Phoenix44 Posted February 13 Posted February 13 The part that I think the OP refers to is this apparently much darker panel which corresponds to the panels missing in the loading pictures. In this other picture, 3-F has a conspicuously lighter panel which doesn't match the camoflage pattern and which looks like the panel on the aircraft on the left of the original photo. https://i.ibb.co/jc8Y7cL/Spitfires-on-the-USS-Wasp-for-delivery-to-Malta.jpg 3
Tail-Dragon Posted February 13 Posted February 13 In the above photo, they apparently played quite a bit of 'mix and match' with the cowl side panels. One thing I noticed, the spinner colors. The 'Temperate scheme' as originally painted, would have had Sky spinners (light color), and the 'Tropical scheme' would have had Red spinners (dark color) - 3*F and 3*B have quite a dark lower surface (Azure blue?) and a dark spinner. 3*D has what appears as a 'Temperate scheme'. Is that a clue to the 'as loaded' schemes?
Troy Smith Posted February 13 Posted February 13 50 minutes ago, Tail-Dragon said: and the 'Tropical scheme' would have had Red spinners (dark color) Just for clarity, AFAIK there was no 'tropical scheme'*, The scheme used in the tropics was Temperate Land Scheme uppers Red spinners were a Mediterranean theatre marking, not factory applied. the factory applied colour was black or the relevant upper surface colour The artist, Elsie Dalton Hewland has a near photographic eye for colour and detail. @Paul Lucas the wing joint strip on LD297 and the DFS Hurricane behind is worth noting. *it has been discussed that there was a Dark Green/Middle Stone scheme, there are papers for it and possible photos. HTH 1
brewerjerry Posted February 13 Posted February 13 (edited) 33 minutes ago, Troy Smith said: ...... The artist, Elsie Dalton Hewland has a near photographic eye for colour and detail. @Paul Lucas *it has been discussed that there was a Dark Green/Middle Stone scheme, there are papers for it and possible photos. Hi apolligy for slight thread drift interesting painting it appears to have a 193Sqn Typhoon DP-N I have a copy of the memo dark green / mid stone from the na/pro on a harddrive cheers jerry Edited February 13 by brewerjerry not had first coffee yet
11bravo Posted February 17 Posted February 17 (edited) On 2/12/2025 at 3:11 PM, Graham Boak said: Ship store paint would affect the performance of the aircraft. Try explaining that to Churchill or Roosevelt, But these aircraft had already been repainted in the UK, once before delivery to Glasgow for loading and once after "Jumbo" Gracie had complained that it wasn't right. Just who is going to authorise a repainting again using unsuitable materials under unsuitable conditions? Certainly not Gracie. Was the captain of the Wasp looking for a court-martial? These photos do show a neat finish which would simply not have been attainable. I grant you that aircraft on the first trip (Calendar) look pretty much like a rush job, which is probably why the whole idea arose, but these on the second trip (Bowery) are much neater. Both Color Conundrums (which now seems to have set the standard for research into these paint schemes) and Cauchi's earlier book both present convincing evidence that these aircraft were indeed repainted on Wasp, using non-RAF paints. Given that we'll probably never find conclusive evidence either way, you, of course, are free to believe whatever you want to. Whether they used Deck Blue paint or the new color that Wasp was testing on some of it's air wing F4F's is irrelevant since, per Dana Bell, the aircraft paint was supposed to be have been a match for Deck Blue. On a related note, are there any pictures out there of Spitfires on Malta still wearing the "temporary" Wasp delivery codes? I always wondered about that aspect of those paint jobs. If they were used for nothing more than sorting out the aircraft for their deliver flight to Malta and were then supposed to be been quickly removed, why did they go to such trouble to paint them on so uniformly, in the same size / layout as squadron codes, when they could have simply just chalked on the codes by hand and wiped them off upon arrival on Malta? Edited February 17 by 11bravo
uncarina Posted March 12 Posted March 12 (edited) Here is my interpretation of the subject aircraft, using U.S. Navy blue-grey and deck blue. It’s a 1/32 combination of the Laminar Flow Designs Vc conversion, with a combination of the Kotare Va and the Tamiya IXc kits. https://flic.kr/ps/45mWu9 Cheers, Tom Edited March 12 by uncarina 1
Troy Smith Posted March 12 Posted March 12 10 minutes ago, uncarina said: Here is my interpretation of the subject aircraft, using U.S. Navy blue-grey and deck blue. It’s a 1/32 combination of the Laminar Flow Designs Vc conversion, with a combination of the Kotare Va and the Tamiya IXc kits. https://flic.kr/ps/45mWu9 Cheers, Tom using the flickr share option 2
uncarina Posted March 12 Posted March 12 (edited) Thanks. The Flickr and Imgur share options aren’t working for me on this forum (the link I added is the share link, won’t work in the “insert from URL” box) maybe an I-Pad issue. Cheers, Tom Edited March 12 by uncarina
Troy Smith Posted March 12 Posted March 12 32 minutes ago, uncarina said: won’t work in the “insert from URL” box common problem, as it seems the obvious way, but you just need to paste the link in the reply area, and the forum software does the rest. same with images, copy image URL, paste in here. HTH 1
gingerbob Posted March 12 Posted March 12 6 hours ago, uncarina said: It’s a 1/32 combination of the Laminar Flow Designs Vc conversion, with a combination of the Kotare Va and the Tamiya IXc kits. My goodness, that's an expensive recipe! The result looks very nice, but (forgive me) from that one image it looks startlingly like a later-camo Fighter Command Spitfire. That is, the colours seem rather orthodox- not what we've come to expect from Malta Spits!
uncarina Posted March 13 Posted March 13 On 3/12/2025 at 2:22 AM, gingerbob said: My goodness, that's an expensive recipe! The result looks very nice, but (forgive me) from that one image it looks startlingly like a later-camo Fighter Command Spitfire. That is, the colours seem rather orthodox- not what we've come to expect from Malta Spits! Not necessarily. You just need to buy the LFD conversion, the Kotare kit, and a few Tamiya sprues. Not a late color Spitfire at all. The USS Wasp would presumably have had USN Deck Blue and USN Blue-Grey paint, per accounts from the Colour Conundrum Compendium and Malta Spitfires books. Rendering my build black and white shows a resemblance to the period photo. Cheers, Tom
uncarina Posted March 13 Posted March 13 On 3/11/2025 at 8:22 PM, Troy Smith said: common problem, as it seems the obvious way, but you just need to paste the link in the reply area, and the forum software does the rest. same with images, copy image URL, paste in here. HTH Thanks Troy, my original post had the share link in the reply area as well. Apparently it is an I-Pad Safari issue. Cheers, Tom
