atdb27 Posted May 4, 2009 Share Posted May 4, 2009 Hi Folks, I'm about to get the B737-100 kit (Thanks Ant Phillips) and would like to update to a more modern 3/4/500 series. I know it will involve much work! Engines being a major change/issue! Should look good next to a 1/72 Concorde So are there any good plans/drawings or refs for the B737 family in any scale that I could work from please? Adrian Link to comment Share on other sites More sharing options...
Richard E Posted May 4, 2009 Share Posted May 4, 2009 (edited) I'm about to get the B737-100 kit (Thanks Ant Phillips) and would like to update to a more modern 3/4/500 series.I know it will involve much work! Engines being a major change/issue! Other than the fact that [a] you've got the 737-100 in your hands and they cost about £60.00 is there a reason why you haven't thought of building one of Welsh Models' 1/72nd scale Boeing 737 300 or 500 kits? Edited May 4, 2009 by Richard E Link to comment Share on other sites More sharing options...
keefr22 Posted May 4, 2009 Share Posted May 4, 2009 (edited) Hi Folks,I'm about to get the B737-100 kit (Thanks Ant Phillips) and would like to update to a more modern 3/4/500 series. I know it will involve much work! Engines being a major change/issue! Should look good next to a 1/72 Concorde So are there any good plans/drawings or refs for the B737 family in any scale that I could work from please? Adrian It's not just the engines you'll need to change to make a -300 from a -100 Adrian, there's the small matter of the latter having a 6ft 4inch longer fuselage. So maybe a -500 would be a better bet? But the -500 wasn't used by that many airlines, so choice of markings is limited. Other changes to the NG were modified leading edge slats & a new dorsal fin, & a longer nosewheel leg. The intakes in the wing/body fairing were also different in some 100 aircraft to the 200/300. Keef Edited May 4, 2009 by keefr22 Link to comment Share on other sites More sharing options...
atdb27 Posted May 4, 2009 Author Share Posted May 4, 2009 Keef,Richard Thanks for your comments so far, Good point about the Welsh Models kit BTW!!! Have got my one at a VGP (Very Good Price) I think there was also a Fine Scale article on making this kit with some mods updates etc? Does anyone have this write up please? PM me if you can scan/supply etc. Adrian Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted May 5, 2009 Share Posted May 5, 2009 I think there was also a Fine Scale article on making this kit with some mods updates etc?Does anyone have this write up please? Adrian Adrain, Which kit are you talking about here? The only 737 article I recall could have been a 1/72 Aurora kit in Janet Airways marking? which was an injected kit. Link to comment Share on other sites More sharing options...
Alan P Posted May 5, 2009 Share Posted May 5, 2009 (edited) Contact Jennings Heilig for your one-stop shop on the conversion. He seems to be the best source of this info that frequents these boards. I think eng could also help you as he does/did line engineering on the -400. Good luck!! Al Edited May 5, 2009 by PHaTNesS Link to comment Share on other sites More sharing options...
RNZAF Posted May 5, 2009 Share Posted May 5, 2009 If it is the Aurora 1/72 100 kit, why dont you just do it as a 100, it will take enough extra detailing work with the kit as it is and there are a wide range of 100 decal sheets out there. Then as Richard stated you can buy the Welsh 300 or 500 to compliment it. Link to comment Share on other sites More sharing options...
woody37 Posted May 5, 2009 Share Posted May 5, 2009 I too am wanting to build a 733. I want to do the BMI Baby Billboard colours. What is the best model to get to achieve this ? Is the Welsh model resin or Vac Form ? Never done either before, but Vac Form looks scary ! Link to comment Share on other sites More sharing options...
keefr22 Posted May 5, 2009 Share Posted May 5, 2009 (edited) I too am wanting to build a 733. I want to do the BMI Baby Billboard colours. What is the best model to get to achieve this ?Is the Welsh model resin or Vac Form ? Never done either before, but Vac Form looks scary ! It's listed on the Welsh website as 'multi-media' - which with their kits usually means vac-fuselage, resin wings, stabs & fin & metal undercarriage. But I've never owned one, so that's a guess on my part! Welsh vac-form parts are usually very well done & easy to work with. Keef Edit: I was assuming by your post that you mean you want to do one in 1/72? If not, the best 144th 737 New Generation kits on the market are Daco's. These are followed by the minicraft kits, which whilst not quite in the same league are simple to build & can be made into very nice models that look like 737's! Edited May 5, 2009 by keefr22 Link to comment Share on other sites More sharing options...
atdb27 Posted May 5, 2009 Author Share Posted May 5, 2009 If it is the Aurora 1/72 100 kit, why dont you just do it as a 100, it will take enough extra detailing work with the kit as it is and there are a wide range of 100 decal sheets out there. Then as Richard stated you can buy the Welsh 300 or 500 to compliment it. Might just do that. Cheers Adrian Adrain,Which kit are you talking about here? The only 737 article I recall could have been a 1/72 Aurora kit in Janet Airways marking? which was an injected kit. I think that is the one Buddy. Have you got a copy of it? Cheers Adrian Link to comment Share on other sites More sharing options...
