Julien Posted November 27, 2008 Share Posted November 27, 2008 I am doing a kit at the moment and intend to do it post war mounted on a plith, for this the hatches etc will be welded up, any idea of the best way to replicated this? Cheers, Julien Link to comment Share on other sites More sharing options...
darson Posted November 27, 2008 Share Posted November 27, 2008 I am doing a kit at the moment and intend to do it post war mounted on a plith, for this the hatches etc will be welded up, any idea of the best way to replicated this?Cheers, Julien There's a couple of ways you can go about this Julien and both are fairly simple. The first is the old stretched sprue method, with the sprue glued to the model and smothered in Tamiya extra thin cement then textured with an old No 11 blade with the tip snapped off. The second is a little more tricky as it's harder to handle and involves very thin sausages of Miliput (or similar two part compound) placed on to the model where you want the weld seams, then textured with the tip of an old No 11 blade with the tip snapped off. Cheers Link to comment Share on other sites More sharing options...
Julien Posted November 28, 2008 Author Share Posted November 28, 2008 Cool, I will try the sprue thing. Julien Link to comment Share on other sites More sharing options...
