hasegawa boxing P8. The E boxing is nothing more than a D with "additions" to make it an earl E prototype. You get correct instrument panels for a B/D in the box. Also remember that you need bot vertical stabs to have the small bullet fairings on top of the stabs. The only Hasegawa boxings with both small are the J and DJ boxings if memory serves. You cannot get s DJ out of Revells E model as it is strictly an E with all of the changes to the airframe that the E has. HTH Mike PS Tiger, if you need anymore help I spent a good portion of my young adult life in and around Eagles so I am sure I can answer some questions for you. Mike, Thanks, you confirmed my suspicions.....I guess you cannot always rely on aftermarket decal manufacturers to provide the right recommendations !.....Two Bobs definitely quote F-15Es in their sheets even though I had an inkling there was more to an E tha just the conformal tanks. I had also picked up the dual small bllet fairings issue but thanks anyway. I have bought the right kits...that's the main thing ! Link to comment Share on other sites More sharing options...
