Here is my second participation, supposedly "the easy one".
Inside the little bag: a few injected plastic parts, metal rod for the tail booms and decals x 3.
Many small manufacturers tend to be more exhaustive on the history of the subject and on details like colours. The references used are also very useful. I like that!
Did I say "easy"? Well, I have a problem with ease. That airfoil is all wrong and must be corrected!
Some progress for soon.
  • Love 3
3 hours ago, CarLos said:
"the easy one".
Well it was!
It is a lovely feature which seemed to die out, and I guess there's no need for it nowadays with the internet.
My 'real' interest is in how Mark @2996 Victor lists this- arabic 12 at the start on latin script twelve later on?
Being serious, a cute little chap for those of us not making it and clever to see some metal rod instead being used.
Delighted this GB is bringing out all these unusual kits, where else would you see one of these getting built :yahoo:
Best of luck
Cheers Pat
  • Agree 1
  • 100% 2
Small update: sanded the underside of the wing and glued plastic card to correct the airfoil. I divided the plastic in 4 parts to minimize the chance of bowing later, but only time will tell if I succeed.
Here it is, ready for primer.
I am also thinning the fuselage, as the plastic is very thick. Boring... I will replace the tail booms because they are too thin. Fortunately I have a good stock of rod in various dimensions. Brass or steel? That is, "easy" soldering or silver soldering (a first to me)?
I am almost sure that the RAK-1 flew in varnished plywood but need to read more on the subject.
'Till next!
  • Love 2
16 hours ago, AaCee26 said:
That's such a crazy kite that I want one!!!
AaCee
Good luck to find one! I only knew about 12 Squared when a local hobby shop was closing and selling all the "hidden from the shelves" stuff. I also had a good deal on Esoteric vacs. May be the CMR kit will be easier to find.
  • Love 1
  • Agree 1
Ha! I once had a 12th Square kit, an MS L, and it was sold as soon as possible😅
CMR looks more promising. Even a good set of drawings might help to start...
AaCee
  • 2 months later...
A small but very important update - I wouldn't  be able to proceed without being able to solder with precision the tail booms. I always made a mess with that kind of job, so I was very careful. And it worked!
I started by making a 3d model of the booms:
It allowed me to print a drawing of the booms, and to mark with a blade on particle board the location and the exact dimension of the parts. Then I enlarged the grooves with a P-cutter and with a triangular file.
Then I placed the accurately cut brass rod (I used 0.7 mm diameter) and taped
Put a bit of flux with the tip of a toothpick and next cut a tiny piece of solder (shown in front of the toothpick) over the joint. Then, a touch with the tip of the soldering iron and voila - an almost perfect joint, for my soldering skills.
The tools (sorry for the messy desk)
And here is the pair!
I am really happy for achieving this. Now I can think about WW1 booms, sturdy undercarriage legs and other things that would be impossible without this skill.
Carlos
  • Love 2
Superb work, Carlos, very neat soldering - something I always struggle with.
Mark
