Guest snipersmudge Posted August 5, 2009 Share Posted August 5, 2009 (edited) As a long time fan of rally cars especially the 70's and 80's eras I will attempt to do this kit justice. Never built a car before so this should be interesting. The kit looks quite nice and as the body work just needs a nice white base I think I should be ok! Pete Edited October 24, 2009 by snipersmudge Link to comment Share on other sites More sharing options...
Rallychef Posted August 5, 2009 Share Posted August 5, 2009 Welcome aboad, Pete, nice choice, I built the Safari version (Italeri) last year. Looking forward to watching your progress Regards Ian D Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted August 20, 2009 Share Posted August 20, 2009 well it's about time I posted some pics of my SLOW progress the bodyshell is now ready for priming, some seam lines where sanded down and abit of filler here and there I had a go at test fitting the bodywork over this and the fit was extremly tight, this I think will be harder once all the other parts are in place, any ideas on how to make it an easier fit without damaging anything? wheels done with primer and then some tamiya TS47 I have kicking about, not bad for my firast attempt at spraying a gloss coat from a can more soon hopefully! Pete Link to comment Share on other sites More sharing options...
keefr22 Posted August 23, 2009 Share Posted August 23, 2009 I had a go at test fitting the bodywork over this and the fit was extremly tight, this I think will be harder once all the other parts are in place, any ideas on how to make it an easier fit without damaging anything? I'm still trying to find the e-mail I had from a friend who's built one that contains the mods he did to make the body an easier fit (I need it for my build too!) - if I can't find it I'll have to ask him again! Either way I'll let you know when I find out! Keef Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 2, 2009 Share Posted September 2, 2009 I'm still trying to find the e-mail I had from a friend who's built one that contains the mods he did to make the body an easier fit (I need it for my build too!) - if I can't find it I'll have to ask him again! Either way I'll let you know when I find out!Keef Yes Keef that would be very handy! very little progress has been made as I am still scratching my head trying to figure out how I'm going to get the body on Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted September 2, 2009 Share Posted September 2, 2009 Good start Pete, when I was a kid I used to pass a toy shop every Saturday morning which had, a huge die cast model of the Alitalia Stratos. It used to mesmerism me, covered in mud and looking very real Link to comment Share on other sites More sharing options...
keefr22 Posted September 15, 2009 Share Posted September 15, 2009 Yes Keef that would be very handy! very little progress has been made as I am still scratching my head trying to figure out how I'm going to get the body on Found it! This is the advice I received from someone who's built a couple of Hase Strats ; "Trim the interior around the top of the footwell - which is behind the front wheels - this can't be seen when the car is finished. Remove the raised circular mounting holes from part G8 (if you are not separating the rear body section). I suspect Hasegawa intended to do the same as they did with the 037 - having the piece separate even if an engine is not included in the kit. My view is that the rear section would have located into these holes, as it is they have no function, they are not on the original 1:1 cars, and they prevent the chassis from sitting properly. My kit looked exactly as is shown on the side of the kit box - the rear wheels are too far forward, and the whole thing is under great pressure if built as originally intended. Use Araldite or some other clear epoxy to fix the glass and side door panels - otherwise they will fall off when stretching the sides of the body to get the chassis to fit in!" HTH Keef Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 17, 2009 Share Posted September 17, 2009 cheers for the advice Keef, I think that will help no end Link to comment Share on other sites More sharing options...
keefr22 Posted September 17, 2009 Share Posted September 17, 2009 cheers for the advice Keef, I think that will help no end I hope so, as I'm following it too!! I've just about finished the interior of mine tonight so I hope to try & get it & the body together tomorrow. I didn't have any epoxy glue as recommended, so Ive just stuck the top of the glass in with a fair bit of Tamiya extra thin cement, leaving the sides loose - I hope that'll give it enough play to get the interior in without the glass falling out! Keef Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 22, 2009 Share Posted September 22, 2009 right spurred on by Keef's progress I have now got my finger out and got some paint on, body in primer Wheels all finished chassis taking shape more soon, promise! Pete Link to comment Share on other sites More sharing options...
