Erwin Posted October 25, 2010 Share Posted October 25, 2010 (edited) Hi Erwin,The aircraft do not carry the ships insignia because aside from their national markings, the BordfliegerGruppe 196 Arados assigned to the various ships only carried their Verbandkennzeichen (Unit codes) and frequently the seahorse emblem of BflGr.196 on either side of the nose immediately aft of the cowling. The normal complement of Ar 196s on Bismarck was four although if required, an additional two could be carried. The four assigned to Bismarck were 3 x 196 A-2 models and 1 x 196 A-3 model and were all from the 1. Staffel of BflGr.196. The Ar 196 A-2s were: T3+IH W.Nr.052, T3+AK W.Nr.110 and T3+DL W.Nr.123. The Ar 196A-3 was T3+MK W.Nr.150. Thus by simply changing the last two letters of the code you can model any one of Bismarck's four aircraft (externally, A-2 and A-3 were virtually identical having the same armament etc). If you want to do one of Prinz Eugen's three embarked aircraft you could do the 196 A-3 T3+HL from the 3./BflGr.196. HTH Dave Thanks.Very good info. I've had a look at Wingspalette,and found many profiles. http://wp.scn.ru/en/ww2/h/21/2/3 Edited October 25, 2010 by Erwin Link to comment Share on other sites More sharing options...
tango98 Posted October 25, 2010 Share Posted October 25, 2010 Hi Erwin, To answer your questions - my answers in bold type: I've had a look at Wingspalette,and found many profiles. IMO forget these (and Wikipedia too) much of the information is ficticious or poorly researched so whenever possible find a photo of your chosen subject. Anything starting with T3 are Arados onboard ships . Correct ? Generally yes as T3 was the unit code identifier code assigned to BflGr 196 but there are a number of recorded instances when no Verbandkennzeichen were applied to Ar 196s and the aircraft only carried their factory codes - again, a photo is the way to go. Plus not all carried the seahorse insignia ? Correct. So,if I do an Arado with the markings of a ship from the Atlantic without the seahorse I'm OK ? Yes, I have photos of Ar 196s from Gneisenau, Bismarck, Tirpitz and Prinz Eugen carrying the full T3 codes but no seahorse. When you are ready to begin painting your Arado let me know and I'll send you some decent scans. Cheers Dave Link to comment Share on other sites More sharing options...
Erwin Posted October 25, 2010 Share Posted October 25, 2010 (edited) Thank you all for the very good info. I guess my concern wan't needed after all. Plenty of codes to go by even if the decalsheet schouldn't have the seahorse. Well,it looks my project for this GB stands. "1/32 nd Revell Ar 196 on catapult". Edited October 25, 2010 by Erwin Link to comment Share on other sites More sharing options...
keefr22 Posted October 25, 2010 Share Posted October 25, 2010 Well,it looks my project for this GB stands."1/32 nd Revell Ar 196 on catapult". That is going to look mighty impressive!! Keef Link to comment Share on other sites More sharing options...
Erwin Posted October 26, 2010 Share Posted October 26, 2010 (edited) That is going to look mighty impressive!! Keef I should be. But I will concentrate on the Arado first.Hoping the kit hits the shops soon. If I run out of time during the GB then I will have at least finished the plane. Edited October 26, 2010 by Erwin Link to comment Share on other sites More sharing options...
tango98 Posted October 29, 2010 Share Posted October 29, 2010 Having now got things organised timewise regarding my modelling time vs family/home commitments I'm definitely in for this one. My intended entries being a 1/48 Hs293-equipped Do 217 of the II./KG100 and a 1/32 Ar 196. Incidentally, is anyone planning on entering a Bv 222 in this GB? Cheers Dave Link to comment Share on other sites More sharing options...
Alan P Posted November 2, 2010 Share Posted November 2, 2010 Great news Erwin! glad you are very much still aboard! And thanks a lot for the timely info Dave (tango98), glad to have you along too! Al Link to comment Share on other sites More sharing options...
tango98 Posted November 2, 2010 Share Posted November 2, 2010 Thanks Al, glad to be here. Cheers Dave Link to comment Share on other sites More sharing options...
denstore Posted November 2, 2010 Share Posted November 2, 2010 I have figured out a solution for the deck of the KGV, so this will be my contribution. It will be built as she looked during the chase for Bismarck. Link to comment Share on other sites More sharing options...
Phil Reeder Posted November 2, 2010 Share Posted November 2, 2010 Hopefully,I plan to do the Scharnhorst ,using the new Dragon kit,but ,I`ll have to monkey around with it bit,to change it to represent her as she appeared during the Atlantic raiding sortie"Operation Berlin"Also I want to try a new technique I`ve thought of,to simulate a wooden deck. See yer,Phil Link to comment Share on other sites More sharing options...
wkennerley Posted November 13, 2010 Share Posted November 13, 2010 Right it appears the Birsmark is elligible so I have bidded on an Airfix Bismark lets see if I get it, I feel like doing a ship. I will need guidance as to what it should look like for the period though (if the kit is not right) - I may just buiild the Spruance Class John Roger that I have as a practise piece as I have never (as far as I can recall) built a ship kit before. Wayne Link to comment Share on other sites More sharing options...
