Timmy! Posted December 3, 2008 Author Share Posted December 3, 2008 Ohh I Escaped after 3 As said above... PEC where did I get PCU from lol........ I think what is confusing is the seat here has the blanking plate fitted to protect the connections.... the one you have has the hose attachments on it by the looks of it. The protective cover we fitted between flights does not. see http://sepecat.info/b/2007/10/19/ejection-...tin-baker-mk9b/ OK here is a close-up of the seat. I think the gray part is throwing you guys off. I have a photo of a pilot w/ the PEC and it appears to be the right size to fit in the notch where the errant gray box is. Do I have it right? Remember I'm only capturing rough outlines of these parts - the model will have better detail. Timmy Link to comment Share on other sites More sharing options...
Mike Posted December 3, 2008 Share Posted December 3, 2008 This isn't modelling... it's scale engineering! Link to comment Share on other sites More sharing options...
Timmy! Posted December 17, 2008 Author Share Posted December 17, 2008 A little progress with the model. As always please let me know if you find glaring errors. Your help has been very useful so far. This shot is of the nose gear. You can see the wire frame outlined in red dashed border. This is 2-d view port from the 3-d part. All four view ports are generated from one 3-d model. Any changes I make to the 3-d model will change all four of the view ports. The ones outlined in red have not been rendered. There are also sections of the nose wheel and hub, again taken directly from the 3-d model. Here is the gear well, most of these have been redrawn in order to add surface detail. Notice the red outlined sections these are used as guides to precisely re-create the 2-d drawings of the gear well. That's it for now, Timmy Link to comment Share on other sites More sharing options...
Brian1 Posted December 17, 2008 Share Posted December 17, 2008 This isn't modelling... it's scale engineering! I agree, and it's awesome! Link to comment Share on other sites More sharing options...
Howard of Effingham Posted December 19, 2008 Share Posted December 19, 2008 having looked at the bronco model, i'm very, very impressed indeed. gonna keep an eye on this model. Link to comment Share on other sites More sharing options...
smeds Posted December 19, 2008 Share Posted December 19, 2008 OK here is a close-up of the seat. I think the gray part is throwing you guys off. I have a photo of a pilot w/ the PEC and it appears to be the right size to fit in the notch where the errant gray box is. Do I have it right? Remember I'm only capturing rough outlines of these parts - the model will have better detail.Timmy The item behind the gray box you point out is I believe the handle for the PEC dust cover (the part that the gray box is located onto) which is removed by the groundcrew/pilot on crew in and refitted on turnaround and after flight servicings. So, if no seat stick interface is in place, the dust cover will be fitted. HTH smeds Link to comment Share on other sites More sharing options...
Timmy! Posted December 19, 2008 Author Share Posted December 19, 2008 ...seat stick interface...smeds Had to read that three times then I got it! I have heard of "stick actuators," but not that one. That helps! I really think that the lack of detail in the drawings is confusing us all. The model will be based on the photos I have, and will incorporate much more detail - which I hope will clear things up. Timmy! Link to comment Share on other sites More sharing options...
Cornish Posted January 6, 2009 Share Posted January 6, 2009 wow! Please post more. Link to comment Share on other sites More sharing options...
TonyT Posted January 20, 2009 Share Posted January 20, 2009 (edited) Hows it progressing Timmy, heard news there are 10 on them going Stateside as they were trying to recruit Jag Engineers to maintain them, was Fwd an email to see if I was interested...... BTW I just bought a 1/18th Jag Pilot white metal figure that would just look like a tall Jag pilot against it........ Edited January 20, 2009 by TonyT Link to comment Share on other sites More sharing options...
nirvanagr Posted April 11, 2012 Share Posted April 11, 2012 No words about the Bronco! I'm speechless. As for the Jag, i'll be waiting to see another wonder! Link to comment Share on other sites More sharing options...
