Jazzy Jase Posted January 15, 2009 Share Posted January 15, 2009 Whilst attempting post-shading for the first time I made a little error. As you can see in the picture below, there's a couple of patches where I've put on too much paint and it has pooled. How should I go about fixing this? Don't really want to strip and re-paint the whole wing. Link to comment Share on other sites More sharing options...
CPNGROATS Posted January 15, 2009 Share Posted January 15, 2009 Mask off and repaint the problem panels... HTH, Cheers, ggc Link to comment Share on other sites More sharing options...
AndyL Posted January 15, 2009 Share Posted January 15, 2009 Take some masking tape - Tamiya is best, and mask off the offending panels. Lightly rub back the offending surfaces and respray. Link to comment Share on other sites More sharing options...
turnerdad Posted January 15, 2009 Share Posted January 15, 2009 If you've got a little time, mask off the affected panels, lightly rub back with the finest wet sandpaper you can find (micromesh if you have it) then spray the original colour, demask and try again post shading. If in more of a hurry forget masking panels off and just rub the affected areas then repspray lightly (thats what I'd do). The advantage with weathered finishes is that mess ups are easy to hide, as ultimately it will all look like a beaten patchwork anyway. HTH. Link to comment Share on other sites More sharing options...
Jazzy Jase Posted January 15, 2009 Author Share Posted January 15, 2009 Cheers guys, I thought you might say masking and sanding, was just a bit nervous about doing it. Anyway, I followed your advice and I'm pleased with the result, though the larger mark needed a lot more rubbing down than I expected. Link to comment Share on other sites More sharing options...
