philbean Posted January 5, 2010 Share Posted January 5, 2010 so.. why do they always print the red dot seperate to the rest of the roundel? Its a complete pig to get it dead centre. Link to comment Share on other sites More sharing options...
Andrew Jones Posted January 5, 2010 Share Posted January 5, 2010 It's much harder to get dead centre if it's printed there out of register Link to comment Share on other sites More sharing options...
Test Graham Posted January 5, 2010 Share Posted January 5, 2010 (edited) I wish they'd print the yellow separate, that seems to be wrong a lot more times than the red. Edited January 5, 2010 by Graham Boak Link to comment Share on other sites More sharing options...
pigsty Posted January 5, 2010 Share Posted January 5, 2010 I don't understand it either. And it's not just RAF roundels - French roundels are often printed with a separate centre, and that means making the blue bit separate. This leads me to think that it can't be because the red phase of the printing process is always more at risk of going off-register. Yet that in turn means that all colours must be equally at risk, which should mean that the outer ring should be printed separately as well! Perhaps, though, it's because it's easier to trim the offending portions on the outside. Says he, specualting wildly. Does any of our decal-printing colleagues know? Link to comment Share on other sites More sharing options...
TonyT Posted January 5, 2010 Share Posted January 5, 2010 (edited) Are you sure it is not simply to do with Copyright, the MOD hold the Copyright on the roundel, by removing the red dot you instantly do not need to buy a royalty licence fee for using it, as it is no longer a RAF roundel....... Edited January 5, 2010 by TonyT Link to comment Share on other sites More sharing options...
Paul @ Parkes682Decals Posted January 5, 2010 Share Posted January 5, 2010 I don't understand it either. And it's not just RAF roundels - French roundels are often printed with a separate centre, and that means making the blue bit separate. This leads me to think that it can't be because the red phase of the printing process is always more at risk of going off-register. Yet that in turn means that all colours must be equally at risk, which should mean that the outer ring should be printed separately as well! Perhaps, though, it's because it's easier to trim the offending portions on the outside.Says he, specualting wildly. Does any of our decal-printing colleagues know? Hi there Well,I print all of mine all together its easier that way saves messing about. Autocad allows you to do it very easy and the are not out of register,there all drawn as circles on different layers as per colour then all i do is hatch them solid.They come razor sharp because they are Vector based software. Hope this helps Paul Parkes682Decals Link to comment Share on other sites More sharing options...
Vingtor Posted January 5, 2010 Share Posted January 5, 2010 For silk screen printing, it's all up to the printing machine. Each colour is printed as a separate layer. If the paper moves (just slightly) between two colours, the decals will be off-register. This is independent of the actual colour. But the more colours on a decal sheet, the greater risk for register problems. The far best silk screen decal printer, in my opinion, is Cartograf. They always print in register. However their prices are high. A very good alternative is Boa, which also prints well in register and is much cheaper. Nils Mathisrud Vingtor Decals www.vingtor.net Link to comment Share on other sites More sharing options...
little-cars Posted January 5, 2010 Share Posted January 5, 2010 From memory it started when the RAF claimed the roundal as trade mark. So you need to license it from them to use it.... You can get away with it for short run stuff as they are not seen as 'commercially viable'. Link to comment Share on other sites More sharing options...
thx6667 Posted January 5, 2010 Share Posted January 5, 2010 Its usually done as a registration thing. Link to comment Share on other sites More sharing options...
pigsty Posted January 5, 2010 Share Posted January 5, 2010 From memory it started when the RAF claimed the roundal as trade mark.So you need to license it from them to use it.... You can get away with it for short run stuff as they are not seen as 'commercially viable'. It can't just be this. As I say, other countries' roundels are treated the same way. Link to comment Share on other sites More sharing options...
