Heather Kay Posted November 11, 2024 Posted November 11, 2024 On 09/11/2024 at 01:28, Dunny said: Lots of other things which I have yet to get my head around While I remember I recommend getting a copy of the Wingleader photo archive 23 on the Manchester, plus Warpaint 103 which has 1/72nd scale drawings which are helpful if perhaps not 100% in all details. For my build I’m investigating ways to get the various stencil markings reproduced. They’re essentially the same as the Lancaster but in light grey/white rather than red as the Airfix transfers have them. Still working on that. 5
Dunny Posted November 11, 2024 Author Posted November 11, 2024 10 hours ago, Heather Kay said: While I remember I recommend getting a copy of the Wingleader photo archive 23 on the Manchester, plus Warpaint 103 which has 1/72nd scale drawings which are helpful if perhaps not 100% in all details. For my build I’m investigating ways to get the various stencil markings reproduced. They’re essentially the same as the Lancaster but in light grey/white rather than red as the Airfix transfers have them. Still working on that. Wise words Heather - thank you. I shall probably duplicate what's on Airfix sheet and use a combination of printed decals and cut stencils as appropriate
Dunny Posted November 11, 2024 Author Posted November 11, 2024 Hi All, You can see that I've done some early work on modelling the business end of the Vulture: You can see that I've added in a couple of panel lines (these are 0.2mm circles swept around a guide curve which was projected onto the relevant surface from a sketch). The radiators still require some finesse, but once I have the kit (and thus correct wing profile) I can then start modelling the rear portion of the nacelle, Thanks for looking, Roger 15 1
bigbadbadge Posted November 12, 2024 Posted November 12, 2024 Ooooooo nice work Roger. Looks good on screen. Chris 1
John_W Posted November 12, 2024 Posted November 12, 2024 How times have moved on. I have a vintage Airfix Annual for Modellers from the early 70s featuring a Manchester conversion using balsa wood carved to shape and sealed with dope and talc. 1
Dunny Posted November 12, 2024 Author Posted November 12, 2024 1 hour ago, bigbadbadge said: Ooooooo nice work Roger. Looks good on screen. Chris Thanks Chris - I've made some progress with the rear of the nacelle, which is a bit more complex! 12 minutes ago, John_W said: How times have moved on. I have a vintage Airfix Annual for Modellers from the early 70s featuring a Manchester conversion using balsa wood carved to shape and sealed with dope and talc. And no less valid a path to the same result! 1
Dunny Posted November 13, 2024 Author Posted November 13, 2024 Hi All, Some progress with the Vulture! I think I've now got the basic shape reasonably accurate: The intersection with the wing I will sort out once I have the profile. I'm considering incorporating the upper section into the wing itself but have yet to figure that out - may require a couple of test prints. You may also note that I've left the rear end of the nacelle dangling. As on the Lanc this section was incorporated with the flap, so I shall replicate this detail (possibly with a view to having the flaps extended). Note also that the panel lines have temporarily disappeared, as victims of the overall accuracy of the profile. They shall return, Thanks for looking, Roger 14 1
bigbadbadge Posted November 13, 2024 Posted November 13, 2024 Nice 3D wizardry Roger, or shall we call you Dunnybledore😉😄 great work fella it is fascinating to see it progressing. Chris 4
Dunny Posted November 13, 2024 Author Posted November 13, 2024 15 minutes ago, bigbadbadge said: Nice 3D wizardry Roger, or shall we call you Dunnybledore😉😄 great work fella it is fascinating to see it progressing. Chris Careful - that could stick! 🤣 3
Dunny Posted November 13, 2024 Author Posted November 13, 2024 Hi All, Before I disappeared too far down a panel line rabbit hole, I thought I'd throw a few on and then export an STL file just to check out the lines themselves. Here's the STL file opened in Chitubox, which is the slicing software I use: I reckon those should come out nicely and don't look overcooked for 1:72? I can now continue to add detail - radiators, oil coolers, exhausts etc. - this is fun! Thanks for looking, Roger 15 2
