Matchbox 1:32 Spitfire Rebuild
dr_gn
Here’s an old model of mine: a Matchbox 1:32 Spitfire built about 25 years ago. It’s seen some action as you can see. I’ve decided to repair it and use it for some much needed airbrush practice:
It needed a load of araldite to piece it together (cyano didn’t work for some reason), and a shed load of filler and filler-primer. Once smoothed down, I tried re-scribing panel lines in the filler, but it just crumbled (I tried plastic filler and car body filler, scalpel blades, scribers…all sorts):
So I decided to fill all panel lines, and I’m going to draw them on in pencil after painting and decalling, it will be the lesser of two evils. I intend to give it a coat of satin or matt varnish to give some ‘bite’ for the pencil, and use some stainless Hasegawa templates and a S.A.M. steel rule for a guide, followed by satin varnish and weathering.
I’m waiting for some spare parts to arrive (cannon, prop blade, decals etc), so in the meantime I drilled out the exhaust stubs, made a new bearing/housing for the spinner, and a stand out of scrap aluminium and Perspex for when it’s finished:
That’s progress to date. Any advice on drawing pencil panel lines appreciated!
Edited by dr_gn
  • 1 month later...
Here are a few progress pictures:
Scratchbuilt seatbelts (from the Britmodeller Modelling Tips section!)
Home made perspex lights tinted with Food colouring/Klear (to replace the solid plastic originals). Next time I will use coloured perspex and save myself a shed load of hassle!
And a scratchbuilt gunsight to busy up the cockpit a bit more.
I realise most of the above are not strictly accurate, but what the hell: it's all good practice, and the model was a scrapper anyway!
Edited by dr_gn
I don't have the instrument decal (and it's not complete anyway), so I thought I'd try printing a flight sim Spitfire panel out to scale to see what it would look like. Most of it's obscured by the gunsight anyway, so I think with a bit of careful PaintshopPro editing and a bit better cutting out, it will look fine:
Anyone any other ideas for making instruments?
Very slow progress!
Propeller is repaired & finished, windscreen fitted & masked (still waiting for PVA to set).
Gunsight fixed in place.
Instruemnt panel printout edited and EvoStuck to dash panel.
Yellow & Sky areas airbrushed ready for masking.
Crazy experimental masking:
Blu-Tac/Tamiya masking tape/paper/bog roll.
With the Blu-Tac, I'm hoping it will give a very fine feathered edge without it being too obvious. My airbrush is easily capable of a feathered line of the correct thickness, but I am not:
I decided to have the yellow wing leading edges, and I've painted and masked the fuselage band so that it will be a perfect colour match for the spinner.
The much vaunted IPMS Stockholm Paint guide is absolute crap by the way. I used their recommended Tamiya paints on a test piece, and it's all wrong. I have ended up mixing my own greys to get it anything like.
Got a Revell Avro RJ85 for Christmas. That is basically one colour: white, so no problem there hopefully!
reckon you'll have this done before 2010? Its looking good masked up and ready, I tried this a few months ago and c@cked it up a treat, but that was me, not the tools or masking's fault!
Doubt it: It'll be the pencil-drawn panel lines that will take it into 2010 I reckon! That's if I get that far...if the paint isn't much good I'll just bin it anyway. At least I'll have learned a few new tricks.
OK, so on my Spitfire rebuild I applied a coat of Klear after painting, followed by the decals (using Microsol). Everything looked great, so I overcoated with more Klear ready for weathering.
This morning the dreaded silvering has appeared DAMMIT!
What can I do? Does matt varnish help?
Any help gratefully accepted!
(This help request repeated on Tools and Tips Forum)
OK it wins.
Anyone else know what it's like to be a perfectionist even when you know you are one of those people incapable of ever getting anything perfect?
I'm leaving it for a few weeks: it's put up a real fight so far, and I don't want to ruin it completely. I Overdid it a bit on the cannon smoke staining, so I tried to correct it. It worked OK, but in the process I messed up the underwing decals, so I have to wait for the replacements to arrive (thought I didn't need them, but good job I ordered a set anyway!). This is progress so far:
Still got to draw the panel lines on & recoat with satin, fit the IFF and VHF antennae, the tip lights and the canopy. I've had enough for now though.
I think that looks great, I also like to re finish my old kits, it is very satisfying, every time I go up into the loft I pass an old Matchbox Spitfire that was the first 1/32 scale kit that I bought and built. Must get round to rebuilding that some time. Keep up the good work.
Den
