Oily Posted August 1, 2009 Author Share Posted August 1, 2009 Looks good fella If you've got some confidence in your airbrush skills, you could do some toning by mixing up some shades of the alclad to give some extra depth to some of the nooks. A coat of black or dark grey wash should bring out the "panel lines", and then those dreaded teeth! Mix up some colors like your own teeth & look in a little mirror ro get the shades & color right. You have reference material at hand Cheers Mike. I've only just got my airbrush so my skills are very limited plus i've no Alclad left,lol.I asked Phil in the Promodeller section for advice of which wash to use and he suggests a black wash like yourself.i've put some white undercoat on the teeth for now.Going to try and mix some colours tomorrow,we'll see how it goes. Link to comment Share on other sites More sharing options...
Oily Posted August 6, 2009 Author Share Posted August 6, 2009 Well i finally finished it,what do you think?Good and bad comments appreciated.One thing i think i need to do is remove more of the black wash from around the teeth. Link to comment Share on other sites More sharing options...
TonyT Posted August 6, 2009 Share Posted August 6, 2009 That looks superb. Link to comment Share on other sites More sharing options...
David_in_Fremont Posted August 7, 2009 Share Posted August 7, 2009 I think it looks brilliant! Maybe remove a tiny bit of the wash, but not much. Impressive job on making the teeth look real! Link to comment Share on other sites More sharing options...
Obi-Jiff Kenobi Posted August 7, 2009 Share Posted August 7, 2009 That is seriously cool! mate. Link to comment Share on other sites More sharing options...
Doug Rogers Posted August 7, 2009 Share Posted August 7, 2009 Ye Gods! He doesn't look like he's smiling now does he, he looks like he's going to seriously enjoy ripping someone to pieces! Link to comment Share on other sites More sharing options...
Mike Posted August 7, 2009 Share Posted August 7, 2009 Very well done Link to comment Share on other sites More sharing options...
Oily Posted August 7, 2009 Author Share Posted August 7, 2009 Cheers guys,not only for your comments but for all the help and info i got off this forum,It's been a great resource. Link to comment Share on other sites More sharing options...
AndyL Posted August 7, 2009 Share Posted August 7, 2009 Fantastic job! Link to comment Share on other sites More sharing options...
Alan P Posted August 17, 2009 Share Posted August 17, 2009 Wow that's a fantastic result, congratulations! Al Link to comment Share on other sites More sharing options...
Oily Posted August 18, 2009 Author Share Posted August 18, 2009 Fantastic job! Wow that's a fantastic result, congratulations! Al Thanks guys Link to comment Share on other sites More sharing options...
T-Tango Posted August 18, 2009 Share Posted August 18, 2009 Superb job, really well made model and so different. Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted August 18, 2009 Share Posted August 18, 2009 Clucking bell - that's awesome.... Link to comment Share on other sites More sharing options...
Mark M Posted August 18, 2009 Share Posted August 18, 2009 i want one to scare away the cats! Link to comment Share on other sites More sharing options...
Obi-Jiff Kenobi Posted August 19, 2009 Share Posted August 19, 2009 i want one to scare away the cats! Oh no, not another thread about cat abuse! Link to comment Share on other sites More sharing options...
Tomas Grunt Posted September 7, 2009 Share Posted September 7, 2009 Hi, how did you get that parts to the right shape? I use also heatgun but it is quite hard to fit all parts. Thanks Link to comment Share on other sites More sharing options...
Oily Posted September 7, 2009 Author Share Posted September 7, 2009 Hi, how did you get that parts to the right shape? I use also heatgun but it is quite hard to fit all parts. Thanks Hey there. Heat gun/hot water or hair dryer will do the trick.Heat up a little area at a time,do a test fit,they won't be perfect but get it somewhere near.It'll soon become clear what needs 'adjusting' Then I started at one end,say the eye socket/upper jaw piece,super glued it,then super glued the other end,then went along getting the shape/fit right with the heat gun(WARNING,can give of nasty fumes if it gets near the super glue),after that i just used super glue as i went along to fix it in position then used plumbers weld to strengthen the joint. Hope this helps,if you need any more help,just ask Link to comment Share on other sites More sharing options...
