smuts Posted March 4, 2010 Share Posted March 4, 2010 Hi guys, started this about an hour ago.. Dragons SdKfz 234/3 Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 4, 2010 Share Posted March 4, 2010 nice looking kit looking forward to this Link to comment Share on other sites More sharing options...
smuts Posted March 6, 2010 Author Share Posted March 6, 2010 Hi guys, got goin on it now suspension built & ready for some pre shading.. started on the interior sprayed XF-9 for the floor & engine compartment & masked em off prior to a coat of WEM ARG-01.. Andy. Link to comment Share on other sites More sharing options...
smuts Posted March 7, 2010 Author Share Posted March 7, 2010 Hi guys, interiors building up well just got the seats & shell rack to finish off & spray the vision blocks, fittings on the upper hull... Andy. Link to comment Share on other sites More sharing options...
smuts Posted March 8, 2010 Author Share Posted March 8, 2010 Hi guys, hull/fighting compartment finished just a matt coat & weathering left... Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 8, 2010 Share Posted March 8, 2010 very smart and neat painting of the interior Andy love it Link to comment Share on other sites More sharing options...
Mike Posted March 8, 2010 Share Posted March 8, 2010 I like the shells... they look very pukka. What's the plan for weathering the interior? Link to comment Share on other sites More sharing options...
crookedmouth Posted March 9, 2010 Share Posted March 9, 2010 I assume that this thing was designed as a pushme pullyou? hence the 2 steering wheels? Link to comment Share on other sites More sharing options...
smuts Posted March 10, 2010 Author Share Posted March 10, 2010 Hi guys, matted down & weathered.. I like the shells... they look very pukka. What's the plan for weathering the interior? Mike, I've sponged hull red (primer)on the tread plates & walls then added some X-11 with a sponge to the hull floor /tread plates/transmission, dusted the floor with MiG European dust then Tamiya sets A /D & E in streaks on the walls/seats etc. upper/lower hull together every thing on except the knocky off bits......... I assume that this thing was designed as a pushme pullyou? hence the 2 steering wheels? yeah it could be driven either way, all eight wheels were steerable & the bugger could shift as well 48 mph combat loaded Cyberhobby do a steering set for the 234's so you can position the wheels. the systems still in use on today's multi wheel APC's. Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 12, 2010 Share Posted March 12, 2010 very nice indeed Andy really like the weathering on the interior top job Link to comment Share on other sites More sharing options...
Deon Posted March 12, 2010 Share Posted March 12, 2010 Nice one , look forwards to seing this one when its all done Link to comment Share on other sites More sharing options...
smuts Posted March 13, 2010 Author Share Posted March 13, 2010 Hi guys, started work on the gun about 80% done & test fitted to superstructure, hulls been srayed a light coat of XF-60 enamel.. Ta Andy. Link to comment Share on other sites More sharing options...
smuts Posted March 15, 2010 Author Share Posted March 15, 2010 Hi guys, finished the gun & sprayed XF-60 with the shell basket done in NATO black, added some chips with hull red & silver.. road road wheels sprayed Gunz H410(tyres) & fitted, Dragon's given the option to mix & match tyre type/pattern that was common on 234's... nearly there.. now the fun part tri-colour camo. Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 16, 2010 Share Posted March 16, 2010 looking good I like the different wheels gives it an in combat feel about it Link to comment Share on other sites More sharing options...
smuts Posted March 17, 2010 Author Share Posted March 17, 2010 Hi guys, after lookin for pics of the /3 version on the web & in print I've come to the idea that the vast number were left in just dark yellow, plus after three attempts at a tri colour ended as a complete #uck up & respray I'm goin with a single colour (if this had wings it wouldn't have any panel lines left) any way I've added some tarps to break up the lines & add a bit of colour then given the jerry cans a bit of colour by leaving one grey the others peeling... I'm going to use one of the MiG filters on this from the German set & I'm not sure which one to use I'm sure I heard/read that the best one for the Dk yellow is the brown filter any advice would be great. Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 17, 2010 Share Posted March 17, 2010 Nice work Andy, as regards the MIG filters there is no hard and fast rule which says you must use a certain filter for a specific colour scheme I would suggest you try it out on a scrap model/ bit of card sprayed with the colour you have on the 234 first and experiment with the different filters. Remember that a filter will darken the base colour slightly and there is no way of reversing this. I apply my filters using a wide round brush, dip the brush in the filter then blot off on some tissue etc then brush onto the vehicle and let dry fully before adding any more. Pete Link to comment Share on other sites More sharing options...
smuts Posted March 18, 2010 Author Share Posted March 18, 2010 Hi guys, Thanks Pete for the advice with the filters. started the exhausts sprayed them NATO black the mist coated a very thinned hull red over em... fitted & the tarps painted Aeromaster olivgrun, added some pioneer tools & both MG's... both the MG's are really impressive (Gen2) so I need to source some ammo belts....any idea's. Ta Andy. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted March 18, 2010 Share Posted March 18, 2010 jolly nice, like the tarps very smart Pete Link to comment Share on other sites More sharing options...
T-Tango Posted March 18, 2010 Share Posted March 18, 2010 Very, very good, love the tarps, should look good with the MIG filters on. Link to comment Share on other sites More sharing options...
smuts Posted March 26, 2010 Author Share Posted March 26, 2010 Hi guys, started to give it that lived in look now leaned five 75 mm rounds against the wall on the gunners side & dropped three spent cases on the floor threw two outside two in the basket , added three 50 round drums for the 34 & some potato mashers to ruin some buggers day. Andy.....& Ive snapped that bloody aerial off :shithappens: BTW.. anyone still make ammo belts? Link to comment Share on other sites More sharing options...
daz greenwood Posted March 26, 2010 Share Posted March 26, 2010 Very nice Andy! And IIRC don't Aber or Eduard make ammo belts? Link to comment Share on other sites More sharing options...
Mike Posted March 26, 2010 Share Posted March 26, 2010 I'm might have 1 or 2 belts spare... let me have a look round for 'em Link to comment Share on other sites More sharing options...
Mike Posted March 26, 2010 Share Posted March 26, 2010 I have one... I think it was left over from my sWS Searchlight carrier build Link to comment Share on other sites More sharing options...
Deacon Posted March 29, 2010 Share Posted March 29, 2010 Just run thorugh the thread of this build and it looks great! Well done so far Andy. Deacon Link to comment Share on other sites More sharing options...
NinjabreadMan Posted April 2, 2010 Share Posted April 2, 2010 (edited) I've just gone with a 234/3 aswell, and now having looked at yours im a bit dissapointed, mine will be no where near as well made/finished as yours! Nice little vehicles tho! We could make ourselves a nice armoured car force!! Edited April 2, 2010 by NinjabreadMan Link to comment Share on other sites More sharing options...
