Antoine Posted January 1, 2009 Share Posted January 1, 2009 (edited) First build started in 2009. It will be an OOB, with very little scratch, no PE and no resin. My main aim will be to make it as clean as possible. I'll also try certain tips for heavy weathered Japanese aircraft. What's in the box. Edited January 1, 2009 by Antoine Link to comment Share on other sites More sharing options...
Antoine Posted January 1, 2009 Author Share Posted January 1, 2009 (edited) Let's go. Starting with the pit. I've just added a few copper wires straight on the engraved plastic lines. A coat of TS30, and then, I've put a few drops of liquid mask randomly. Then, a coat of interior green. A few bits of red, yellow and green here and there (I use the aerodetail book). And, with a toothpick, I remove the liquid mask. The interior green is some kind of Vallejo/prince august paint, and doesn't stick too well on the TS30. So its peeling a little bit too much to my liking, but it's not really important, as nearly nothing will be seen once the fuselage halves will be glued. Don't forget the pit itself. I've made some straps on the rudder bar, with masking tape. I've tried to use the panel's decals, but they didn't stick too well. So I've done a little bit of alu drybrushing, with some bits in red and yellow. Its not yet finished, I have to make some seat straps, and also a wash. Edited January 1, 2009 by Antoine Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted January 1, 2009 Share Posted January 1, 2009 swift start on this one Antoine old chap, like the the paint peeling in the cockpit Link to comment Share on other sites More sharing options...
Antoine Posted January 1, 2009 Author Share Posted January 1, 2009 Thanks! And I don't forget the M41! Link to comment Share on other sites More sharing options...
Antoine Posted January 3, 2009 Author Share Posted January 3, 2009 An attempt to recreate the aotake lacquer effect: A coat of TS30. And then a coat of X23 clear blue. Link to comment Share on other sites More sharing options...
Antoine Posted January 3, 2009 Author Share Posted January 3, 2009 I've finished the pit. Added the lap straps, with a buckle. Very difficult for me to make a smaller one. The engine, painted tyre black, with an alu drybrush. Then a brown/red wash. Complete with the radiator. Link to comment Share on other sites More sharing options...
Old VG 33 Posted January 4, 2009 Share Posted January 4, 2009 Hello That's a good start with this little fighter. Patrick Link to comment Share on other sites More sharing options...
wkennerley Posted January 4, 2009 Share Posted January 4, 2009 Wow nice kit and brilliant work you have put into it I look forward to future posts Link to comment Share on other sites More sharing options...
Antoine Posted January 4, 2009 Author Share Posted January 4, 2009 Thanks a lot! Link to comment Share on other sites More sharing options...
Muller Posted January 4, 2009 Share Posted January 4, 2009 Great work so far, like the paint-chipping in the cockpit, the aotake looks spot on too! Link to comment Share on other sites More sharing options...
Antoine Posted January 4, 2009 Author Share Posted January 4, 2009 the aotake looks spot on too! Thank you! No too sure about that. I think that I'll have a another try with a drop of clear green added to the blue. Link to comment Share on other sites More sharing options...
Antoine Posted January 4, 2009 Author Share Posted January 4, 2009 More little bits. I wanted to represent the cowl flaps open. The inside was sanded with the help of my faithfull dremel. I cut each flaps with a razor saw. And then I bended carefully each one of them open. I glued each legs (they come in two parts), and then added the brake's flexible, and fixed it with cyano and metal tape. Link to comment Share on other sites More sharing options...
Antoine Posted January 25, 2009 Author Share Posted January 25, 2009 I just had another try with aotake. I was not satisfied with the blue, so I've tried a blue green (Mix of clear blue and clear green). There is no landing light in a Ki-43-I, only from late Ki-43-II on... And anyway I've lost the light clear cover. I've used a little bit of sprue and glued it in place. Once dry, it was cut to the correct length, and then sanded to get the shape of the wing's leading edge. I've also glued a thin copper wire to give the trim cable a better look. Link to comment Share on other sites More sharing options...
dahut Posted January 26, 2009 Share Posted January 26, 2009 It looks very nice, Antoine. One of my favorite WWII aircraft. Link to comment Share on other sites More sharing options...
Antoine Posted January 26, 2009 Author Share Posted January 26, 2009 Preparing for paint. Masking (Tape and Mr masking sol) Then the markings: An undercoat of white. Then the red for the hinomaru. A coat of orange/yellow on the leading edges A coat of blue/black in front of the pit. Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted January 26, 2009 Share Posted January 26, 2009 nice build so far Antoine, like the idea of spraying the national markings, what will the final colour scheme be? Link to comment Share on other sites More sharing options...
Antoine Posted January 26, 2009 Author Share Posted January 26, 2009 See the boxart, Pete? That's it. Green & grey. Link to comment Share on other sites More sharing options...
dahut Posted January 27, 2009 Share Posted January 27, 2009 I rather like the psychodelic, trippy colors you show here! Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted January 27, 2009 Share Posted January 27, 2009 See the boxart, Pete?That's it. Green & grey. DOH! silly me! looks interesting with the paint chipping too! Link to comment Share on other sites More sharing options...
Antoine Posted January 27, 2009 Author Share Posted January 27, 2009 DOH! silly me! looks interesting with the paint chipping too! That's what I was aiming for with this kit. Improve some weathering technique, mostly chipping paint on an alu coat. Here is the plan: - Coat of TS30 - Randomly application of mr masking sol neo - Coat of green/grey - Rub the masking sol - Maybe a few scratches here and there with a cutter? I'll see. Link to comment Share on other sites More sharing options...
Ian Posted January 27, 2009 Share Posted January 27, 2009 Built one last year - really enjoyed it too. Wont hi-jack your thread, Antoine, but let me know if it's OK to post pics of mine in this thread - just as a comparison. Best Ian Link to comment Share on other sites More sharing options...
Antoine Posted January 27, 2009 Author Share Posted January 27, 2009 Built one last year - really enjoyed it too. Wont hi-jack your thread, Antoine, but let me know if it's OK to post pics of mine in this thread - just as a comparison.Best Ian I'm sorry you can't, your builds are far below my well known standard... Joking (Bad joke as usual), You're more than welcome, Ian. Seeing your build can give me some ideas. Anyway, this one will finish (I hope) in the critique corner. I always ask for comments (I've never enough for my taste), good or bad as soon as they're constructive. Link to comment Share on other sites More sharing options...
Antoine Posted January 27, 2009 Author Share Posted January 27, 2009 Masking. I've cut the hinomaru in some tamiya tape. The large one, but still not as large as I needed. I had to take to stripes, one above the other. I only hope that there will be no blur once the tape is removed. To cut the tape, I've used a circular cutter (?). Then another coat of white. While it's drying, I've masked the anti-glare panel around the pit. I'll let everything dry till tomorrow. Link to comment Share on other sites More sharing options...
Antoine Posted January 27, 2009 Author Share Posted January 27, 2009 Well, in the end, I couldn't wait till tomorrow. And the winner is: Link to comment Share on other sites More sharing options...
perry Posted January 27, 2009 Share Posted January 27, 2009 This is really looking great Antoine, will be ineteresting to see the end results! Link to comment Share on other sites More sharing options...
