After coming to an abrupt halt on the WW1 torpedo boat, due to 'technical' issues. I've decided to go up scale with this one, it's been sitting, gathering dust for ages and I think it's time it saw the light of day. Heaven only knows where I'll be putting it when it's finished, but I'll worry about that when the time comes.
I think I need more shelves, there is an MTB in the same scale lurking somewhere, be nice to have the two opponents displayed together.
I know this is not a perfect kit and has known faults, including the propellers which are wildly inaccurate, I've tried to source replacements but to no avail, I know they are out there, I just can't find them.
I really should try this 3D printing one day.
I'm going to, as is my habit, add a wooden deck and many bits of brass PE.
I've got a tin of Schnellbootweiss from Resolution Hobbies, it's in one of the 14ml tins, so I hope its enough (there is an awful lot of plastic in this scale) or I'll be paying a visit to @beefy66 in the not too distant future.
So, without further babble here are the bits......
p?i=1cd9bdcc857eefc6aeb050264113cf38
As you can see, a vast expanse of grey plastic. That's a 12" rule !!!!!!
p?i=c8cecb4195b7b736920962f679ee015f
But the smaller parts seem nicely moulded and reasonably flash free.
p?i=e10954d19972abbb3b6631d05afab53e
p?i=55e31cfb43d2e6563bd426194fb9cd5c
The wooden deck bits
p?i=efe5edb2654186ef6538c8a43b421de2
And many bits of brass.
p?i=a2e4a70d3ede212800cf53fc54a94308
I would normally make a base from wood and brass rod, but that'll be a bit large, so I'll use the included base.
Jon
  • Like 12
Hi Jon,
I have my a lot of 3D models from my s-boot build and they include the 3 propellors (LH prop below) which I think will work OK at 1:72nd.
prop
If you need upgrades to the kit parts, just PM me
Steve
And off we go.
I'm sort of following the build instructions :whistle: a very rare occurrence. So am adding the PE parts to the inside of the bridge/cockpit.
p?i=e50445e7b82b9fcd07e7f43ecce5bc68
With the aid of my new toy. I saw this on another WIP log and thought it was good idea, and I was not wrong. It works splendidly, already wondering how I managed before.
Jon
All the PE is on, now to spray.
I'm painting  before assembly otherwise, that way I can get into the nooks and crannies.
p?i=59ee1698428ca72f684a585af9181da7
Hi Jon
The sprint is on 😁. Hope I can keep up.
cheers
Graham
That looks very good from my position of 5 laps behind you😁
Always nice to see a Schnellboot build. The next upscale after this is the 1/35 S100.
At 1m long, it’s still in my stash, waiting for a space to build.
Will be watching this build.
I'd have a job to get it in my workroom :yikes:
Jon
I've got a wooden deck set for this and this is the piece for the bridge floor.
p?i=82eb752c868d9f77fccc3847b5257a7a
As you can see, the floor is actually slats/duckboard and if I put this deck on it, the slats will disappear, so.............
p?i=4ae5af786b7223463bf7b7494bad1839
I'll separate the individual planks and stick them on the slats.
p?i=2cc4d6cb4ef37b791c4d795becad26b0
Much better.
p?i=dbed43e3af4542f14786f64b40dc83a3
  • Like 12
  • Love 1
Jon
Had a quick look at this on thier website, looks the dogs, I can think of loads of ways I can use this. Did you buy it direct from the manufacturer?
Yes. I got the one with 4 clamps, not cheap, but I thought if I get the 2 clamp one I’ll need 4, Sod’s Law being what it is.  Fast delivery, ordered Saturday, arrived yesterday.
Just ordered my set - the 4 clamp one like yours. 😄😄😄😄😄😄😄
Can anyone tell me what the deck railings would be on the boat ?
The kit comes with these..........
p?i=3feb7b3f7eb8efd6ea4759dbe840d70a
Which are fine, but I'm wondering if they should be stanchions with a chain or cable between them.
On some photos I've found they look like chain/cable.
Jon
Hello Jon.
As an example, I could show you my 1:35 Italerie boat, which I built in 2014.
AP1GczNZrAYUX_cpu84QOSc6r-WgPgEw5ASUOpCL
Here you can see that it is partly a chain.
AP1GczMmYVZoVGt4fHnjb0wSyUFqdU0vB6vfCsnh
At the stern, rope was then passed through eyelets.
AP1GczNCklFiV3oDpPUDWaZc-vo-PvXffmZPN6Ah
Of course, I can't tell you how accurate Italeri's research was.
AP1GczM8W94TpxqmDGJGI3bB2mQ1Zb7JGOdiTfkH
Then I have this photo which shows the area where the chain was taut, between the two torpedoes.
You can see a metal bar above and behind it, and a steel cable underneath. Unfortunately, the two sailors are standing in front of the gap where my chain is. It doesn't appear to be a chain, but it looks like the railing could have been opened there.
AP1GczPz-PEossE-xbfzlmpxtQSnvYUrLig0ekYh
I hope this helps you a little.
Thanks for this, that is an excellent model.
You’ve backed up what I’ve found online and in the couple of books I have, some of the railings are solid, some are wire, with chains where gangways would lead to dockside.
I think that’s what I’ll do.
Jon
  • Agree 1
Thanks, Jon.
Maybe another tip. I don't know what armament you want to depict; my model has a massive flaw.
Aside from the fact that the color scheme on my torpedoes is wrong, if you like I can ask my specialists what color the torpedoes on the speedboats were. Did the boats carry either the torpedoes or the sea mines? Never both. The boats were made of wood and couldn't bear the weight of both, so it was either/or.
16 minutes ago, madtatt said:
Thanks, Jon.
I'm sticking with the guns that are with the kit, as the PE set has many parts to enhance their detail.
This boat is carrying torpedos, which the instructions would have me paint as follows....
Fins....Steel
Nose.....Copper
Body.....Semi matt brown or Light copper
But if you can get a more accurate scheme, then many thanks
Jon
I a tissue paper from a shoe box to cover mine to make the canvas dodgers.
Keith
Keith
That is also on my horizon, I might keep the forward bit on the railings as per kit, solid, and cover with a dodger and then use stanchions I have found online to finish the rest with cord, to look like cable.
Jon
Hey Jon.
There's a real debate among scholars about the exact color scheme of torpedoes. In Germany, by the way, they were also called eels. The torpedoes, not the scholars. 😁
So, there's agreement on the basic body. It was steel-colored and well-greased.
The heads vary between copper and dark gray. Most people say dark gray. The only thing that's certain is the training torpedoes; they were red and white striped or had a yellow ring. What colors does the kit specify?
Edited by madtatt
🤣 LOL 🤣
Internals of the cockpit finished.
p?i=b32e0a96047e43fc51e6c1118f22b4ef
Slats on one side done
p?i=269c6bd1659456f726846fbd17c36050
Fins....Steel
Nose.....Copper
Ok, Jon.
What I can say is that the torpedo body itself was an unpainted, bare steel tube that was frequently coated with grease by the crews to increase its seawater resistance and the stern was made of either polished steel or brass.
Nose can then be copper, but as far as I know it is mostly dark grey.
What I can also say is that I really like your model so far. 😉
