PENYDARREN 1804 – 1:35 test
I have been blessed with the opportunity to build a test model of a PENYDARREN locomotive made or more correctly 3D printed. This is a test and the model in the final version will look a little different, it will be completed with some details and corrections. The publisher of the model is the company ‘Świat z kartonu’ and the scale is 1:35. Below is a test print.
  • Like 9
Just goes to show how small the first locomotive was when you see it here, still looking small despite being 1/35.
This is definitely something unlike almost everything else built here, so it will be interesting to see how it goes together, even if trains aren't really my area of interest.
  • Agree 1
I managed to attach more parts, as you can see in the picture there are two wire parts but they are replacements for the print parts. I swapped to speed up the build as well as to see if it could be built as a mobile version. The parts fit perfectly. And there are a few parts missing from the print again.
All the parts cut out and fitted together on the dry model. I know that you can see that not everything is in the axis of symmetry but this is just put together for the photo. The parts fit together perfectly. As I wrote earlier it goes to make a running one because I have just tested it, but as I am making a test model I have to let go of this option and make it as a steadystate model.
It's an unusual construction on this forum, and a very nice result 👍
If you don't mind my asking: perhaps you should drill the inside of the chimney to reduce the thickness of its wall, for better realism?
  • Agree 1
The reliable LEGO blocks for catching the geometry on my workshop are always at hand and Penydarren is already on the wheels thanks to them being set straight.
Yes I know the chimney wall is thick but this is a test model and I just need to check that everything fits and I don't have time to ream the chimney. From what I already know the box is ready. I will definitely be making another one but already running. But thanks for the heads up.
This is the completed test model of the 1804 Penydarren locomotive in 1:35 scale made as a 3D printout and the publisher is the ‘Świat z kartonu’ company. For the rest of the photos, please visit the gallery.
