Airfix 1:72 Hawker Hart Bomber
Found this at a trade stall last weekend and desided to do a rebuild..
A scrub and soak in old brake fluid... and a clean up of poor areas such as around the cockpit/ gunner position and fuselage seams.
If anyone has answers to any of my anotations, feel free to write below!
Edited by phat trev
Does answers to any of my anotations?
Well I can't answer any of your questions unfortunately but it looksl ike an interesting project :)
I remember one of my first few projects (many many years ago!) was a friends "pre-loved" Airfix 72nd Spitfire mk.Vb, we were both only 8 or so at the time but I loved that kit, think I probably still have it somewhere :-)
For rib tapes I would mask off the wings leaving a thin gap over the position of the rib. Then lay down a couple of thick coats of paint or thin filler like Mr Surfacer. Let it dry, remove the masking tape and gently sand down the raised areas until you are happy with the result. Sometimes I would apply another thin coat over the entire wing after removing the tape and then sand down, but I do not always do this.
To do this I have found it best to have sanded the wing surfaces to a smooth but not shiney condition, as this will give the paint/filler something to bite into and not require too much sanding/polishing afterwards.
If the paint/filler is thick it might take just one coat.
Experiment and have fun!
HTH
Christian the Married
Edited by wyverns4
This method I must use, thanks! nice and simple, no messing around with strips of plastic card. I will give it a try.
As for the book, I wonder if my local libary has a copy.
HTH
i use a slightly different method to chistian , instead of masking i use stretched sprue / mek for the ribs , then the thick paint method . when sanding down , the harder plastic remains slightly proud of the surface . very subtle . much easier than trying to mask thin lines consistantly ! :undecided:
Edited by blimp
Decided to go down the sprue route. I have followed the existing moulded detail as it looks to be quite accurate.
Good luck! I've gone down this route before. The results look great but it turned me into a gibbering looney along the way. :frantic::banghead::mental: Yes I know, nobody even noticed the difference!
Martin
Martin
will book myself into a looney house asap then..thanks for the prior warning! :dunce:
Now I have covered the top wing with 'ribs' do I need to slap a covering of liquid glue on to secure everything before I start sanding??
Edited by phat trev
It would be advisable in order to stop any of the tapes comming loose when you sand them down.
Martin
