copey Posted September 20, 2009 Share Posted September 20, 2009 Hello peeps , I'm building acads 1/32 F-18, and the decals for the sidewinders are to stiff ,, they won't wrap around the missiles I even treid soaking them in hot water hoping that would soften them up.. but to no avail. so I was wondering if any one has any hints or suggestions any help is welcome Mark Link to comment Share on other sites More sharing options...
Mark M Posted September 20, 2009 Share Posted September 20, 2009 ?set & sol Link to comment Share on other sites More sharing options...
copey Posted September 20, 2009 Author Share Posted September 20, 2009 (edited) Tried that first, even tried just using micro sol .. bloody things keep peeling away Mark Edited September 20, 2009 by copey Link to comment Share on other sites More sharing options...
Notdoneyet Posted September 20, 2009 Share Posted September 20, 2009 Mark, Lay the decals down over a patch of wet Future/Klear - surface tension will suck the decal down for that "painted on" look. HTH, Ian Link to comment Share on other sites More sharing options...
Julien Posted October 2, 2009 Share Posted October 2, 2009 If the kleart does not work then you can use thin liquid cement, yes GLUE this does work but is dangerous, you only get one go at it so have to get the decal in the right place first time. Also better on a good topcoat. Other option is to paint on the markings (ie for the coloured rings) its a pain but looks good. Julien Link to comment Share on other sites More sharing options...
Alan P Posted October 2, 2009 Share Posted October 2, 2009 Bad luck Mark, the Acad decals are well known in earlier boxings of the kit as being as brittle and pliable as walkers crisps. If the Klear trick doesn't work (it should, that's how i got them to stick eventually) you might have to bite the bullet and go for the TwoBobs stencils HERE Here's hoping for better luck, Al Link to comment Share on other sites More sharing options...
Nobby Posted July 7, 2010 Share Posted July 7, 2010 Try using Tamiya thinners mate....See my thread here- http://www.britmodeller.com/forums/index.php?showtopic=52002 Hope it helps you! Link to comment Share on other sites More sharing options...
