This will be my kit for this GB. I picked it up recently and after a bit of research realised that New Zealand's army bought a fair few of these tanks, mainly Mk2, Mk3 and Mk5 variants. Because the kit is a Mk2 this'll most likely be one that was used for training in New Zealand, (I'm waiting for some decals to turn up so I will be a bit more precise soon.)
I also bought a couple of books to help me on my way.👍
p?i=385e722947563c1d0fe9de807633ad53
p?i=45dd848a11d60755aba0c65a1cd18a8d
I am currently finishing off another project so once that is done I can get on with this. All the best. :thumbsup:
  • Like 10
25 minutes ago, Milan Mynar said:
That's an interesting topic, I'll follow it.
Good to have you along Milan. I will get a proper WIP set up this evening and then the fun can start.:thumbsup:
  • Stef N. changed the title to Valentine Mk.II "Ngara"
The sprue shots. Typical Tamiya in that it is well detailed but not overly busy. Should be a relatively straight forward build.
p?i=b60d5f9a630f01511f57f2d0f68cb5aa
And some decals from Firestorm of Australia.
p?i=78ff0307bf6b7ec6764f42a489810a3a
And a colour view of the tank which I will try to attempt.
p?i=1e36a62cc6f1a2a1ea6fd816c877f0e8
There aren't many photos of this so its camouflage will have to be a rough guesstimate. It looks angular, similar to Caunter but with earthy colours. If anyone has a good knowledge of the colours the NZ Army used I am more than happy to hear your view.
Cheers all.:thumbsup:
  • Like 9
Well, this is going together with no problems whatsever. Tamiya the masters of model makers. :thumbsup:
The shell is mostly complete.
p?i=89e13510f11ff0e2bec39aa669f301f1
p?i=f97fd1e825922dd51178c05efb901a26
More tomorrow hopefully. All the best.
A Valentine!  Very attractive design, and under-appreciated in my view.  I had no idea anyone was still using them in 1960!
  • Agree 1
The more I study it the more I appreciate its design. A simple light tank that done its job (mostly). 👍
Your build looks very good, I will be following it closely. I have built Valentine tank models from various manufacturers, not from Tamiya yet. I expect the build to be a relaxing affair.
2 hours ago, Muchmirth said:
Looking forwards to see you do this! I like the look of the scheme.
Cheers Paul. Thanks to the input of Kingsman I know what colours I will be using, with a help from Mike Starmer's paint mixes too, but I am hoping the NZ Army Museum get back to me about the camo pattern, or it's likely to be a rough guess.👍👍
  • 100% 1
A small update. I have the wheels and most of the body done. I need to paint the lower parts now as the link and length tracks will not fit if the mudguards are in place. Day off tomorrow so I will spend it painting.👍
p?i=9a0dec3564c6b6e7cf969a688d771528
Edited by Stef N.
Added photo.
  • Like 9
Thanks lads. I got the base coat down, using Mike Starmer's Tamiya mix for Khaki Green G3. A nice mix and good colour. The tracks have been base coated with a mix of Dark Iron, NATO Brown, Satin Black and a dash of red. It works rather well.
p?i=d306d339de3e0650044a960ae8cca8cc
Cheers all and have a great week.:thumbsup:
1 minute ago, Milan Mynar said:
You're going full throttle.
No messing about Milan. I couldn't finish my last GB so I am making sure I get one in the gallery this time. 😁👍
Excellent work so far!  How did you accomplish such a neat paint job on the rubber road wheel treads?
Thank you. I paint the rubber black first and then use a Helix Circle Template as a mask and paint the interior. Quite a cheap piece of kit and effective.👍👍
Cheers lads and good evening. Body now built and ready to paint. The wheels and tracks have already been painted and will need careful masking before any paint is sloshed around. I'll have to remind you all that this kit is ace. Absolutely no problems whatsoever (except me putting the periscopes the wrong way round😳).
p?i=336577bf83bb8e5a30d19e5d9c66ccc5
p?i=462e29c5d9430b81d8c8c61232b2e9d0
Anyway all the best and I hope all your projects are going to plan. :thumbsup:
  • Like 10
I have had good results with index card and tale for masking tank tracks that are already painted.
Thanks for that. It should be a reasonably straightforward masking job, probably. 😁👍
