Billos Posted December 11, 2024 Posted December 11, 2024 On 08/12/2024 at 05:00, Hook said: My last attempt was a bit of a disaster - the aluminium paint dit not perform well, making a lot of sanding and paint removal necessary @Hook I sympathise, I also experienced aluminium disaster requiring complete rubdown and start over. But it worked out in the end. You Are Not Alone! 1
Hook Posted December 11, 2024 Author Posted December 11, 2024 Thanks all! I have high hopes for the weekend. Cheers, Andre 1
Hook Posted December 29, 2024 Author Posted December 29, 2024 On 12/11/2024 at 7:50 PM, Hook said: I have high hopes for the weekend. ... which were dashed by the ghastly weather. A cold drizzle and water based paint do not mix. So I must admit defeat this round. Ever since metallic finish #1 went awry, either I was swamped with work, the weather was appaling, or, mostly both. Unless a late Christmas weather miracle will arrive in week 2 of next year I will not be able to make even the extended deadline. I'll probably KUTA her in the spring. Cheers, Andre 2
TEMPESTMK5 Posted December 30, 2024 Posted December 30, 2024 21 hours ago, Hook said: ... which were dashed by the ghastly weather. A cold drizzle and water based paint do not mix. So I must admit defeat this round. Ever since metallic finish #1 went awry, either I was swamped with work, the weather was appaling, or, mostly both. Unless a late Christmas weather miracle will arrive in week 2 of next year I will not be able to make even the extended deadline. I'll probably KUTA her in the spring. Cheers, Andre Good morning André I am very sorry to read that but I would like to remind you that as usual you can still finish your build after the dead line , the dead line is only for the Gallery ... Best regards Patrice 1
Hook Posted March 8 Author Posted March 8 On 12/30/2024 at 10:04 AM, TEMPESTMK5 said: I am very sorry to read that but I would like to remind you that as usual you can still finish your build after the dead line , the dead line is only for the Gallery ... Ah!, le smelle suite du victoire! Today the weather was such as to allow me to have an airbrush sesssion, I managed to get a very decent result with the Fickle Mistress that is metallic paint! Some Vallejo Air Duraluminium gently applied with the ol' H&S, I'm actually pleased as punch with the result: Bonus Airfix Super Mystère, since I had a good thing going metallicwise: Cheers, Andre 2
Hook Posted March 16 Author Posted March 16 Some work done over the weekend - I've addded some panel tone variations with metallic pigments: Resulting in this: Most major decalling done - I've still have to add some smaller markings, but she's really coming alive with those colourful bits methinks: Cheers, Andre 1
