The rules:
1) This is a group build for Ground Forces, Naval and Airforces that took part in Operation Desert Storm and Operation Iraqi Freedom (the Gulf Wars). Your entry MUST have taken part in the combat that took place between Iraqi and Coalition forces in either the first Gulf War, in 1990-91, or in the second 2003-Present. We will also allow aircraft, ground forces from the Iraq-Iran war 1980 -1988. We will also allow Northern and Southern Watch operations and Operation Desert Fox.
2) Models must be less than 20% done. We will also allow models from pervious GB's that have not been finished as long as they fall into the time frame.
3) Any format can be used as well as accessories, Vac, Plastic, Resin, Metal, Photoetch.
4) Enter as many completed models as you like, but if there is a raffle at the end you will only be entered once to keep things fair.
What do you class as 20% made, as I have a F-15E on my work bench at the moment that was used in OIF?
can you post some pics please Jabba?
if you have just got the cockpit tub done that is fine
if you are about to put on the decals forget it! :lol:
depends on the complexity of the kit and at what stage you are at. ;)
Edited by walrus
You called it Merv
sadly she's gone way past the 20% stage imho too. Sorry Jabba.
But if you get the build complete there is no reason why you couldn't post in the Inspirations Thread and start something else- an advantage of having a 12 month GB is that it gives plenty of scope for joining in at a later stage with plenty of time to finish :D
oi you lot stop splitting hairs :lol:
I have a 1/48 Airfix Jag that has sat since the end of the Jaguar GB unfinished. I would greatly appreciate an opportunity to recover some of my lost pride in having not finished that GB. Here is a link to that build thread.
I have since acquired a Neomega pit that I painted, but have not installed. The gun ports have been attached to their respective fuselage halves, as have the nose sections and the nose gear well has been painted and attached to one side... That's about it though...If I had to estimate I'd say it's about 19.925% complete, however I'll defer to those better equipped to determine such things to decide whether this project will qualify or not... :pray:
Thank you for your consideration,
Mark
Sorry Mark but according to the amount of plastic in the kit, the resin you need to add and the amount of paint already on there I calculate the kit at being precisely 21.03571% complete, tough luck :whistle: .
Seriously the Shaguar looks at less than 20% to my eyes, so my vote is for yes.
Thanks Darren... :speak_cool:
Your support is much appreciated.
I'd say you're not even 20%! Maybee 14.311117%... :evil_laugh:
Soooo....Come on DOWNNNNNNN!!!!!!!!!!!!!!!.......................
You called it Merv
No problem, as there are plenty more to build for this GB. Thanks for taking a look.
Here is one of my started projects for consideration for the group build.
I've started this old Italeri C-130 with a view to building it as a Desert Storm one.
I've glued the front sections of the fuselage to the rear. One wing has been assembled and most of the Interior sections have been built into sub sections and gutted ready for adding detail as I really want to go to town on the interior. I've also added some lights to the interior.
I plan to have the model on a diorama base hooked up to a ground power unit.
If the verdict is that it's less than 20% done I'll build it.
Mark
Oh,Boobs !!
It looks as if my Hasegawa,(or was it Airfix's ??),Jaguar GR1 won't qualify,as i completed it 18 years ago !! :fraidnot::nono:
BUT...i am STILL waiting on the delivery of the Tac.Air.Refueller.(to go with it.....)
Even then,it would STILL be 50% done,yes ?? :confused::shrug::wall::weep::hmmm:
However i am hoping to get the 1/35 Challenger Tank today...(at least,THAT qualifies !!)*
Here's hoping....Bazza.
*Since then,i've GOT it....!! la la la !!
Edited by Bazza
Hi Mark
Looks and sounds like there is still a lot to do on the project, so i would be happy about it's inclusion.
Thanks for your judgement paul,
If no one else objects I'll make a thread this evening.
Regards,
Mark
  • 6 months later...
I'd like to enter this build as well.
Hobby Bosses 1:72 Mi-24V Hind-E.
I thought the bad guys were under represented, although this build will fall within the Iran/Iraq war.:)
Deacon