Jennings Heilig Posted May 5, 2009 Share Posted May 5, 2009 I'd have to rank converting an Aurora "737" (not quotes - it's only vaguely reminiscent of a 737 if you squint your eyes and stay at least 10' away) into a -300 or -400 right up there with converting the KMC "727" into a 727. Unless you're a masochist of the highest order, you'd be money, time, and sanity ahead of the game to simply buy a Welsh kit and be done with it. If you do want to convert the Aurora/Monogram kit, you're going to end up replacing about 90% of what you get in the box. You might as well scratch build it. J Link to comment Share on other sites More sharing options...
atdb27 Posted May 5, 2009 Author Share Posted May 5, 2009 I'd have to rank converting an Aurora "737" (not quotes - it's only vaguely reminiscent of a 737 if you squint your eyes and stay at least 10' away) into a -300 or -400 right up there with converting the KMC "727" into a 727. Unless you're a masochist of the highest order, you'd be money, time, and sanity ahead of the game to simply buy a Welsh kit and be done with it. If you do want to convert the Aurora/Monogram kit, you're going to end up replacing about 90% of what you get in the box. You might as well scratch build it.J Im only a masochist at weekends J! Sounds like the doing 100 and getting a Welsh kit is the 'Sane' way to go. Just one of those impetuous thoughts. Thanks Guys Link to comment Share on other sites More sharing options...
woody37 Posted May 6, 2009 Share Posted May 6, 2009 It's listed on the Welsh website as 'multi-media' - which with their kits usually means vac-fuselage, resin wings, stabs & fin & metal undercarriage. But I've never owned one, so that's a guess on my part! Welsh vac-form parts are usually very well done & easy to work with.Keef Edit: I was assuming by your post that you mean you want to do one in 1/72? If not, the best 144th 737 New Generation kits on the market are Daco's. These are followed by the minicraft kits, which whilst not quite in the same league are simple to build & can be made into very nice models that look like 737's! Thanks. Never new about this, cheers Link to comment Share on other sites More sharing options...
eng Posted May 11, 2009 Share Posted May 11, 2009 I've got a Welsh 1/72, 737-500 and access to real thing for pic's or info. PM me any time if I can be of assistance. I'd definetly avoid trying to mod a -100 to a -3/4/500, as suggested go for the Welsh -500 and make fuselage plug's if required. A long time ago there was talk of Denzil at Welsh making plugs for the -300/400 version but I don't know if this ever came to anything, should be fairly easy to do yourself. Hope these snaps give you some inspiration - Go for it! Eng Link to comment Share on other sites More sharing options...
atdb27 Posted May 23, 2009 Author Share Posted May 23, 2009 Hi Eng, PM on it's way. I did get up to GLA for a few visits but never with my camera Isn't that always the way though! Adrian Link to comment Share on other sites More sharing options...
eng Posted May 23, 2009 Share Posted May 23, 2009 (edited) Nose gear bay looking aft. Another showing the leg from the front. Aft l/h side of the leg. Fwd view of the left main gear. Aft wall of the main wheel well looking from the fwd r/h corner to the aft l/h side. The unit aft of the tank on the keel beam is the stby electric hyd pump. The long diagonal cylinder on the left of the pic is the brake accumulator and above the inner end of this is the flap power drive unit (the green item half way up the bulkhead with shafts from either side), on the roof at the top right of the pic is the landing gear downlock viewer for the crew to check the leg's are down and locked if dropped by gravity. Wheel well from l/h bay looking to the fwd corner of the r/h bay (the large tank in the foreground is the stby reservoir on the keel beam between the bays, and the furthest tank is the B sys hydraulic reservoir) you can also see the inner side of the leg and sidestay. This is taken from the r/h bay looking fwd and left, the tank in view on the roof is the smaller A sys hydraulic reservoir, and again the stby reservoir in the foreground. The large white unit to the right of the A system tank is the spoiler mixer unit (a mechanical computer) which gives the differential and proportional control of the flight spoilers (no's 2,3 on the left and 6,7 on the right. Hope these are of some help Adrian, PM or email me if you have any questions or need more info, Rgds, Eng Edited May 23, 2009 by eng Link to comment Share on other sites More sharing options...
atdb27 Posted May 23, 2009 Author Share Posted May 23, 2009 (edited) Fabulous Eng. There a great help thank you. Adrian Edited May 23, 2009 by atdb27 Link to comment Share on other sites More sharing options...
eng Posted May 25, 2009 Share Posted May 25, 2009 Never occured to me until tonight but here's a link to a superb site with stacks of info and links - http://www.b737.org.uk/index.htm Rgds, Eng Link to comment Share on other sites More sharing options...
kev67 Posted August 28, 2009 Share Posted August 28, 2009 I am making the Welsh model 1/72 Boeing 737 T43-A, completed the main build and starting to finish the spray painting, if you need any assistance on building the Welsh models I would be more than happy to help. http://www.flickr.com/photos/26726329@N02/...495506/sizes/o/ Link to comment Share on other sites More sharing options...
