:thumbsup:
Looking forward to this one, people :popcorn:
Absolutely Random, it's the 6th by my calendar so construction begins tonite.
We only have four months to get our number up to a force that can beat the coastal defences.
Let's get started and build planes,tanks, ships,etc... to make the landings on 6 th of June a sucses.
NEXT STOP... NORMANDY !
Where's my Glue? Where's me paint??? :frantic:
Edited by timbo33
Tasca Firefly sat in garage. ive got decals, ali' barrel - etch arrives tomorrow - then off we go!
My god, that sounds like you've got a real one squirrled away. I've always liked the Firefly, so I'll be looking forward to this build.
Watch out for the tasca suspension, it's a a pain in the bottom! I would go as far as to suggest robbing the suspension from another kit if you have one available or investing in the Resicast replacement set. There again, you might get on with the Tasca sussy, I did'nt.
Phil
I'd certainly like to do something for this.
Would it be pushing the envelope a little too far to model Oddball's Sherman? If so, then I have plenty of other options, from Heller/Airfix LCA to PaK 40 ... this could even be the excuse I need to make the Attack PaK 43.
Oddball is first choice, though, and I've plenty on the go so I'm in no rush to start.
Phil
Phil I wouldn't go so far as calling the Tasca suspension a pain in the bottom, its gimmicky true but it's not hard to build. Just replace the layers of vinyl with equally sized bits from a pencil eraser.
Darren,
I have built a couple of the Tasca Shermans, the suspension is a pain! I have used sections of square stock to replace the vinyl, at some stage I might just try the pencil eraser idea, thanks for that. It would have, perhaps, been nice if Tasca had given the option of using the "working" suspension or a set of plastic blocks to replace the vinyl sheet.
Phil
Hello,
The only problem with "Oddball's" Sherman would be that "Kellys Hero's" is set in Italy.
Phil
Hello,
Phil
Nooooooo it's not! The movie was made in the former Yugoslavia, but the setting was France (they were about to go to Nancy). However, if you recall, they "fought their way from Omaha" before Oddballs' CO was "decapitated by an 88". Don't you remember what the Tigers did to Shermans in the bocage? They ASSAULTED them.
Why for all these years have I thought it was set in Italy! I know it was made in Yugoslavia, hence the interesting vehicles that appear. I have not seen it for many years, perhaps I should blow the dust off my copy and watch it again!
Phil
"Always with the negative vibe's Moriarty"
I have the Tamiya early Sherman kit kindly donated by Timbo is it possible to do "Hurricane" listed as Normandy Aug-44 as this has a camo pattern a touch more interesting than just plain old olive drab.
M4 Sherman (U.S.A. 3033967) "Hurricane" 66th Armoured Regiment. Landed in full wading gear. Photographed 9th of June 1944, Utah Beach.
Phil
Had e mail from Historex - Resicast Firefly bogies arrive tomorrow. Firefly etch arrived today so I should be able to get cracking. Usually build as much out of box as I can, or scratch my own bits and pieces - skill level permitting so thought I would go mad on this one as its my first group build. Havnt decided on regiment yet, Have Bison decal set so it will probably be off there - hope to get cutting and building tomorrow..Neil
Phil
would that be in OD or field applied camo, i've seen a picture of the camo but it has no date
The earlier photo with the wading gear shows it in overall Olive Drab with the code "H 2" on the turret, the later photo, dated the 16th of August 1944, shows the vehicle with camo striping, I personally think the "stripes" are black (faded and dirty) the code had gone from the turret by this time. The tracks in the later shot seem to be T48 Rubber chevron with the chevron almost completely worn away. The wading gear had gone by that time.
Phil
