Hi there
As I am on a bit of a roll painting yellow and black I thought this model might fit into this GB. Here is the box, sprue and decal shots. During its life 134 went though a number of tiger stripe changes, later in life they were consigned to the nose only. BTW I am open to suggestions how to get the black tiger stripes right. On to the pictures.
p?i=850e3d72ed0aa559aa6bf1cd69d05513
p?i=dca0b530f2a773ca36190972a40bf040
p?i=8c867bcea2f71bd35b5e20ada15cfc80
p?i=91b9a03d673d9e81c81d44c64ca7d581
p?i=ba7d8d24aac5ba00765a1f00016d7436
Regards Toby
  • Like 11
Unfortunately, some of the items on this decal sheet seems to be wrongly sized.
Welcome to the GB Toby and with a superb choice, I love the F-5 family and think that the scheme you have chosen is one of the most striking worn by them. The kit is a good one as its the old ESCI one which I have built and enjoyed so I am keen to see how you get on.
Thanks about the tip @Vingtor, I will find  a workaround somehow.
Thankyou @modelling minion for the welcome. Yes, this is a nice kit. I built one before, this time it will be the colour scheme that takes the time.
Regards Toby
Edited by Planebuilder62
typo
Welcome to the GB Toby :) You've chosen a subject and scheme that's guaranteed to stand out here
James
Here is question to the BM hive mind.
To assemble the fuselage on this kit, is it best to follow the instructions or to glue each nose side to the fuselage side first?
Regards Toby
Well, after studying some of the Esci F-5 builds in the earlier F-5 STGB I found the answer to my own question so I have deviated from the instructions about the fuselage. Great stuff here on Britmodeller. 😊😊😊😊😊😊😊
Coming soon will be some spreaders to help the rear fuselage match the bottom part.
Pictures to follow in a day or two.
Regards Toby
Join the fuselage sides first. Otherwise you might get a join that is not very smooth.
Nils
Hi there
Fuselage fronts glued to rears done, thanks for the tips on that @Vingtor and @modelling minion. Spacers fitted to avoid a step glueing the bottom on.
Some filling as needed and this is where the model is now ready for primer.
p?i=44839dc47de51b8af876cb4622af27e9
p?i=8a7c4033fe1996fe4dbb6334efbfc1d5
p?i=118e8946ff0fe0c401ed1324a9cf513f
Regards Toby
  • Like 13
That's looking good, Toby. I've built this kit myself and know full well that the fit is far from perfect, but you appear to have that under control
James
Well painting has started, and its been a trial error exercise to find the right shade of yellow. The first attempt was to use Mr Color RLM 04 which looked a bit dirty of all things. Trial no 2 was Tamiya yellow from their lacqeur range. Nice and bright, but a bit too yellow like this :
p?i=93031ce8f4417dc20c62e62168a0876d
Then I tried what I think was best, Tamiya Chrome yellow misted over in thin layers after being decanted into a very small jam jar. I did not want to re-create the same solid chrome yellow as my recent B24 Assembly ship. Here it is:
p?i=51a8e8516f8ad5de07d7643ca5ec34dc
Next up is to mask and paint the rest of the easy bits. For the Tiger stripes I will try 2 solutions. At the front with the wider strips, I will use thin strips of masking tape cut with wiggly edges followed by the black. For the rear, the black stripes are much shorter and thinner. Here I plan to paint the back end of the model black and then use very small Blu tack sausages for the black areas, followed by the grey.
Regards Toby
  • Like 11
Nice job with painting the yellow, Toby, I like the colour too
James
Well the stripes on the front part of the plane have been masked.The back of the plane will have blu tack sausages for the tiger stripes as they have a slightly different style than the stripes over the yellow. Make sense ? , maybe. Any way here is the black paint on and the masking removed. Some fine oversray on the edges of the stripes is whats needed next I think.
p?i=456b262d1d24d6b698551d7c62a8ed8d
p?i=fb8671ab614968a78a6f9b350cfd6a2b
Regards Toby
  • Like 11
I checked the yellow colour on the other RNoAF F-5A tiger (208) at the Gardermoen museum today. It seems that RAL 1033 was used. A less bright yellow than what you have used. Assumedly the same colour/paint was used on 134.
Thanks Nils for the info, I think I will stay with the yellow used.
Since posting yesterday I misted over a thin coat of clear orange as the yellow did not quite look right. Like most planes, the exact shade of the original colour depends on the weather when the photo was taken and the film/camera settings. I also softened down the edges of the black stripes by spraying a very thin freehand soft edge to the stripes to more closely replicate the original plane.
Here is the state of play today.
p?i=2020c67221d789f30e085ed23d0a1b95
Regards Toby
  • Like 9
Well I went a bit overboard on softening the black stripe edges and now there is not enough yellow left. Had I used black enamel I could have easily removed it but the laquer dries to fast for that and would have taken off the yellow as well. Hey ho, re-learning something I already knew. Next step is a new layer of grey primer followd by pink and yellow again. Then its plan B for the black stripes.
p?i=298eb82169d9b82a534a1c16e7c65e04
Regards Toby
Here we again with nice yellow model plane. Only Tamiya TS Chrome yellow used this time.
p?i=402c71bc5236a704e2548dd38d6a6b37
My friend Dag Roger in my local IPMS branch who knows there is to know about F-5 kindly pointed out that the RWR receivers are missing from the nose and the fin. The nose sensors will need a bit of trial and error plastic surgery. In parallel I will be trying out blu tack masked stripes on my paint mule this time.
Regards Toby
