My submission is another 1/24 build Hurricane. I'll be doing my best to get work done here, as well as finish up some details on a previous project so it isn't just looking pitiful sitting in a corner
Don't have any history to share of these particular acft and their squadrens.  Life has been more than a bit busy these last few months, and I haven't had the free time to get much done outside of Family events and work.
20250802_152625
Probably going with this scheme.
20250802_152816
20250802_152843
The wings have a wierd line on both upper and lower panels. Almost like they were crushed, but they don't appear to be. The box was packed well, and shows no damage.
20250802_153244
20250802_153251
The fusalage halves look fine. We will press on.  Overall it looks like a nice kit. A little different than the Airfix kit, but similer in many aspects.
  • Like 9
A 1/24 scale cannon armed IId - that will be quite the beast when built! By all accounts that is a decent kit, so hopefully it proves an enjoyable build and provides some good down time outside of real life. Welcome to the build. 👍
Great to see one of these big beast's here I'm building the MKl outside of this GB and it's been hassle free so I'd expect you have no issue's either.Good luck.
A few hours of free time this afternoon so let's get some work done shall we.
Obligatory Sprues pics.
20250804_135717
Good detailing
20250804_135825
20250804_135854
Good detail, won't really be seen.
20250804_135902
Big guns!
20250804_135945
20250804_140046
Various bits and pieces.
20250804_140026
20250804_140135
20250804_140208
20250804_140245
20250804_140332
Overall the parts have good detail that should show up nicely when complete.
Several parts won't be seen once buttoned up.
20250802_152639
Time to build.
Happy Birthday to my oldest Grandson,  Finn.
On the 26th we fly from Houston to North Carolina for the youngest 2nd Birthday.  Miss lily is growing to fast.
  • Like 10
Despite all that plastic it doesn’t look an overly complex build. And yes, some very nice detailing. Should look fantastic when done!
Agreed with that thought.
I'll get the sprues washed and start shooting some primer at pieces.
Still have a Revell 1/32 kit waiting as well.
Screenshot_20250802_162043_Chrome
d9b81488dcc7baeef1c4d4b5ae96c238
Skipped the cockpit for now and started on the engine. Will get some painting done on Friday. These parts are all pretty clean will far less flash than the airfix kit.
I'll work on some of the cockpit Friday as well as get fusalage interior painted.
20250805_180402
20250805_180720
That's it for today.
We'll be back.
  • Like 11
9 hours ago, Wings unlevel said:
Hope there won’t be too many dark nights getting this one built. 😂
Yes hopefully. Cause ya know, for night is dark and full of terrors, and Winter is coming.
  • Haha 2
Major parts test fit to hopefully avoid fitment issues later.
Released the fusalage, Wings, firewall, gear bay panels from the sprues.
Gear bay, and firewall needed a bit of sanding but not to much.
The upper wing panels show a bit of gap that I'll need to check a bit more. Looking to avoid excess putty filler.
The wing joins the fusalage pretty clean for the large bottom section.
Gear bay needed minor sanding, and shows fairly tight joint all around.
20250808_111126
20250808_111144
Main firewall slots into place well. Needed a little sanding. The front has a bit of angle that needs to be observed as part of the wing dihedral.
20250808_111303
The backside of the piece is the front of the gear bay. Fits decently.
20250808_111246
20250808_111425
20250808_111747
The major assembly seems to go together fairly well.
20250808_112001
20250808_112007
20250808_112022
20250808_112114
getting back to the engine and cockpit assembly now that this has been checked.
  • Like 13
Trumpeter marking research is notoriously poor.
KX413 is a Mk.IV, not a IID,  is not a trop version, and the codes are Sky, and serial is black. Code letter maybe M as well, and likely the roundel colours are wrong,  and if the profile is right, then some are mis proportioned as well.
This is KX413
Mk.IV have added radiator armour, an up armoured windscreen and added applique armour under the cockpit, late IIDs have the same fuselage armour added.
