Sign in to follow this
Dustyjack
A Kittyhawk III question
Hi
can anyone tell me please if the profile below is right for the Kittyhawk III FR474 and I can use the 1/32 Hasegawa P-40K kit or was it a long tailed P-40L.
Thanks for read this.
Jack
Hi
Jack
I'm not sure of the accuracy of the profile, but if it is right, then I think you should be using the P-40K/M. A P-40L would be a Kittyhawk Mk.IIA in English money.
Hi
Jack
If the profile is correct then it is an early P-40K (P-40K-1 or P-40K-5). These are SHORT tailed aircraft with the tail fillet. You need a dedicated P-40K kit --OR-- a P-40E with an aftermarket tail conversion.
If you go the P-40M route you will have to shorten the tail.
The P-40L equates to a Kittyhawk Mk II (Merlin engine) which is a different animal altogether.
HTH
JS
Just out of interest, where did you get the profile?
I'm picking its from HERE This also shows the differences in lengths between the various marks of Kittyhawks quite well. This Page might also have some useful shots.
Steve
Edited by stevehnz
Many thanks.
I somehow managed to miss the fact that there was a second page to the Imps article!
Hi Chaps
Many thanks for your help. I have the P-40K kit already so that part isn't a problem and yes Steve your right as to where I got the profile from, all I have to do now is get Christmas out of the way and I can start building.
Many thanks
Jack
Hi Chaps
Many thanks
Jack
Hi Jack ,
The Markings and serial are correct BUT you need a long fuselage variant for this A/C
Long Fuselage K10/15 serials started from FR414. P40L Kittyhawk IIA serials were FS400-499
Disregard any other info you may read about there being a batch of OF RAF P40L being designated Kittyhawk MKIII.
This is an error which has been compounded by lack of original research by some Authors.
Terry McGrady
Edited by Terry McGrady
Hi Terry
That would figure and the other scheme I fancied was DB-H, EV412 but now I've learnt that its a Model E and not a Model K, I'm not having much luck with a colour scheme for this bird, I'll have to keep digging.
Jack
Edited by Dustyjack
Hi Terry
Jack
3 Sqn RAAF used Kittyhawk IIIs. A question on Aussie Modeller International may get some schemes.
Hi Terry
Jack
Hi Jack,
DB-H EV421 of 2 SAAF was indeed a Kittyhawk IA , but as it was a late model E it looked like an P40K -1/5. Desert camo as well so you can certainly do that A/C. The late Model P40E / KittyhawkIA was essentially a K-I airframe with an P40E engine.
Serials commenced at EV315 and ( with gaps) Finished at EV431
PM me and I'll send you an interesting photo.
Terry McGrady
Edited by Etiennedup
fault
