Romeo Alpha Yankee Posted February 3, 2010 Share Posted February 3, 2010 (edited) This is the Fujimi UH-1N kit. Here is the pre start shot. I got this kit a few years ago and it had been started. I was drawn to it by the USAF VIP scheme option (VIP aircraft is one of my collection themes). The other options are a USMC bird and an Italian Navy bird. The cockpit was part started as was the rotor head, so I added a splash of paint to them and finished construction of the cockpit. I added tape belts to the seats. The instrument panel has nice raised detail which I dry brushed to bring out. Since there was no detail on the centre console I rummaged through my decal spares and found a console decal from a trashed Hasegawa UH-1H kit. I glued the cockpit into one of the fuselage halves, I did a test fit on the skids and realised some nose wait might be required so I added some small strips of lead into the nose and under the centre console before closing up the fuselage. I think it give it a more positive sit on the skids. So that is how it sits at the moment. I will concentrate on this one while detailing the MRH90 and how to progress a little faster now since we have about a month to the finish line. Edited February 28, 2010 by TrojanThunder Link to comment Share on other sites More sharing options...
Erwin Posted February 3, 2010 Share Posted February 3, 2010 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 7, 2010 Author Share Posted February 7, 2010 Some progress to report, filling and sanding has commenced along with some further construction. I am finding the fit of this kit is very good The only issue so far is the windscreen. Its fit is not the best so I have added some shims above the cockpit doors to help with the fit. Sanding started... Link to comment Share on other sites More sharing options...
Andrew Posted February 7, 2010 Share Posted February 7, 2010 Great progress, Ray. You've certainly got it together in short order and here's hoping that it continues as well from here. The scheme you've chosen should look very snappy. Cheers, Andrew. Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 9, 2010 Author Share Posted February 9, 2010 Great progress, Ray.You've certainly got it together in short order and here's hoping that it continues as well from here. The scheme you've chosen should look very snappy. Cheers, Andrew. Thanks Andrew, Yes its coming together nicely. Fit is good and not many colours to contend with on the interior. I like there Fujimi kits, first attempt t one and I will have a crack at a few more. I got a couple of F-4s form you that were Fujimi I believe? Next update. Most of external fittings are on and I am getting close to exterior paint. The only thing holding me up there is getting the correct grey for the scheme. Hope to sort that out in the next day or 2. Have got some paint on the main rotor blades and that needs masking and the metallics applied. I have fitted the windscreen and masked the other window openings. I am trying to leave the clear parts off until the last minute so I don't botch them Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 14, 2010 Author Share Posted February 14, 2010 After a lvely sodden weekend I had a chance to progress the Huey. I painted the roof with a Tamiya White Primer rattlecan and masked it up This was followed with some Testors Aircraft grey and Tamiya flat black ...and then the masking was removed. Next I will be masking up the main rotor and and painting the tail rotor, added the clear parts and decalling. Should be finished inthe next few days and then I can go back to the MRH90 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 21, 2010 Author Share Posted February 21, 2010 (edited) Almost finished, As usual at the end of a project I start to rush. I noticed a few places touch ups are required. The Future was still wet in this shot which I assume made the windscreen look fogged up. After touch ups decalling to be done and then it is finished... Edited February 21, 2010 by TrojanThunder Link to comment Share on other sites More sharing options...
faceman Posted February 22, 2010 Share Posted February 22, 2010 Looking good, can almost hear the thwack of the rotors. Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 24, 2010 Author Share Posted February 24, 2010 Well I had to repaint the grey since I had done a touch up and the colour had changed! Something to do with getting to the bottom of the bottle and the hard pigment at the bottom breaking down (even though I had stirred it a lot in previous painting sessions). You may notice a slightly lighter tone to the grey. Anyway I resprayed the grey and gloss coated it. Time for decals and a wash now and it will be finished. Link to comment Share on other sites More sharing options...
Deacon Posted February 27, 2010 Share Posted February 27, 2010 I have an Italeri UH-1N to do so I am watching this build with interest. looking good so far mate. Deacon Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted February 28, 2010 Author Share Posted February 28, 2010 Thanks Deacon! Well I am calling his one finished now. here are the pictures and will also add them the finished builds thread. Link to comment Share on other sites More sharing options...
Erwin Posted February 28, 2010 Share Posted February 28, 2010 A great result. Well done job. Link to comment Share on other sites More sharing options...
Deacon Posted February 28, 2010 Share Posted February 28, 2010 Cracking result mate, well done. Deacon Link to comment Share on other sites More sharing options...
Andrew Posted February 28, 2010 Share Posted February 28, 2010 Very nice indeed, Ray. Congratulations on a fine result; it looks every bit the VIP machine. Cheers, Andrew. Link to comment Share on other sites More sharing options...
faceman Posted March 1, 2010 Share Posted March 1, 2010 Nice one, well done Link to comment Share on other sites More sharing options...
Deon Posted March 1, 2010 Share Posted March 1, 2010 That's a beauty, Ive one half started from many years ago, just waiting for AM blades! Link to comment Share on other sites More sharing options...