Alan P Posted November 14, 2010 Share Posted November 14, 2010 (edited) Great list of entries so far (updated): Shar2 - WEM 1/350 L-Class destroyer and HobbyBoss 1/350 Type IXC U-Boat MadNurseGaz - Revell 1/350 Type VIIC U-Boat and Matchbox 1/72 Wellington keefr22 - Airfix 1/400 HMS Montgomery Erwin - Revell 1/32 Arado Ar196 on catapult! JazzyJase - Tamiya 1/48 Swordfish Phil Reeder - Dragon 1/350 Scharnhorst as Gneisenau PHaTNesS - Revell 1/144 Type VIIC U-Boat and Tamiya 1/700 Gneisenau CPNGROATS - Type VIIC U-Boat gcn - U-Boat or Tamiya Swordfish Deacon - Airfix 1/72 Sea Hurricane aurora-7 - Revell 1/72 Flower Class Corvette (started) alex - Airfix 1/72 Sea Hurricane denstore - Tamiya 1/350 KGV smuts - Acc Min 1/48 TBM Avenger tango98 - 1/48 Hs293-equipped Do 217, Revell 1/32 Ar 196 wkennerley - Matchbox 1/700 Bismarck rowmk1 - Revell 1/144 VIIC/41 U-Boat no4mkit - Hasegawa 1/72 Sea Hurricane Mk1 RAF Colonel - Airfix 1/600 Ark Royal and Bismarck Mal - Tamiya 1/700 V&W Class (WAIR/LRE conv) I've updated my entry to the Tamiya Gneisenau in 1/700. The O-Class Destroyer will be a fallback if I have time. Al Edited December 9, 2010 by PHaTNesS Link to comment Share on other sites More sharing options...
Erwin Posted November 15, 2010 Share Posted November 15, 2010 (edited) Great list of entries so far (updated): [*]Erwin - Revell 1/32 Arado Ar196 Should be "...on catapult". If I get it in time.I've ordered it directly from the maker but haven't heard of him anymore. Edited November 20, 2010 by Erwin Link to comment Share on other sites More sharing options...
keefr22 Posted November 15, 2010 Share Posted November 15, 2010 Great list of entries so far (updated):[*]keefr22 - Airfix 1/400 HMS Montgomery Al Got the WEM etched brass for it at Telford over the weekend - scary.....!!! K Link to comment Share on other sites More sharing options...
Phil Reeder Posted November 17, 2010 Share Posted November 17, 2010 Scharnhorst delete ,add Gneisenau(I might change my mind again,I used to be indecisive ,but now I`m not so sure!!) So long ,Phil Link to comment Share on other sites More sharing options...
denstore Posted November 17, 2010 Share Posted November 17, 2010 Scharnhorst delete ,add Gneisenau(I might change my mind again,I used to be indecisive ,but now I`m not so sure!!)So long ,Phil Are you going to wait for the Dragon Gneisenau, or will you convert the Scharnhorst? Link to comment Share on other sites More sharing options...
Phil Reeder Posted November 19, 2010 Share Posted November 19, 2010 Are you going to wait for the Dragon Gneisenau, or will you convert the Scharnhorst? IF I do it ,it will be a kitbash of the Dragon kit,I have some plans of the G`nau during "Operation Berlin",anyway I`ll how the spirit moves me. PRegards ,Phil Link to comment Share on other sites More sharing options...
rowmk9 Posted November 19, 2010 Share Posted November 19, 2010 Can I play? I have a 1/144 scale Type VIIC/41 from Revell that would fit the criteria perfectly methinks! Link to comment Share on other sites More sharing options...
Phil Reeder Posted November 20, 2010 Share Posted November 20, 2010 Can I play? I have a 1/144 scale Type VIIC/41 from Revell that would fit the criteria perfectly methinks! Yep,that would be ideal,welcome aboard! Cheers ,Phil Link to comment Share on other sites More sharing options...
rowmk9 Posted November 20, 2010 Share Posted November 20, 2010 Thanks Phil I'm looking forward to this one now Link to comment Share on other sites More sharing options...
Erwin Posted November 22, 2010 Share Posted November 22, 2010 The catapult kit arrived today. Link to comment Share on other sites More sharing options...
Alan P Posted November 23, 2010 Share Posted November 23, 2010 Great news Erwin! List updated Link to comment Share on other sites More sharing options...
Shar2 Posted November 23, 2010 Share Posted November 23, 2010 Oooh! that looks very nice Erwin, can't wait for mine to arrive now. Link to comment Share on other sites More sharing options...
wkennerley Posted November 23, 2010 Share Posted November 23, 2010 (edited) Have acquired a Matchbox Bismarck so I am in on this GB - Are there any net sources re info on the Bismarck for the period? I assume I can use RB Model 1/700 brass barrels on the Matchbox kit? Wayne Edited November 23, 2010 by wkennerley Link to comment Share on other sites More sharing options...
Shar2 Posted November 23, 2010 Share Posted November 23, 2010 Have acquired a Matchbox Bismarck so I am in on this GB - Are there any net sources re info on the Bismarck for the period?I assume I can use RB Model 1/700 brass barrels on the Matchbox kit? Wayne Try HERE Link to comment Share on other sites More sharing options...