There were very few IID's used in the UK, mostly by 184 Sq.
You may find this of interest then, has pics of BP188 as well, and link to film in the desert.
https://www.britmodeller.com/forums/index.php?/topic/235071194-hurricane-iid-6-squadron-leading-edge-wing-stripe-and-some-marking-observations/
IID were also used in Burma by 5 and 20 Squadrons.
HTH
Doesn’t look like there’ll be too much to sort out when it goes together.
Agreed, spent a few hours in the evening cutting out various bits and building sub assemblies.
Didn't get around to any painting yesterday. Hopefully  next week when I come off shift I'll take a day to get some done.
I need to do some research based on what Troy has provided. Might just need to paint the proper squadren codes.
Building up as much of the small assemblies as possible.  Should reduce total time for the build and let me paint more in one sitting.
Exhaust stacks, these will need sanding after sprue release.
20250809_100450
Rudder, elevators, radiator internals, fusalage fuel tank and more engine bits.
20250809_100531
20250809_100321
20250809_100351
the fusalage fuel tank will be hidden once installed, so it will not be painted. Same for the wing fuel tanks.
The rear of the engine won't be seen, so minimal detail work will happen. The sides will get some attention, but most of it, will not be seen.
Back to night shift tonight.
  • Like 9
I always enjoy putting together sub assemblies, an always satisfying way of feeling like you’re making progress. 👍
Off night shift this morning. It's my tired day as I work to get turned back to dayshift for Friday morning.
Managed to get a little paint thrown on a few of the pieces. I'm choosing to paint this how I want which may not be perfectly historically accurate but it's nothing to wild. We can think of this 2 ways.
1.  I'm on the Star Trek Kelvin alternate timeline so what ever I do, is correct.
2.  This is GL's freshly restored acft, and I choose to have it painted this way. Current acft have all sorts of colors on them, so whatever I do is correct.
Various bits
20250812_160025
Firewall action
20250812_160122
Cockpit framing,
20250812_160400
20250812_160431
20250812_160529
Decided to paint fusalage walls a bit lighter with the grey green. I'll use the cockpit green for some dry brush shade tones.
20250812_160151
20250812_161002
20250812_161919
Will be doing highlights with some drybrushing. As well as adding several sidewall bits that need to go in.
Will spray the black pieces tomorrow and see about getting the rest of the engine bits on.
Still have several Cockpit pieces that will need to be brush painted.
Not planning to show much in the way of weathering. Just enough for some good contrast.
Edited by glwanabe
  • Like 10
Just catching up on this monster 1/24th scale build and its looking quite good. Personally, I'm not a huge fan of all those rivets, however in this scale it's probably well justified.
Cheers and all the best going forward... Dave
I figure whoever is paying for the paint gets to decide what paint gets used!
Looking great so far — nice work! How are the decals in that kit? Trumpeter can be a bit hit-and-miss with quality. I’m really looking forward to seeing it all come together; it’s going to be an absolute beast!
9 hours ago, stevej60 said:
Brilliant progress on the beast.
Thanks Steve, didn't get much done on Thursday. Hoping to get a little done this weekend.  I'm not a fan of the instrument panel design as supplied.
Might have to look into something aftermarket.
I hadn't built a Trumpeter kit before. The plastic is pretty nice, and the decal sheet looks good.  We'll see once I start applying them.
I'm considering an attempt to paint the code letters and serial numbers.
A word of warning on Trumpeter decals,I find the colours too bright and I had a nightmare with the 1/32 Spitfire build needing after market after they just
fell apart,also for my MK1 currently being build I simply bought Techmod decals for the same colour issues added to that the same issues for this GB with
their sister company Hobbyboss on their Hurricane IIc where again AM decals were needed their favourite error is supplying the gray codes in white!
Good to know!  I was considering a set of techmod if I could find some that would match a unit of this acft. Seems like I might need them just for basic roundels and such.
Edited by glwanabe