Dunny Posted November 13, 2024 Author Posted November 13, 2024 By the way, if anyone is looking for a more detailed tutorial on applying panel lines there's a great one here: 3
Dunny Posted November 13, 2024 Author Posted November 13, 2024 Hi All, Thinking ahead to the interior build, I wondered about the bomb sight fitted to the Manchester? My money is on the Mk.IX Wimperis: Any other information gratefully received, Cheers, Roger 2 1
TeeELL Posted November 13, 2024 Posted November 13, 2024 1 hour ago, Dunny said: By the way, if anyone is looking for a more detailed tutorial on applying panel lines there's a great one here: That is just the thing I was thinking about asking you. I’m no fan of panel lines on 1:72 scale models but there are a couple of lines that should feature on my Canberra forward fuselage replacement. 1
Rabbit Leader Posted November 13, 2024 Posted November 13, 2024 Looking just fabulous Roger and although you're putting in lots of time and effort here, I’m also hoping it may entice some mainstream manufacturer to finally produce an OOB Manchester kit. Cheers and all the best.. Dave 1
Dunny Posted November 13, 2024 Author Posted November 13, 2024 15 minutes ago, Rabbit Leader said: Looking just fabulous Roger and although you're putting in lots of time and effort here, I’m also hoping it may entice some mainstream manufacturer to finally produce an OOB Manchester kit. Cheers and all the best.. Dave Much obliged Dave! If they do not, I may make any successful results available to this discerning community (Happy to entertain trial build candidates) 🤩 1
Rabbit Leader Posted November 13, 2024 Posted November 13, 2024 2 minutes ago, Dunny said: Much obliged Dave! If they do not, I may make any successful results available to this discerning community (Happy to entertain trial build candidates) 🤩 Happy to oblige Roger and would be willing to clear the workbench to get started on a Manchester. Cheers.. Dave 1
Dunny Posted November 13, 2024 Author Posted November 13, 2024 2 hours ago, Rabbit Leader said: Happy to oblige Roger and would be willing to clear the workbench to get started on a Manchester. You'll be first in the queue Dave 1
AliGauld Posted November 13, 2024 Posted November 13, 2024 That's all looking brilliant. This is going to be fairly spectacular. It's all Dark Magic, of course. Shouldn't the name change be DunnyBrasco though. Cheers, Alistair 6
Dunny Posted November 13, 2024 Author Posted November 13, 2024 8 hours ago, AliGauld said: That's all looking brilliant. This is going to be fairly spectacular. It's all Dark Magic, of course. Shouldn't the name change be DunnyBrasco though. Cheers, Alistair Thanks Alistair - as opposed to Gauldalf the White? His projecting thinners spell is quite the thing 🤣 2
Jeff G Posted November 14, 2024 Posted November 14, 2024 12 hours ago, Dunny said: You'll be first in the queue Dave If we’re starting a line… 2
Rob S Posted November 14, 2024 Posted November 14, 2024 3 hours ago, Jeff G said: If we’re starting a line… Did someone say “Manchester Line here!”? 1
Dunny Posted November 14, 2024 Author Posted November 14, 2024 Hi All, Some progress on the Vulture! I found this rather lovely picture, which shows all sorts of details on the Vulture: From this I was able to knock together an exhaust model: I spent a while fluffing around trying to bed the base into the nacelle, until I figured out that I could surface-mount it just as easily. You can see the location peg on the underside, which will fit a corresponding 'ole on the nacelle. I can therefore have a non-handed, single component for all four positions - nice 🤩. In other news, I have confirmed that the Manchester was fitted as standard with the Mk.IX CSBS (Course Setting Bomb Sight) at this stage of the campaign. The later Mk.XIV was evaluated on a single aircraft, but only introduced in volume on the Lancaster. I shall therefore add a Mk.IX to the list of items to be designed and printed. Thanks very much to @Shep65 and @T-21 who provided the vital nuggets of information over in the WWII questions thread. Here it is for anyone interested: Thanks for looking, Roger 15 1
bigbadbadge Posted November 14, 2024 Posted November 14, 2024 Cracking work on the exhaust design Roger. Chris 1 1 1
