Here is the provisional groupbuild calendar for 2025.
There are seven standard groupbuilds and one KUTA (in red) each lasting 16 weeks.
Seven Eight Single Type groupbuilds (in yellow) each lasting 13 weeks.
Two Classic GBs (in cyan) each lasting 20 weeks.
The Blitzbuilds (in green) each lasting three days.
So far there are no historical GBs which have been suggested.
Edit:   Incorrect.  There is the 200 Years of Railways GB, which I will now add in to the calendar.
Please note that the calendar is provisional.  Dates can be adjusted to suit circumstances.  For instance, it's nice to adjust an STGB start date to match a significant date relating to its subject, such as the first flight.
I have endeavored to keep the summer months relatively clear.  From 14 July onward there will be no more that seven concurrent GBs.  However, there will be up to nine concurrent GBs in the spring between 12 April and 14 June.
Once again, I have attempted to ensure that groubuilds don't run over into 2026 by too much.
I will put The Bunfight poll up later in the month.
Edit:  to avoid confusion the latest update is in the first post.
Updated 17 Nov 2024
  • Like 10
  • Thanks 6
  • Love 2
  • 100% 1
7 standard GBs, is that all,😁- at the last count I'm backing 11 in the bunfight, I sense a problem 🙀.
  • Haha 3
As for the lack of historical GB, while it wouldn't entice me, I'd have thought VE/VJ Days we're historically significant
  • Agree 1
June next year is 75th anniversary of start of Korean War.
And Vietnam war ended 50 years ago in April, may be relevant to that GB?
Chris
Edited by Chrisj2003
In the past there was a proposal for a GB around the theme "seen on TV" next year makes the 100th Anniversary of Baird's first TV transmission - probably a tenuous link to an anniversary GB but it's there.
  • Love 1
34 minutes ago, Angus Tura said:
Hi, @Enzo the Magnificent. Is pat @JOCKNEY's minor manufacturer melange going to be the other classic GB?
I've just looked at the relevant threads and it seems to have a bit of traction, so let's go for it.  :thumbsup:
  • Thanks 2
The first revision is now in the first post of this thread.  To avoid confusion I will only post one calendar graphic.
  • Thanks 3
It's nice to see the "Minor Manufacturer Melange" as a classic GB.
"Modelling Minnows"?
Regards,
Adrian
  • Agree 1
Here is a first draft of the calender for next year.   This graphic is also in the first post of this thread.
I have attempted to fulfil the requests made in the Bunfight thread and to minimise overlaps.  Unfortunately @Wez and @JOCKNEY do have slight overlaps but in both cases one of their overlapping GBs has a co-host, hopefully minimising the stress.
I have also attempted to have GBs start on or close to significant dates.  In one case a GB ends close to a significant date.
September and October are busy months with either eight or nine GBs running concurrently. The last halves of April and May also have eight concurrent GBs.
Graphic removed to avoid confusion.  Please see initial post.
  • Thanks 9
Looks good to me Enzo for the Hurricane STGB. Thanks for scheduling it to end on the anniversary of the Hurricane‘s first flight, a neat touch. And I now have a co-host in @stevehnz 👍
Peace is in favour all year round and sadly probably every day of the calendar is the anniversary of the end of some battle or another...which is a long way of saying the calendar works for me. Thank you Enzo the Magnificent for your continued magnificence.
  • Agree 1
@Enzo the Magnificent, as the only reasonable GBs for car builders are ‘80s’ and ‘Give Peace a Chance’, would it be possible that they didn’t overlap?
Thanks
Martin
  • 100% 1
The dates for Eighties and Post-WW2 Twins look good to me. My only comment is the title of Eighties is just that, "in the danger zone of the bunfight" was added when we, erm, made the bunfight. I'm quite happy to have "Ride into the danger zone" as the quote for the GB though ;)
James
Those GBs have some constraints due to host availability, but I'll see what I can do.   It may be that they overlap by a couple of weeks though.
You could also build cars in the Heller Classic GB, but that doesn't help at all as it overlaps both the GBs you mentioned.  The Anzac GB is another possibility.   And always remember that railway companies also operated a lot of road vehicles.
  • Thanks 2
Thanks, @Enzo the Magnificent, even a shorter overlap would be appreciated. If it can’t be done, don’t worry about it, but thanks for taking the time to have a look.
I pretty much dismissed the Anzac GB, but I’ll go and have a look :yes:
Martin
Another co host for the list, please add me to Railways 200.
  • Agree 1
Phew! I was just about to "volunteer' you. Id add that railways are a big topic so another volunteer to make full crew working would be welcome
Driver, fireman and guard
We could also have a traction inspector, a ticket inspector etc etc
