AnonymousFO98 Posted July 27, 2009 Posted July 27, 2009 Have started making some banners please offer constructive comments take them and play with them or design your own or if happy please use them will edit the second one and hopefully get a couple more out in time having a problem finding the layers transparency tool
darson Posted July 28, 2009 Posted July 28, 2009 Bloddy hell that beats the heck out of what I was try to produce, thanks for going to the effort. Cheers
AnonymousFO98 Posted July 31, 2009 Author Posted July 31, 2009 (edited) thanks Darson no probs slowly getting the hang of layers so will have a bash at doing one more if poss still haven't fully sussed out the feathering of edges though Edited July 31, 2009 by walrus
AnonymousFO98 Posted July 31, 2009 Author Posted July 31, 2009 (edited) probably needs some tweaking still but you get the gist! Edited July 31, 2009 by walrus
AnonymousFO98 Posted August 2, 2009 Author Posted August 2, 2009 (edited) Hi Merv and Paul coool what is it with Britmodellers and Pink Tonkas? must make one meself some time Edited August 2, 2009 by walrus
AnonymousFO98 Posted August 29, 2009 Author Posted August 29, 2009 Good question Jabba i have only ever used my own so it is a straight forward task of copying the IMG tag from photobucket or wrap the IMGtags around using bbcode the only way i can suggest is that you right click on the banner of choice save it in your image hosting site and then paste into your signature in controls and amend hth till someone suggests an easier way
AnonymousA667 Posted August 29, 2009 Posted August 29, 2009 How are banners added to the end of posts? If you're using one of the banners already posted here, right click on it and then click 'properties'. From this get the image address, highlight and copy it. Then click 'My controls', followed by 'edit signature' which is in the Personal Profile menu. Paste the image address, highlight it and then click the 'Insert image' button which will prefix/suffix the address . Hit edit signature and it is done. If you have your own image it needs to be uploaded to a suitable image hosting site, from which the address can be copied and pasted (look for the tag 'forums') with already attached. Sounds complicated, but it is easier to do than describe. peebeep
Jabba Posted September 6, 2009 Posted September 6, 2009 If you're using one of the banners already posted here, right click on it and then click 'properties'. From this get the image address, highlight and copy it. Then click 'My controls', followed by 'edit signature' which is in the Personal Profile menu. Paste the image address, highlight it and then click the 'Insert image' button which will prefix/suffix the address . Hit edit signature and it is done. If you have your own image it needs to be uploaded to a suitable image hosting site, from which the address can be copied and pasted (look for the tag 'forums') with already attached. Sounds complicated, but it is easier to do than describe. peebeep It took a while to get the edit done, but thanks for the information.
