312 T4
nick
Nick, one thing you are missing is the Positive battery terminal needs a rubber boot over it, because if you accidentally touch it to anything else metal, it will short with the chance of a fire, blowing the electrics or worse case senario the battery exploding in your face........ the Negative does not need one as it will be a negative earth return through the chassis, Staggering build BTW .
Tony,
I have an intimate knowledge of what you are referring to in the shape of many years ago, leaning heavily on a ring spanner tighning aforementioned battery nut, that was in contact with watch band, that was in turn in contact with car body, thus spot welding watch strap links together + smell of pork + swearing
I will NEVER do that again
You are, of course correct
Nick
Edited by nick
Absolutely fantastic, the Aluminium sheet trick works a treat, is it just thick Aluminium foil or a sheet, whatever it really works.
My secret weapon
2 quid a pair from Tesco. Ideal thickness, I've tried about twenty different foils and thin sheets, this stuff is just right
Nick
Wow the attention to detail is mind blowing absolutley tremendous build love it
Russ
Here's today's progress.
This is a shot of the BMF over micro balloons to replicate the rough texture I was talking about. It's slightly too coarse but it will do
Getting there now I think, got the sides done
Nick
Edited by nick
Pretty much scratch built the front suspension arms tonight, I'll post some pictures tomorrow
Nick
The front suspension arms started out like this with large fictitous fillets on the underside as you can see here- they had to go!
so all that material carefully removed and tube section formed from the wreckage, made a new fillet from plasticard and punched a turret and top fillet piece from ali sheet
Heres the full size
Edited by nick
Got most of the scratch building on the suspension done today as well as finishing the sheeting. This has turned into a big job!
Thanks for looking
Nick
Edited by nick
Is that Zero paint Nick? Looks nice & smooth! As in fact does the whole build!
Keef
OK I'm impressed recognising paint manufacturers is pretty impressive! yes it is zero. It's the only Ferrari red for me
Nick
Nick
:winkgrin: thanks Nick, it's probably because I've sprayed so much of the stuff myself now! I need to order some Ferrari red from Hiroboy for my 126 which I hope to start soon!
Keef
Just tried microballoons to represent the suede on the steering wheel. Hmm, that didn't work then, back to the drawing board looks OK with the naked eye, but looks like its covered in ping-pong balls close up. SO suggestions then for ultra-fine non-soluble powder to represent suede at 1/12th - answers on a postcard (-:
Nick
Edited by nick
Nick
I saw someone use embossing powder, but when I tried it in 1/24 it looked overscale to me - might work in 1/12? You get in from craft stores. Otherwise what about mixing talc with the paint & try stippling it on?
Keef
Stripped the steering wheel back to bare plastic and will do it properly this time. Had a nice few hours in my element super-detailing the engine bay this afternoon making brackets, connectors and cables, will post some photos tomorrow as sunny evening/new patio set and n (where n>2) of bottles of Amarone and some other nice stuff has has won the day (-:
that's life as the French say
Nick
Edited by nick
Here's my quick snap of some of the connectors and brackets I've been scratch building
Bought a selection of watch repair screws that have some very useful tiny fasteners included. Made an insulated boot for +ve terminal as suggested earlier!
Off to see the Rev Al Green now so must dash(-:
Nick
Edited by nick
Stuff done today:
Jubilee clip for oil header tank
Water hose connecting rear of cylinder banks
Scratch built gear linkage
Scratch built 'thing' above alternator - what the hell is that, anyone know?
Thanks for looking
Nick
Busy day yesterday:
Built and painted all the brakes, including scratch building a pair of brass plates and fixing bolts on top of the rear calipers
Turned a rear light form clear sprue to replace the solid chromed-plastic one supplied
Removed all the non-scale, screw fixing pillars and cut-outs which turned into a big job, then painted the sponsons and finished the skirts with semi-matt black and matt ali BMF
Finished and fitted the exhausts with rub&buff
Wound exhaust retaining springs from 010 lead wire
Made needles for instrument panel, painted and Glue&Glazed
Made a toggle switch for the steering wheel from a micronut and flattened 010 lead wire - bent up here I notice as well as being very dusty!
Stripped the chrome off the wings
Edited by nick
