Joining you with this, early F-111A kit.  A rare find at Jet Age,  the tool was later modified to an F-111E.
This a 1973 box, which was about when I received one for Christmas.
Instructions, and what Airfix made of the F-111.   Mention of a UK version, and the US Navy's F-111B.
Parts, in one of Airfix's yucky plastic colours.  A novel feature of the F-111, is the crew escape capsule which you can see.
And decals - onto my window for bleaching.
  • Like 16
Nice to have you joining us again, Tim :) Airfix have certainly had some "interesting" colour choices for their plastic over the years. I'm pretty sure I built a Bf 109 in that colour plastic as a kid, I suspect an older kit passed on to me from a modeller friend of my grandparents as the "new" boxing kits I remember from the 80's were either grey, black, or white plastic.
James
  • 100% 1
Wow as soon as I saw that box art and blue plastic I was taken right back to a happier time and place.Thanks Tim and good luck.
  • Agree 3
  • 100% 1
Some preparation.  The escape capsule is nearly complete.
White gloss airbrushing of wing lower sides, and control surfaces.
  • Like 12
Nice work with this one too, Tim
James
Emerging from  the variable geometry phase of the paint-shop to assemble the aircraft hull.
I've lubricated the wing pivots with vaseline, heatsmashed the linkage pins - then assembled the upper and lower fuselage parts.
Tailplane links were damaged, so have been fixed.
Then from the underside.  F-111A, B, C, FB and EF versions had Triple Plow translating cowl air intakes,
identified by those huge splitter plates.  Later variants had blow in intakes.
These omitted the splitter plates, and seeing the F-111F at Cosford, I couldn't quite believe how far out the intake actually is..
And finally with the escape capsule fitted.  There's loads of space in the nose for ballast,
and it can be fitted last of all.
  • Like 11
That's all progressing very nicely, Tim :)
James
  • 100% 1
This one's also looking the part, Tim :)
James
As with your other build, I'm stuggling to spot the issues in the photos. I think both builds look good
James
Both of my F-111 models have three ejection triangle decals.   On each I've installed one just behind the canopy on  each side.
Does anyone know where the third goes?  I can't spot it.
Undercarriage fitted.
And onto those wheels.  Surprisingly, this model isn't a tailsitter - even with the wings back.
Minimal ballast in that nosecone, which is dryfitted so far.
Completion of assembly for this kit.
I'm just going to give it a coat of matt - then completion.
Nice to see her up on her legs, Tim :)
James
I have just looked throug hthe old Ian Allan book on the F-111 that shows many a photo of the Grey "A"s and "B"s and I can only see 2 triangles. They may vary slightly in their positioning, but there  only appear to be 2.