keefr22 Posted September 22, 2009 Share Posted September 22, 2009 Love those wheels!! Looks like this is becoming a Stratos race.....!!!! Keef Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted September 22, 2009 Share Posted September 22, 2009 Ohh looking good Pete Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 25, 2009 Share Posted September 25, 2009 cheers chaps, some more for you, got some etched seat belts and have added those, I expect the sabelt markings are not strictly correct but I will run with em! also added some MIG pigments to the footwells dashboard done, exhausts painted in alclad aluminium, they will get some staining added with tamiya clear colours next, and lastley body work all sprayed up. I used a can of plasti-cote appliance white. This is my first ever go at this so I took my time and think it's turned out rather well. Just to be on the safe side I will probably leave it for a few days to harden off properly before comencing with the decals. sorry for the pics It's hard to get a good shot of a white model! I am currently sorting out all the other bits for the kit, the headlights and rear lights have had a coat of alclad chrome for the reflectors and I am just finishing off the mirrors more soon Pete Link to comment Share on other sites More sharing options...
keefr22 Posted September 25, 2009 Share Posted September 25, 2009 Looking good Pete - you're racing ahead of me now! I added Mig pigments in my footwells too, as Stratoses did seem to be particularly manky inside. But I don't think I added enough, as unlike yours you can't see mine!! Keef Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 25, 2009 Share Posted September 25, 2009 cheers Keef, I must say I am really enjoying this at the moment it makes a refreshing change. I could get into this auto modelling Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 27, 2009 Share Posted September 27, 2009 more for you, after a marathon session today I have all the decals on the bodyshell. A few places need touching up but this can wait until the decals are fully dry, I used mr mark setter and softener on the decals. Next here is the completed headlights and front light pod. Alcalad chrome gave me a nice reflective colour more soon once I have my strength back! cheers pete Link to comment Share on other sites More sharing options...
T-Tango Posted September 27, 2009 Share Posted September 27, 2009 Looking good, looking real good Pete. Link to comment Share on other sites More sharing options...
keefr22 Posted September 27, 2009 Share Posted September 27, 2009 That's excellent Pete, looks really good! I think it would be a safe bet to put my mortgage on you having the first finished build! I haven't done anything on mine over the weekend. I did put some zero paints Porsche glacier white basecoat on it on Friday, but as I'm down to the bottom of the bottle I think its gone off a bit as it didn't spray at all well. Now giving it a few days to harden off properly before giving it a good micro-meshing! Looking forward to seeing yours finished, Not long now.....!!! All the best Keef Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 27, 2009 Share Posted September 27, 2009 cheers guys, keef I may have it finished by next week if I am lucky, just ordered some zero paints gloss for the bodywork. still quite nervous regarding getting the bodyshell over the chassis! pete Link to comment Share on other sites More sharing options...
Rallychef Posted September 27, 2009 Share Posted September 27, 2009 Very impressive Pete, looking great, looking forward to seeing the final result. cheers Ian D Link to comment Share on other sites More sharing options...
Doug Rogers Posted September 28, 2009 Share Posted September 28, 2009 Looking good Pete. How did you get on with the Plasti cote White, I'm doing a ZEXEL Skyline R32 GTR at the moment and used the same paint, but it's orange peeled quite badly despite a layer of Halfords plastic primer? Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 28, 2009 Share Posted September 28, 2009 Looking good Pete. How did you get on with the Plasti cote White, I'm doing a ZEXEL Skyline R32 GTR at the moment and used the same paint, but it's orange peeled quite badly despite a layer of Halfords plastic primer? cheers guys, doug I had no problems with the plasti cote. I built up the finish spraying three light coats leaving for ten mins each time then a final thicker coat. The finish did not orange peel at all. for primer I used mr surfacer 1000. maybe the plasti coate reacted to the halfords primer? pete Link to comment Share on other sites More sharing options...
Doug Rogers Posted September 28, 2009 Share Posted September 28, 2009 Hmm...could be, I'm a bit of a novice when it comes to cars and I think I've just underestimated the level of preparation needed to get a lovely smooth finish. Think I need to invest in some micromesh and polishing cloths, oh and one of those nice Tamiya stands too. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted October 1, 2009 Share Posted October 1, 2009 Nice work Pete Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted October 23, 2009 Share Posted October 23, 2009 well I finished the model on tuesday, the glass and internal parts where first fixed with araldite then the body was carefully flexed over the rolling chassis. Here are a couple of pics more in the completed builds gallery cheers pete Link to comment Share on other sites More sharing options...
