bigbadbadge Posted April 7, 2009 Share Posted April 7, 2009 Hello everyone Please could someone help, I am currently building a 1/24th scale Spitfire Mk1 (Airfix) and there are no walkway lines/borders in the decals, did all the mk1's have them I am building P9390 of 54 squadron. I would be grateful of any help offered. Many thanks Chris Link to comment Share on other sites More sharing options...
Edgar Posted April 7, 2009 Share Posted April 7, 2009 Early K-registered Mk.Is seem to have been without lines, but there's a very clear photo of P9450, showing them, and, since it first flew only a month after P9390, on balance I'd say that it should have them. Remember that the port wing had the "Walkway forward" line along the spar-line, and the fore-and-aft "Walkway inboard" line; the starboard wing had only a "Walkway forward" line, from root to tip. Also the lines did not run over the roundels. Edgar Link to comment Share on other sites More sharing options...
keith in the uk Posted April 8, 2009 Share Posted April 8, 2009 Chris. You must have one of the early kits , the current decal sheet has the walkway lines and the WALKWAY FORWARD , WALK INBOARD markings. The black lines are quite easy to do , just cut strips from Black decal sheet to the lenghth you need and apply , remember they dont overlap the roundels. Tec Mod decals do sheets for 1 24th Spitfires which include the walkway markings if you dont fancy making your own. As they say on Blue Peter heres one i prepared earlier. Link to comment Share on other sites More sharing options...
bigbadbadge Posted April 8, 2009 Author Share Posted April 8, 2009 (edited) Thanks guys I will add them. I will nick them from my airfix Mk V, but use the wording from the Mk1. I must admit the kit actually went together well and only a tiny amount of filler was used around the intake and the the rear of the wing where it joins the fuselage will post a couple of piccies when finished. By the way nice build there Keith Once again thanks Chris Edited April 8, 2009 by bigbadbadge Link to comment Share on other sites More sharing options...
