F1Fan Posted October 25, 2024 Posted October 25, 2024 I have one of these compressors I acquired secondhand. Barely used. 1, Does anyone have a manual they could send me pictures of if possible? 2, How do I set this up as a beginner? It is all assembled and doesn’t leak but what is a good starting point to set the pressure regulator at as a newbie to this? I have a Badger Xtreme Patriot 105 with it. Thanks for all advice
szeregowy Posted February 19 Posted February 19 Hi @F1Fan. I have exactly the same compressor so will be happy to help. Regarding set up, the pressure will depend on the application. I usually keep it at around 20psi, but for finer details and if I spray closer to the model then I drop it to around 15psi (very thin paint mixture). Do you still need a copy of the manual?