kev67 Posted August 28, 2009 Share Posted August 28, 2009 Nose gear bay looking aft. Another showing the leg from the front. Aft l/h side of the leg. Fwd view of the left main gear. Aft wall of the main wheel well looking from the fwd r/h corner to the aft l/h side. The unit aft of the tank on the keel beam is the stby electric hyd pump. The long diagonal cylinder on the left of the pic is the brake accumulator and above the inner end of this is the flap power drive unit (the green item half way up the bulkhead with shafts from either side), on the roof at the top right of the pic is the landing gear downlock viewer for the crew to check the leg's are down and locked if dropped by gravity. Wheel well from l/h bay looking to the fwd corner of the r/h bay (the large tank in the foreground is the stby reservoir on the keel beam between the bays, and the furthest tank is the B sys hydraulic reservoir) you can also see the inner side of the leg and sidestay. This is taken from the r/h bay looking fwd and left, the tank in view on the roof is the smaller A sys hydraulic reservoir, and again the stby reservoir in the foreground. The large white unit to the right of the A system tank is the spoiler mixer unit (a mechanical computer) which gives the differential and proportional control of the flight spoilers (no's 2,3 on the left and 6,7 on the right. Hope these are of some help Adrian, PM or email me if you have any questions or need more info, Rgds, Eng Have you any more pictures of the undercarriage as I have the Welsh model 1/72 Boeing 737 T-43A and looking at it, the undercarriage legs look wrong on the kit, as the leg of the forward undercarriage goes straight up but you pictures show it does not Link to comment Share on other sites More sharing options...
Kev1n Posted August 29, 2009 Share Posted August 29, 2009 putting all this junk into a model is my kind of wierd behaviour.... Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted August 29, 2009 Share Posted August 29, 2009 Have you any more pictures of the undercarriage as I have the Welsh model 1/72 Boeing 737 T-43A and looking at it, the undercarriage legs look wrong on the kit, as the leg of the forward undercarriage goes straight up but you pictures show it does not Kev, I think you will find EVERY 737 kit in all scales has got the nose gear strut wrong. I expect that it is for strength and reduced complexity in producing the kit. I can tell you the Airfix and Minicraft 1/144 kits are like the Welsh kit. Link to comment Share on other sites More sharing options...
kitnut617 Posted August 30, 2009 Share Posted August 30, 2009 (edited) I got hold of some 1/72 'Janet Airways' decals because I was going to do my 737 (Monogram boxing) in those colours, but I should tell you I was told all the 'Janet Airways' 737's were -200's. You can get the decals from Draw Decals. http://www.drawdecal.com/catalog.htm I bought a Welsh Models 1/72 737-200 for it instead, these are very nice kits although I've not made mine yet, as said above, vac fuselage, resin wings, engines and white metal u/c and other small bits. You get a clear vac windshield and a full cockpit. I've got four of the 1/72 Welsh Models kits so far, all very nice and I should get on with them, especially the DH Comet in RCAF markings. If you scroll down the list a bit you'll find you can get some T-43A decals for this kit too. BTW, the Aurora/Monogram injection 1/72 737 is really of one of the prototypes, but it is close to a -100, NASA used one of the prototype -100's for quite a while and I was able to find some decals to do this type. I got them from Hawkeye Models Australia. http://www.hawkeyemodels.com.au/Site.htm Look in the US Military listing here. Edited August 30, 2009 by kitnut617 Link to comment Share on other sites More sharing options...
TonyT Posted August 30, 2009 Share Posted August 30, 2009 (edited) I too am wanting to build a 733. I want to do the BMI Baby Billboard colours. What is the best model to get to achieve this ?Is the Welsh model resin or Vac Form ? Never done either before, but Vac Form looks scary ! If you need pics of a baby one it is doable they live next door to me they had a couple painted as adverts for Board to the Rings, and visit Wales Edited August 30, 2009 by TonyT Link to comment Share on other sites More sharing options...
kev67 Posted August 30, 2009 Share Posted August 30, 2009 I got hold of some 1/72 'Janet Airways' decals because I was going to do my 737 (Monogram boxing) in those colours, but I should tell you I was told all the 'Janet Airways' 737's were -200's. You can get the decals from Draw Decals.http://www.drawdecal.com/catalog.htm I bought a Welsh Models 1/72 737-200 for it instead, these are very nice kits although I've not made mine yet, as said above, vac fuselage, resin wings, engines and white metal u/c and other small bits. You get a clear vac windshield and a full cockpit. I've got four of the 1/72 Welsh Models kits so far, all very nice and I should get on with them, especially the DH Comet in RCAF markings. If you scroll down the list a bit you'll find you can get some T-43A decals for this kit too. BTW, the Aurora/Monogram injection 1/72 737 is really of one of the prototypes, but it is close to a -100, NASA used one of the prototype -100's for quite a while and I was able to find some decals to do this type. I got them from Hawkeye Models Australia. http://www.hawkeyemodels.com.au/Site.htm Look in the US Military listing here. The only niggle I have found with the Welsh model is the two section centre resin bit, I think it would of been better if this was vacform as there is no room to add extra detail as it is a solid bit of resin where the wheel wells are, also the tail hinges were in the wrong place Link to comment Share on other sites More sharing options...
